Rear Derailleur problems
Hi guys, I will get straight to my problem. So when I tighten my rear quick-release axle my rear derailleur hanger gets bent for some reason and my derailleur cage starts hitting my spokes. Is there a reason for this or any fix?
Thank you
Thank you
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
A quick fix may simply be to grab the rear derailleur and pull it away from the spokes followed by an adjustment at a shop
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Yes, there's a reason for it...your hanger is not aligned correctly. It doesn't matter what it looks like with the wheel out, only when it's on the bike. Have it aligned by someone that knows what they're doing.
Likes For cxwrench:
If you have a replacable hanger tighten the bolt(s) or replace the whole thing if it's bent.
Quoted: 2236 Post(s)
Liked 1,314 Times
Also, just a thought. Check that the axle/hub actually fits the dropout spacing without too much play. If there is an axle nut missing and/or the QR is flexing the dropouts inward that would pull the derailer as well.
Not likely, unless its a new bike to you or you were recently working on the wheel, but another random posiblilty.
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
I recommend throwing away the derailer and going SS.
Liked 1,124 Times
My friend told me to do that and He guides me in everything i do --- I will be doing this after i procure a cordless makita reciprocating saw to cut my bar width down a few inches
(oops - i thought you were in on this thread but i was mistaken
- however if you have time to read it, its a doozy
Cheez Wants to Buy a Nice Mountain Bike - Page 4 - Bike Forums )
