Quick questions and answers
#1327
Bikes: steel track
Quoted: 235 Post(s)
I have a Novatec hub similar to this one:
One of the red spacers got locked down too tight, and I believe it's rubbing against the hub and needs to be loosened.
However, it's stuck tight, and I can't hold onto the axle tightly enough to turn the spacer without the axle turning along with it.
Any ideas?
Any ideas?
#1328
Rocket Scientist
Bikes: 2001 Bianchi Pista
Quoted: 9 Post(s)
What if you tried tightening the other side (non-stuck) to your dropout so that the hub is on the outside of the frame?
here is a crude depiction: /\ is the frame viewed from the rear, _ is the hub... /\_
#1329
Fixie Infamous
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
Any ideas?
Any ideas?
#1331
Bikes: steel track
Quoted: 235 Post(s)
Well, damn, that sure worked better than cursing and banging on my hub with a wrench like a crazed monkey.
#1332
Rocket Scientist
Quoted: 9 Post(s)
Quoted: 1332 Post(s)
Liked 398 Times
Probably fine. I'm running 23's on Archetypes, which I think are a 23 outer width. Can't imagine ever wanting to go skinnier than 23's though unless the riding surface was smooth as glass.
#1335
Bikes: Wabi Classic, Schwinn Madison
Quoted: 19 Post(s)
Yeah, i was wondering cause right now my 25s measure as 28s on the 24 width rim. So if i used 23s it would probably size up to 25 or 26. And it would be more aerodynamic if i used 20s. I probably shouldnt even worry about this since i dont ride professionally... thanks for the info.
#1336
Quoted: 324 Post(s)
Liked 251 Times
1. The super plush and comfortable, yet still fast and grippy ride that I get with 25s
2. My gumwall tire of choice does not come in 23
#1337
Bikes: Felt TK2, Felt Z5
Quoted: 943 Post(s)
Liked 20 Times
I've also considered running 23s on my Archetypes for a little more aerodynamic benefit but cannot fathom having to make these 2 sacrifices:
#1338
Bikes: steel track
Quoted: 235 Post(s)
Anyone have thoughts on the best way to cut down Champ Yoshida grips?
I don't like snaking them all the way around the bends in my risers, but the last time I hacked down some grips they looked like they got mauled by a t-rex, which I would also like to avoid.
#1339
Clark W. Griswold
Quoted: 4352 Post(s)
Liked 3,990 Times
#1340
Quoted: 79 Post(s)
Not only are you (or any of us.. I think?) not pro, but the width of your tire really shouldn't be your concern when it comes to aerodynamic drag. Search "how to be more aero on a bike" for all the low-hanging fruit that makes up the vast majority of your drag; then (and only then) should you even start to think about the marginal gains you might (might) get from things like tire width.
#1343
Liked 398 Times
But it makes them so smooth. Also the biggest aero benefit you can get is just getting in the drops.
#1345
Quoted: 399 Post(s)
Liked 274 Times
Sub 1600g wheelset for $200? Anybody here used or know anything about these wheels? Or the company, or any of their other products?
https://conquerelite.myshopify.com/products/s-300
#1346
Clark W. Griswold
Liked 3,990 Times
Mr Pink?
I have a decent enough portion of a 600 Tricolor gruppo and kinda want to build a more modern rode bike and saw there is a new Mr. Pink coming in the nearish future possibly I think so I might build up a little 600/Ultegra jobber.
#1348
Clark W. Griswold
Liked 3,990 Times
#1349
Quoted: 686 Post(s)
Liked 5 Times
I just swapped everything on mine to DA except for the crank. Think I'm going to throw on the White Industries crank and call it a day.
#1350
Your cog is slipping.
