Ball Bearings
Bikes: 64 Carlton Catalina
Ball Bearings
I need some ball bearings for a rebuild of a 1964 Carlton and my LBS only has grade 300 loose balls so I was looking online and found both stainless and Magnetite finish grade 25 balls. Can anyone tell me the difference between the two finishes and which are preferable?
Thanks
Thanks
Really Old Senior Member
Don't know what Magnetite is, but I think stainless is slightly softer than "normal" BB's.
I get mine at-
https://www.loosescrews.com/index.cgi...id=10827251054
I usually get a few bags when buying other stuff to amortize the S&H.
I get mine at-
Quoted: 2026 Post(s)
Liked 1,096 Times
Ball bearing "Grade" is a measure of roundness and the lower the number the better, so Grade 25 bearings are rounder than Grade 300. Actually for the low demands of bicycles, Grade 300 or 200 are adequate but most mechanics use Grade 25 because the cost difference is minor and that is the best readily available grade. Stainless (usually 440C) bearings are good but not guite as durable as "Chrome Steel" bearings which are also less expensive. The Loose Screws link Bill Kapaun gave is a good source as is Bike Tools Etc. (www.biketoolsetc.com) and Amazon sells bearing balls also.
Bikes: Specialized Sequoia Elite/Motobecane Fantom Cross Team Ti/'85 Trek 520
I just dig around in the dirt for approximately correctly sized pebbles and use them.
Bikes: Specialized Tarmac
I can only imagine what that would be like to ride. I'd probably feel like indexed wheels. Sort of like the indexed steering you can have when the headset is out of whack.
Liked 6 Times
As pointed out by HillRider, Grade 25 is the best for bicycle applications.
I buy mine from this people, https://www.vxb.com/ b/cos of their excellent quality and prices.
Bikes: '86 Trek Elance 400; '83 Trek 520; 90s Specialized Crossroads, '84 Trek 610 (wife's), 90s Trek Multitrack (wife's), Cargo Trailers, Burley for the Kids, WeeHoo Trailer
I get grade 25 for my bikes. Like Jed19, I order them from vxb.com.
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
Check with a local bearing house and buy in bulk.
https://yellowpages.aol.com/business/...ll+Creek%2C+WA
Liked 1,096 Times
Liked 1,096 Times
SE Wis
Liked 3,390 Times
Buying in bulk is obviously cheaper per bearing but unless you own a bike shop 1000 bearing balls are going to last a looooong time. I buy in bags of 100 for 3/16 (front hubs) and 1/4" (rear hubs) and 5/32" (Campy hubs) Grade 25 balls. They are less than $5/bag and last several years worth of overhauls on my personal bikes.
Quoted: 5772 Post(s)
Liked 2,564 Times
My friend at SKF asks that I correct this every time I see it.
Ball bearings are the complete assembly, including the inner and outer races, the seals and the balls. The balls themselves aren't bearings, they're just balls. If you wish, you can call them bearing balls, so they're not confused with golf balls.
FB
Chain-L site
FB
Chain-L site
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
Probably no decernable benifit, but at only a dollar a ball, I'd say that would be one of the cheaper 'upgrades' if thats all it takes to put a smile on your face. A genuine bargin compared to all the CF seatposts and stems and bars that are becoming increasingly common on commutor and weekend bikes.
Quoted: 413 Post(s)
Liked 109 Times
Deleted/edited my mis-information....
.001mm is Campy bearing tolerance which is close to grade 25....
Liked 2,564 Times
The key to rust prevention is the type of grease used. Quality greases, combined with regular use to keep them circulated are the best way to prevent rust on races, and far less expensive than ceramic balls.
As for wear, a decently cared for set of hub bearings (greased every 5-10,000 miles or in Spring if riding on salted roads during winter) will last well over 50,000 miles. For most of us that's more than the life of the bike.
FB
Chain-L site
FB
Chain-L site
Liked 1,096 Times
That's very interesting and I'd also like to see the source of this information. A Campyphile poster on another froum used to insist Campy used Grade 10 (or was it Grade 5 or maybe even Grade 3...) bearing balls and "hand matched" each and every set and they had to be used as a complete set. I was always suspicious of this claim and would like to know the truth.
Liked 2,564 Times
I use the phrase " the proof of the pudding is in the eating" on the Chain-L site, and I used it years ago when selling tools, because I believe that that's the only issue a user needs to concern himself with. If I go to a restaurant where the food is consistently excellent, I don't query the chef about his recipes.
Back to Campy, given the extremely long service life of their bearings I don't need to know what grade balls they use, I already know that it's plenty good enough for the job.
FB
Chain-L site
FB
Chain-L site
Quoted: 413 Post(s)
Liked 109 Times
It would be somewhat interesting to know, and certainly to debunk the hand matched nonsense, but does it really matter. As long as I was in the bike industry people always asked about what stuff was, rather than what it did. When I made cone wrenches and freewheel removers, I got all sorts of inquiries about the material they were made from. My answer was always that it didn't matter why or how a product did it's job and lasted, as long as it did both well.
I've heard the comments about 'hand matched' sets and matching lot numbers as well...who really knows? And yes, whatever it is that Campy used/uses is more than good enough for the job!!!
Here's a Campy document verifying grade 100 bearings, Campy didn't state this very often, I think I've only seen it 2 or 3 other times.
https://www.minortriad.com/campagbb.html
