Bought tubeless by mistake
Commuter
Bikes: Hybrid ; Fatbike
Quoted: 32 Post(s)
I didn't see these were tubeless...and I can't do tubeless. They are being shipped now.
Should I stick a tube in...or return them?
https://www.chainreactioncycles.com/.../rp-prod160951
Likes For Canker:
I agree with Canker. Just put a tube in them. most my bike tires say tubeless or tubeless ready. My understanding is tubeless just means it is made to tighter tolerances to be air tight where it fits into the rim.
Just throw in a tube. With a few exceptions, pretty much everything high end in the MTB market is only available tubeless because the market for high end tubed MTB tires has more or less evaporated. This is sorta unfortunate because if you really don't need tubeless, the tighter bead makes the tire slightly harder to install and remove, and it requires somewhat more sidewall reinforcement which increases weight and may slightly increase rolling resistance--which is usually offset by the lack of a tube. But its seriously not a big deal.
Quoted: 668 Post(s)
Liked 529 Times
Seems like a bit of a shame to use that particular tire with tubes, but like others have said it should work.
Commuter
Quoted: 32 Post(s)
I bought cheaper ones recently...rubber is cracking all over and is delaminating from the sidewall....thought I'd throw some money at it...lol
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Quoted: 2338 Post(s)
Liked 2,822 Times
even though it is a UK bike shop (i have shopped with them) you should be able to return, check the options out
