Ultegra 8000 front derailleur rub; is it me or the cranksets
Working with 4 bikes each with ultegra front derailleurs but only on the bikes with ultegra cranksets can I easily eliminate chain rub in all gears.
Bike 1: Custom titanium Road bike with 6800 FD and ultegra cranks, chain passes the cage in all directions after minor adjustments of limit screws and cable tension using in line barrel adjuster
Bike 2: Salsa gravel bike with R8000 and ultegra cranks, rub eliminated following set up directions, adjusting combinations of L, H, and cable tensions screws on the derailleur
Bike 3: CAAD10 road bike with R8000 FD and SRAM Red cranks. Chain rub in big/big combo eliminated, but after much tinkering and smaller cap between chain and cage when in highest gear so much less room for error
Bike 4: Salsa Gravel bike with r8000 and praxis cranks.Could not eliminate chain rub in big big combo without creating rub in highest gear.
Expired Member
Quoted: 3665 Post(s)
Liked 5,414 Times
I think you are doing OK. Shimano doesn't expect us to be able to consistently use big/big w/o rubbing.
aged to perfection
Quoted: 837 Post(s)
Liked 1,255 Times
Right. The "Big/Big" and "Small / Small" combinations are the extremes of chain tension and slack, as well as chain angle. This is particularly true of bikes with short chainstays.
Other gear combinations can approximate the ratios in those combinations. So, don't use them.
For best shifting the outer piece of the front derailleur cage should be parallel (in plane with) with the large chainring.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
