Busted Shifter
Busted Shifter
The shifter (Shimano Revo-Shift, 7 speed) on my Giant Halfway has pretty much given up the ghost. The derailler (Shimano Sora) is fine.
Is there any reason at all I can't get rid of it and replace it with an old-fashioned stem shifter (friction shifter)? Seems simpler and more durable.
permission cleared to try it.. how about a friction thumb shifter? revo = grip shifter right?
friction just means learning how far to move the lever to find the next gear.
lever needs to pull enough cable to span the distance between # 1 & # 7.. pulling on the read mech..
Yeah, that's the thing. All the old stem shifters I see on eBay were made for 5-speeds. On the other hand, the cogs were probably further apart on those old freewheels. It's the total width of the gear cluster that should matter, right? I'll see if I can get a look at an old 5-speed to measure.
Update:
It's fixed. I replaced the broken Shimano Revo-Shift grip shifter with a Falcon thumb shifter.
I had to wait forever to get the part -- seems like everyone was back-ordered. But it finally showed up. It's cheap, it works, and it took all of ten minutes to install it and fine-tune it.
No indexing, but who cares? It works perfectly.
Likes For Inisfallen:
