Selecting Correct Inner Tube
I need to replace the tubes on a 20" mountain bike. The bike has 20 X 2.8 tires and 20 X 2.20/2.50 tubes. The tubes I have in stock are 20 X 2.00/2.25. Are these acceptable to use in these tires or do I need to source the same tubes removed?
Quoted: 1438 Post(s)
Liked 1,092 Times
Meaning that a smaller tube will be stretched thinner and be more easily punctured, but absent a puncture (which might put a hole in a bigger tube also) it should work just fine. Many folks like using smaller tube stretched thinner because they save a little weight. You might consider getting a tube with a closer fit to keep in stock for next time.
