How Many Teeth in this Small Chainring?
Bikes: 1997 Specialized M2Pro
Last April I replaced the small chainring shown in this photo. The new chainring has 38 teeth. I neglected to note down how many the old one had, though I recall it is greater than 38. The old one was so worn that I threw it away.
From this picture, taken before the replacement, how many teeth do you think there are?
I figure 39 (7.8 teeth between the bolts, times 5 = 39). This is a 1995 Specialized M2 Pro.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Quoted: 128 Post(s)
Liked 12 Times
1) wow, that is quite the stretched chain! and resulting shark-finned teeth on the small chainring. I take it the large chainring was less-worn and works fine with the new chain?
2) I can't confidently tell if the chainring pictured is a 38t or 39t, but am confident it's not 42t (the other common small chainring on a road bike). It's most likely 39 because that's much more common than 38. Plus you recall it was more than 38t.
3) It appears that your large chainring doesn't have pins/ramps/gates to aid shifting, and so it's less important to match it perfectly to a certain designation of small chainring. You'll be fine with the 38.
"c" is not a unit that measures tire width
The Drive Side is Within
https://www.bikepedia.com/quickbike/B...el=M2+Road+Pro
says 42 for a 95. But I also think it looks like a 39.
The bicycle, the bicycle surely, should always be the vehicle of novelists and poets. Christopher Morley
Quoted: 5791 Post(s)
Liked 2,581 Times
You can "count" teeth my measuring how far above the rim of the bolt the tooth shoulder is. On a 130BCD ring, the shoulder just touches the bolt. Add 1 tooth for every 2mm or so of added clearance.
BTW- it's easier if you look from the back. but based on it not showing in the cutout, I'll join the 39t crowd
FB
Chain-L site
FB
Chain-L site
given 130 accepts a 38 or 39, and common sets in roadie world is 53 -39. and its probably
the original stuff , I'll vote 39..
Campag opted for their 135 BCD the 39 is their minimum.
Let your bike be the tool
Bikes: '66 Raleigh Carlton, '70 Ron Cooper, '95 Bianchi CD'I, Zonal Frame with Xenon gruppo, Carbon Frame with Record Gruppo, Columbia Twosome, Terry Classic, Bianchi SX, Gravity SS/FG
Quoted: 338 Post(s)
Liked 314 Times
Are you guys are messing with my head? I count 8+ teeth between the bolts. Putting a right angle centered on the spindle center just outside the picture's frame I count around 11 teeth making the old chain ring at least a 42?
Never try to teach a pig to sing...
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
It's a '90's Shimano Ultegra "tri-color" crank. My money's on the standard 39-53 combination.
Jeff Wills
Jeff Wills
Quoted: 128 Post(s)
Liked 12 Times
his small chainring is pretty bad, but it can get worse...
I remain curious about how the large chainring has fared with the new chain. I assume the cassette (rear gears) has been replaced, right?
guys, the bikepedia is saying 42.... and if we're seeing 8+ teeth, which looking again, I do.... 42 should be it.
It is the meaning of the universe, too, you know.
Don't panic.
Don't panic.
Liked 2,581 Times
Now take a look at the photo, and note that the inner diameter of the chainring rim passes close to the line of the bolt circle, but certainly to within the rim of the bolts. eNow take a look at the inner rim of the ring, and compare it to one pitch. So since a 38t is possible, that means that if this is a 42t you'd have to take 8mm out of that rim. I don't see 8mm there to rob, so I'll bet a case of beer that this was not a 42t.
FB
Chain-L site
FB
Chain-L site
hmm, fbinny. what you say makes sense, and here's a 42....
which does look bigger. But I think the grease plays tricks on the eye. Stock is clearly 42.... but i think you're right.
And here it is today with a known 39 tooth chainring:
7.8 teeth from one bolt to the next.
And if those two pictures don't convert you to paraffin lubing...
Quoted: 2026 Post(s)
Liked 1,096 Times
https://www.bikeforums.net/showthread...Skip-Woes-Help!
In summary: I had some problems with chain skip that, it turns out, were related to switching to a 38 tooth wheel. I wanted to go back to what I had.
Surly Stainless steel chainrings are long wearing .. I have a 38t on my R'off bike..
skeptical, but I cannot supervise and consult from a keyboard.
Wait, amazing b/c I can't count teeth, b/c someone actually made this diagram, or b/c bikeforums is so awesome that I naturally expected someone to come up with it?
I know, I know--- probably all three.
