Best Aluminum Road Wheels?
#76
Back to the OP's original question. I recommend ROL wheels. Pretty good bang for the buck IMO. I've been riding a set of their entry level Volant wheels for about 15 years. Still as true and smooth as the day I bought them. About $500. Unless you're a hard core racer or weight/aero/watt geek they're all the wheel set most of us need.
As to the thread drift regarding aero vs weight vs watts, unless you're racing, I mean really racing, most of that stuff doesn't matter hardly at all for an average rider. We go up hill, we go down hill, we ride in front of people, we ride behind people, we have tailwinds, we have headwinds, we have crosswinds and we hardly ever accelerate hard. We're riding not racing. Even if we're on a spirited group ride we're still not racing.
I'm all for learning bout techy stuff and I like cool bling bike parts as well as the next guy but for 98% of us wringing out the last .1 watt, wheel inertia and aero effectiveness doesn't matter one little bit. We just like to ride and we sometimes like to ride hard. Buy whatever floats your boat but realize that unless you're in the upper 2-3% of riders that have the ability to take advantage of these very minor differences it just doesn't matter. By all means buy expensive bike stuff. I do, but I do so knowing I just like the technology. I have no illusions that it's going to make any meaningful difference to how fast I ride. A little bit maybe but nothing one of my motivated ride companions couldn't overcome with a modicum of effort.
#77
Now, none of that changes the perception that heavy wheels are harder to start from a standstill, and we likely care about wattage losses over a short period of exertion much more than wattage gains over a longer period of rest (coasting).
#78
Lighter wheels spin up nice. Aero wheels cruise nicely. Lighter is nicer, more aero is nicer. Pick what you like, and go for a ride :-)
Likes For aliasfox:
#79
Quoted: 501 Post(s)
Liked 631 Times
But anyone who's ridden a 3-4% grade will tell you they can feel the difference from flat ground due to gravity, meaning weight certainly is a factor at those lower grades.
For 182 lb combined bike/rider weight at 250 W, a rider will be moving about 15 mph. Of those 250 W, about 160 W goes to overcoming gravity while only about 60 is used to overcome drag.
#80
Quoted: 4236 Post(s)
Liked 2,949 Times
Does OP have a bike yet? What wheels came on it? In what way would you like to get better?
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
#81
Quoted: 4414 Post(s)
Liked 4,867 Times
In other words, the old "rotating weight is more important than frame weight" is true in theory, but is actually trivial in practice given the actual weight differences in rims and the actual accelerations on the ride. I think I remember reading this - maybe on this forum - a while ago. Seems to make sense to me.
From the Swiss Side analysis, 400 g of wheel weight was worth only 0.7 sec in rotational inertia on the crit course vs up to 80 sec for the aero difference! To put all this into perspective, 1W of extra power on the same crit course was worth 5 sec. So the aero advantage could be worth up to 16W, while rotational inertia is worth just 0.14W.
#82
Quoted: 2483 Post(s)
Liked 2,955 Times
Riding impressions: they made the bike feel top-heavy, although I got used to that, somewhat. What I couldn't get used to, and what persuaded me to sell them on after a few months, was the slight but perceptible reduction in the momentum of the wheels throughout each pedal stroke. Slow down, speed up, slow down, speed up . . . .
Drove me crazy during time trials. Going back to my (much heavier) Campy/GP4 wheels was a relief.
#83
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 465 Post(s)
Liked 547 Times
Sorry folks, but the real answer to the OP's question ( "the best ALUMINUM road wheels for racing? Or at the least, for going fast when one is biking all by oneself?" ) is that aluminum wheels are outdated technology that survives as the low cost option. I have a set of Winspace D67 that are 60mm Front / 68mm Rear. If you want performance, that is a good place to start. They are about 1500 grams for the set. The rim brake version of these wheels are about 60 grams lighter.
So, aero or weight, it doesn't matter. The best aluminum wheels are carbon wheels.
#84
Fast wheels for riding by oneself and fast wheels for riding in a (fast) group are 2 different things. On a flat ride by oneself, aero is indisputably the most important factor, up to the limit of getting blown around by side winds and crashing out. But on a competitive group ride, particularly with climbing, low rotational wheel weight rules.
Using Steve Gribble's calculator, a 183 pound (combined) rider going up a modest 5% grade at 15mph needs just over 360 watts of power. Overcoming gravity requires 270 watts, and wind resistance consumes 60 watts. Rolling resistance, as always, is a distant third-order effect. Mechanical losses are fourth order.
So dropping a pound on the bike and wheels may save you only a few watts, but these are watts that you really really need. You are already maxed out, tongue dragging on your front wheel, and ready to pop off the back. If you drop back 10 feet from the wheel ahead of you, you're done, suffering solo for the next hour.
This doesn't just happen once per ride, but on every climb, and exiting every fast corner. So rotating wheels up to speed is not a one-time per ride requirement, but is a critical necessity often hundreds of times per ride.
I think the naïve assessments here are coming from riders who don't have any pack riding experience, or just like thick-profile wheels because they look Kewl.
#85
Liked 4,867 Times
Swiss Side did calculate rotational inertia in their model and found it to be totally insignificant in all scenarios, especially climbing (<0.05 sec over a 31 min 7% climb). The effect of the 400g total weight saving itself was worth just under 7 sec on the same 31 min climb.
In your climbing example above, 1 lb of weight is equivalent to 1.5 W. No more and no less.
If there is any naivety here it is from you thinking that 1 lb lighter wheels are going to make you significantly faster.
Likes For PeteHski:
#86
Quoted: 465 Post(s)
Liked 547 Times
First off, I ride with a group four days a week in a place where there are no climbs but where a 20 mph wind is common.
Even if there were climbs, there is still that wind, and my 60 mm deep wheels weigh in at 1500 grams and the same brand 35 mm wheels are about 200 grams less.
And remember that I am not always back in the pack. I get to take my turn at the front taking the full brunt of the wind. The aero effects of the deep wheels overwhelm any benefit of less than half a pound of weight.
#87
Bikes: 2002 Eddy Merckx Team SC Resto-Mod; 2019 Ibis Hakka MX; 2017 Spot Brand Ajax Belt Drive
Quoted: 169 Post(s)
Liked 192 Times
#88
Quoted: 1529 Post(s)
Liked 718 Times
And assuming the resin matrix is up to the job, a carbon brake track is a much nicer thing than a sticky metal which likes to form gougey little chunks in your pads, and they seem to generate way less horrible filthy dust.
Furthermore, if the brake tracks on my Caden rims are anything to go by, the lower friction coefficient is a solved problem without the need for a textured surface, at least in the dry.
