Axle mounted 700C fenders for commuter?
I have been looking for over a year for replacement fenders for my commuter (they are cheap and rust quickly. I have to repaint them every 3 months). Now it's a must replace thing as I upgraded to wider tires and they sometimes rub on the fenders. Biggest problem is my bike does not have any eyelets and the existing fenders are axle mounted. I can find 26" ones, but no 700C. My tires are 700cx45, so I'd want fenders a little wider to accommodate future coat guards on the sides. Anyone know if these even exist? Should I just give up and try to find a place to get eyelets braised on? Thanks and sorry if this is the wrong subforum.
Quoted: 7348 Post(s)
Liked 2,460 Times
You can use p-clamps on your frame which will act as brazed-on eyelets. Brazing is expensive because it requires repainting the frame.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
By "axle" I presume you mean for a QR wheel....in which case these fit the bill and are Prime on Amazon and allow you to mount any fender without frame-eyelets.
https://www.amazon.com/gp/product/B00JMAIK7E/
Likes For Marcus_Ti:
Mad bike riding scientist
Quoted: 6214 Post(s)
Liked 4,212 Times
Alternative, if you have a rack on the bike, you can mount the fender under the rack mount bolt, either under the rack leg or outside of it.
Stuart Black
Stuart Black
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
While this isn't a problem I've had to encounter (my bike frames all have eyelets for fenders) it shouldn't be a particularly difficult problem to solve.
You can already get these overpriced aluminum adapters for QR wheels:
https://www.modernbike.com/axiom-axl...-fender-eyelet
You may be able to make those work by enlarging the hole, but I wouldn't bother. I would just make something similar out of stainless steel sheet or some other weatherproof metal (copper or brass would be fine).
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 1034 Post(s)
Liked 1,290 Times
I will add, that if you have to paint them every three months, you aren't painting them properly. You need to prepare them properly, remove all the rust, prime them, then apply the paint. There is no reason the paint, properly applied, should fail so quickly.
Likes For phughes:
Quoted: 18369 Post(s)
Liked 4,507 Times
If you are looking for fenders, include 28" and 29" in your searches.
But, I'd go with @noglider and look for some P-Clamps to attach the fenders, and hopefully not have to mess with the fenders every time you change tires.
Your frame is metal, right?
Likes For CliffordK:
Likes For Gresp15C:
Liked 4,212 Times
I’m not a fan of them for rack clamps, however. Tubus clamps are stronger and easier to use.
Stuart Black
Stuart Black
Very Slow Rider
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Quoted: 500 Post(s)
Liked 132 Times
OP - Have you considered plastic fenders?
I have high quality ones that are durable, require no lower eyelets to mount (although this bike has them on the rear, should these ones ever give up the ghost) and they keep me dry and less weight than metal ones.
The back one looks goofy because I have modified it but still keeps me dry. Running 43mm tires. I know SKS Bluefels are much wider. These are from Portland Design Works. Got them in a trade or somehting, I don't remember....
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
Am I missing something here? Why not experiment with plastic fenders. They're rust proof and can be quite durable
Liked 1,290 Times
No, you aren't missing anything I simply pointed out that the reason the OP's fenders were rusting every three months was not the fault of the fenders, but instead improper painting, namely not priming the fenders first. Whether or not the OP replaces the fenders, it is a good thing to know for future projects. It is something I see here fairly often, people painting without priming first, and then having problems.
Likes For phughes:
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
Likes For davei1980:
Liked 1,290 Times
For sure! I agree with you they shouldn't rust at all in the short term. That said, if they are rusting, it seems to me plastic fenders seems to be a very obvious work around ignored possibly by the OP. There may be very good reasons to stay with steel fenders too which I haven't considered....
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
I would say the OP would do well to get some clamps for $1.83 and some plastic fenders.
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
“P clamp” or “p clamp for bikes” on Google will find all kinds of clamps. Home Depot has all kinds of cheap ones (that Rivendell sells for $11 per pair). Ones with better coating like these at least look nicer. For fenders, you could even use just place plastic ones like these. QBP also carries ones from Dimension so that they can be ordered from your local bike shop.
Liked 4,212 Times
I am considering a front rack but I have a CF fork. Would you not recommend tubus clamps or generic P clamps? I have eyelets in the rear, just the front of my bike has very little weight on it under normal conditions, makes sense for balance to not put a rack on the rear. Plus this way, I can see my beer as I ride...
Stuart Black
Stuart Black
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
I'll either swap out forks for a CrMo one with eyelets or just go with a rear rack.... I am fully embracing nerdy bike commuting. When I first started I was like "I don't need all those lights and fenders and bells are for kids' bikes!!" Now I am all like "I want that!"
Side note - just got brand new rims as a gift to myself and set up my new tires tubeless. Felt like riding a new bike today!
Quoted: 5224 Post(s)
Liked 3,581 Times
Liked 3,581 Times
Liked 3,581 Times
I was just trying to remember a bike I had where I cut the fenders & lifted them & wondering if the cables prevented me from lifting them. but looks like they weren't a problem. I did it in stages, lifting them once them again higher. also worked on another bike doing the same thing especially when I mounted up the studded tires
https://www.bikeforums.net/hybrid-bi...ide-tires.html
https://www.bikeforums.net/bicycle-m...it-bike-2.html
then I got a MTB & did it all again. that's why I mentioned the rare technique that some ppl resort to
