Ideal Seat Bag Contents
Green Tea Lemonade
Because I busted a flat today on my way home from baseball practice (and I had to shoulder my steel-frame bike all the way home), I am seriously considering getting a seatbag... what should the contents be? This is my list thus far. Also, could anyone reccomend a good brand, or at least a good sie of bag.
Extra Tube
Patch Kit
Tire Iron
Small Adjustable Wrench
Allen Key set (not in the bag, as I have an old set that can fit in my pocket, along w/ a presta valve adapter)
Then I have to consider how to pump up a tire... should I get a bike mounted hand pump, or one of those CO2 pumps? How expensive are they, and are the refills expensive too? Thanks in advance.
Extra Tube
Patch Kit
Tire Iron
LET'S ROLL
I use a 2nd waterbottle to hold my spare tube/tools.
I prefer a frame pump, can inflate as many flats that
I get plus I don't feel bad lending it out to fellow riders.
Which has happened a few times.
WESTSIDE PATH NYC by 1nterceptor, on Flickr
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
Real Men Ride Ordinaries
Quoted: 17 Post(s)
Tube, patch kit, all relevant allen and box wrenches (stripped from a multi-tool), tire levers, chain tool (also stripped from a multi-tool), bit of a tyvek envelope for a boot, and a patch kit box first aid kit (a few big bandages and Exedrin, for those poorly timed migraines). Frame pump on the bike. I also try to keep a $20 somewhere handy, just in case, but more often than not it ends up being spent.
Green Tea Lemonade
You gonna eat that?
You gonna eat that?
LET'S ROLL
Everything is squeezed tightly. No rattles.
Pretty much what everyone posted up here.
For commuting I carry the following.
Bike mounted pump
Multi-tool (bike specific) that has tire levers incorporated into the design as well as a chain breaker.
Multi-tool that has pliers and knife.
2 spare tubes (lightweight tubes, i.e. compact)
patches
On my worst day I got a flat in the morning commute. After patching it up, I started to pump air and the damn valve stem broke on me (hence the multi-tool with pliers). On the way home I got another flat, but didn't have patches on hand so I had to use my last tube.
As for the chain breaker, a co-worker had to help another commuter with a broken chain and the tool came in handy.
Bike mounted pump
patches
I go along with what everyone else said, but would like to add that I prefer the Mini-Morph or Road-Morph pumps, as instead of the pump attaching right to the valve stem, the pump has a short hose (really a piece of plastic tubing) that goes between the pump and the valve stem. This prevents possibly ripping the valve stem out of the tube (which I gather is what happened to you in your first post).
The advantage of a pump over a CO-2 inflator is that the pump never runs out of CO-2 cartridges, and I don't feel like that you can control the amount of gas that goes into the tube as well. The CO-2 inflators are mainly intended for racers, anyway, and not really necessary for everyday applications.
I also carry a few electrical tie-wraps as well as a pocket knife. Don't really know why, except that the tie-wraps might come in handy, and a knife is just one of those things that, if you need one, you need one badly!
mountainwalker
Commuting
62
06-23-14 08:10 PM
krazyflip
Road Cycling
27
05-22-10 01:19 PM
