Most powerful solvent for aluminum rims?
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Trying to clean up Gorilla tape residue and tubeless sealant - incredibly tenacious gunk. I've tried mineral spirits and acetone - acetone seemed a little more effective but it's still a lot of work. Seems like too much work.
Any recommendations for a more powerful solvent?
Is Muc-off glue and sealant remover better than acetone?
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Liked 2,011 Times
I don't know. I'd like to hear "X works better than acetone" before I go buy some. Not a fan of having various special cleaners but this gunk is kicking my butt and blistering my fingers. I'm ready to buy the special cleaner if it will help.
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
The only solvent I have in my garage stronger than acetone is methyl ethyl ketone (MEK). It can turn paint tacky just by contact. I'm not sure if it would work well cleaning goo off rims without causing some damage to the finish.
Likes For FiftySix:
Clark W. Griswold
Quoted: 4349 Post(s)
Liked 3,987 Times
Typically if I have some tape residue I try Triflow and that will frequently work. Not always but sometimes.
0000 Superfine steel wool. As long as the rims are aluminum.
Liked 2,011 Times
X works better than acetone and he is also gon to give it ya.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
I've used Goo Gone on a lot of things like label adhesives. I'd suggest trying it. The 3m product (Citrus Based Adhesive Remover) is based on an sweet orange extract. 3m stuff is usually pretty good. I'd try one or the other. PRobably the cheaper one first.
Rub on Goo-Gone, let it sit for 15 to 30 seconds, then use a Scotch-Brite pad. Then soap and water. It's not a sure thing but it's worked a lot of times for me.
Likes For WizardOfBoz:
Brake fluid or gasket remover. Both may discolor the rim - so test first.
Likes For masonv45:
Friendship is Magic
Bikes: old ones
Quoted: 26411 Post(s)
Liked 10,376 Times
...I have never removed the adhesive from Gorilla tape. Generally speaking, my order of solvent escalation is mineral spirits > acetone > spray can brake cleaner (auto parts store) > spray can carburetor cleaner (auto parts store).
The last two are probably bad for you to breathe or absorb through the skin. But they are aggressive solvents. A lot of glues seem to get more removable when you heat them up with a heat gun. Then acetone or the carb cleaner.with a rag.
Likes For 3alarmer:
Likes For Bill Kapaun:
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Why not call the "Gorilla" folks and ask them?
Found this on their FAQ https://www.gorillatough.com/first-aid-sds/tapes/
Let us know what you find out from them
Other questions or concerns can be answered by our Gorilla Support team Mon–Fri, 8 a.m.–5 p.m. Eastern Time at 1-800-966-3458
Likes For JoeTBM:
Quoted: 668 Post(s)
Liked 529 Times
Goo gone works better than acetone
I've used it on car wiring harnesses and removing labels from bottles or computer equipment. Removed 40 year old electrical tape residue with no drama, actually smells kind of nice. Acetone is actually hard on old wires.
Tubeless sealant I've never monkeyed with.
Likes For Pop N Wood:
With a mighty wind
Quoted: 1087 Post(s)
Liked 862 Times
I left duct tape on windows for like a month after a hurricane. Goo gone works great.
It's slightly oily, so when you're done, I'd clean the braking surface with dish soap then rubbing alcohol. Unless you want discs.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Latex-based sealant will dissolve in household ammonia.
Likes For JohnDThompson:
I'm the anecdote.
Liked 1,176 Times
I forgot about that citrus based product. Some of my customers that produce adhesive labels for the oil and gas industry go through a lot of citrus adhesive remover. I've used it myself while working on their machines and use a razor blade to scrape off the softened goo.
Quoted: 1062 Post(s)
Liked 665 Times
The best solvent might be Time. I've removed tape residue by applying a thin coating of heavy oil -- whatever is on hand -- and waiting overnight. Some folks use peanut butter, because the peanut powder holds the oil in place. Even cooking oil works.
Likes For Gresp15C:
Likes For woodcraft:
Clark W. Griswold
Liked 3,987 Times
Bikes: 2021 Trek Domane SLR7 Project One 62cm- 2010 Specialized Allez 61cm
Quoted: 118 Post(s)
Liked 88 Times
Glenn
Likes For GAtkins:
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,217 Times
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 4806 Post(s)
Liked 3,928 Times
Likes For 79pmooney:
Quoted: 550 Post(s)
Liked 325 Times
Unfortunately, they cause cancer and are illegal to sell in California.
Likes For Drew Eckhardt:
