46t/19t?
I'm on a 46/18 fixed, its on the sort of easier end of gearings but not so easy that my knees blow out while going downhill. If you live in a hilly city like I do, and are not super strong, go for it. If you live somewhere flat, I would recommend, something a big harder.
Thanks guess. I am really just looking for an all around ratio. I was thinking 46/18 but went for a spin on another bike tonight with the gearing at 48/19. Still seems a little tall. A 48/19 is really close to 46/18 in gear inches. i am buying a fixed soon and will mostly be using for fitness. 46/19 I think will keep me pedalling pretty consistently. Which is my objective. So I don't blow out the knees at longer distances in higher gears. Thanks again.
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
My advice is to keep pedaling and figure out what works best for you. Don't base your choices on what others do.
Thanks almost trick. Just wondering how other peoples ride have been like riding 46/19. Your advice is understood. Thanks again.
Liked 941 Times
I've been spinning 46x19 for several months now. It seems perfect and I have no plans to change it. I also believe many running higher gears are mashing or over geared. Very few are sustaining 20+ mph for any great distances.
Thanks again almost trick. Your advice and experience with 46/19 is more than likely the way I am going to go. I plan on doing a lot of distance riding and this raToo from my research could be bang on. Your response has been happily received. Appreciated.
Liked 941 Times
Changing ratio's is cheap and easy. Experiment.
If, like me, you know where you spend most of your time on a geared bike, go a tiny bit higher than that. That's what I did and it was spot on.
I hear ya almost trick. I went for a spin earlier tonight on a geared bike. 48/19. Felt a little tall. Your comment about 46/19 was what i thought would be bang on for me as well. I think I got my answer.
Liked 941 Times
Let us know how it goes.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I can't wait for the 46/17t thread to begin. 'cause that's what I ride...and, I'd like to say that.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
I'll be waiting a while for 45/16 to come up. Maybe I should preemptively start the thread.
Pirate/Smuggler
Pirate/Smuggler
Bikes: Felt TK2, Felt Z5
Quoted: 943 Post(s)
Liked 20 Times
I thought 46:16 was a bit too spinny. I couldn't imagine 46:19. My riding area consists of mostly flat roads however. I really like the top end on my 49:15 which allows me to ride more at a geared road bike pace vs a "fixie."
67" is great for those learning to skid. but too low to be practical imo.
interestingly upon looking at this chart:
i realized it is wrong, w/ gross errors in calculation.
i'm currently at 53x18 which is a tad bigger than 44x15 (previous ratio). you'll see that's not reflected in the chart. hopefully no one uses this one.
this is the better one: https://rideyourbike.com/images/skidspots.jpg
uses the default 27" as the wheel diameter constant as well
Quoted: 399 Post(s)
Liked 273 Times
^^^ Surprise, surprise - I too, like that calculator, especially for the fact that it includes odd. smaller wheel sizes. I used it back when I had a mini-fixie with 20" wheels to figure out what-the-hell size rings & cogs to use on that thing.
Mentioned it in another thread - but here is my favorite gearing calculator ATM...
Catculator, the Fixed Gear Calculator
