Mountain Bike recommendations?
Hello all. First time posting here. I am looking for decent mountain bike under $300. I am looking at a few models and need your opinions.
NorthRock XC6 $299. It is a bike from Costco and I've heard it is good quality and has a good frame. Reviewers have said it is not possible to find a better bike for this price.
https://www.northrockbikes.com/mountain-xc6.php
Kawasaki DX226FS 26-Inch Dual Suspension Mountain Bike
https://www.amazon.com/Kawasaki-DX226...pr_product_top
What do you think of these 2 bikes?
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
What are your intentions with the bike? Actual offroad? I myself would invest more money as the low end components really suffer in the dirt.
Either way, road or trails, I'd pass on the Kawi full suspension. Once the low end rear suspension breaks, it's toast. I've had buds with GT mtb's lose the bike due to lack of hard to find replacement parts. Maybe things have inproved over the last few years though I wouldn't risk it.
Ahh, I'd go for the hardtail myself. I had a Trek 800 years ago, $250 rigid (no suspension at all). It had similar components and it did well in the city. Some light trails but nothing too dirty or wet. I did end up upgrading the wheels to Deore hubs/Mavic rims ($99 sale). Plus some slick tires, ended up being and excellent bike for intended use.
Mad bike riding scientist
Quoted: 6240 Post(s)
Liked 4,250 Times
I'd council against the NorthRock too. It's not a bad bike but, generally, if you can by a giant cheese wheel where you buy your bike, you probably should buy either one there.
Get thee to a bike shoppe! If you have to ask the question of 'which bike for me?', you probably should be buying your bike (or your cheese) at Costco. A bike shop provides you with more than just a bike. The bike you get is assembled by someone who may actually know what they are doing, rather than the kid that puts out the cheese wheels. They will help you with fit. They will tune the bike in a few hundred miles when everything settles in. You pay a little more but only a little and you get peace of mind.
You can buy a Specialized Hardrock (without disc brakes) for around $350. If you insist on having discs, you can buy a disc equipped bike for about $150 more. At this level, that's not a real good use of your money. You can also get a Trek 820 for about the same price. If you have a Jamis dealer near, you can get a Jamis Trail X1 for about the same price as the other bikes.
Stuart Black
Stuart Black
Good advice there from Cyccommute, with one qualification: You could, as he says, get the Specialized Hardrock and be fine, but if you want an entry level Trek the 820 is made of steel. For that $350 you can get an aluminum Trek 3500.
Liked 4,250 Times
The 3500 is $400 MSRP for a 2011. I suspect that you could find it for closer to $350 on sale but that's would vary from place to place. I suspect that you could find the Hardrock for close to $300 and the 820 for $250, too. But, again, that's dependent on many factors outside our control.
Stuart Black
Stuart Black
Thank you for your advice guys. I went to a LBS and they really did not have anything for me. The most affordable mountain bike they had was around 450 and that was for a bike with no front suspension and no disk brakes. The bikes with comparable specs to the Northrock XC6 cost around $600 in the LBS.
I found a 2010 Trek 3500 for around 360 online. I'd have to put it together myself though. If i bought an assembled Northrock Xc6 and take it to the LBS for a tune up and to make sure it was put together correctly. Would this be a decent option?
Regarding the Kawasaki dual suspension. I have ruled out buying this bike, however I was wondering if this bike is actually built by Kawasaki? I am guessing there is no way and it is probably just a brand name on some cheapo walmart bike.
Liked 4,250 Times
I would be dubious of any bike that is as inexpensive as the Northrock with disc brakes. Discs usually add about $100 to the price of a bike and if they are selling it for $300 they've made some cuts elsewhere. Discs at this level aren't much to write home about anyway.
Nope the Kawasaki isn't made by Kawasaki. Probably made in a Pacific bicycle factory in China.
Stuart Black
Stuart Black
I read a review on another site and it mentioned some of the specs for the xc6.
Aluminum "lightweight" frame
Shimano Altus shifters - 24 speeds for responsive performance shifting
SR suntour XCT V2 fork
Ninja 26x2.10 tires
Shimano crank
Tektro IO Disc brakes with shimano EF50 levers
KMC Chain
Acera rear derailleur
i will also take a look at the hardrock specialized. Will see if the LBS has it.
Ninja 26x2.10 tires
Shimano crank
KMC Chain
Went to another LBS shop and checked out a few bikes. The Hardrock Disk was around $520, which is a little steep for me. The cheapest mtb with disks that they had was $400.
I have seen the costco bike and I must say I was intrigued. It looks like pretty good stuff for $300. However, do an online fit calculator and figure on having to fix at least a few things. Sometimes stuff is backward on those things. I would want to go on parktool.com or sheldonbrown.com and make sure all the bearings were set correctly such as the hubs or headset. Improper adjustment can make them crap out quick.
The rear axle will probably crap out fairly soon if you use the bike a lot because it's a freewheel. However, since it's an 8 speed, you can upgrade to any standard modern cassette hub rear wheel, or you can just learn to change out an axle.
Do an online fit calculator to see if it's the right size for you.
It MIGHT fall apart. Who knows. But it looks OK.
Bikes: 2006 Trek Rail 2007 Diamondback Dellacruz 1.0 2009 Trek Lime 2009 Jamis Boss Cruiser 7 1980s Nishiki Road Bike 1993 Cannondale R700 (Criterium) 1993 Cannondale V1000 1995 Cannondale M1000 1996 Cannondale Killer V900 1996 Cannondale M900 CAD3 1997 Ca
Shop Craigslist and you can pick up a spectacular bike for that money.
Spetsnaz201, I take it that you don't have alot of bicycle experiance and because of that a value v. cost debate is a moot point. Go ahead and buy the NorthRock and welcome to the world of cycling.
Brad
Brad
Sophomoric Member
Sophomoric Member
Bikes: Many
Quoted: 7 Post(s)
To OP: have you thought about going with used model? You can get really good quality mountain bikes for a couple hundred bucks if you search some classified ads.
My LBS have these 3 models that fit my budget.
Trek 3700 Disk - $430
https://www.trekbikes.com/us/en/bikes...ies/3700_disc#
Norco Mountaneer Disk - $375
https://www.norco.com/bikes/mountain/...e/mountaineer/
GT Outpost Disk - $390
https://www.bikepedia.com/quickbike/B...Disc&Type=bike
Which one of these would you guys recommend? The LBS said that the GT Outpost is better than the Trek 3700 because it has 23 speeds compared to 21 for 3700. The Norco, which is from another LBS also has 21 speeds. I have basically narrowed it down to these 3. Would like some final input.
Liked 4,250 Times
Once a new rider has a little experience with with bicycles and a bit of mechanical knowledge, I'd say go nuts. But the mechanical section of this forum is littered with questions about bad second hand purchases by new riders. Ya ain't savin' any money if you have to buy the bike twice.
Stuart Black
Stuart Black
Liked 4,250 Times
Everything else is equal for the most part.
Stuart Black
Stuart Black
You can do some really nice riding on V-brakes too. The best attribute of disc brake IMO is the smooth power modulation, and I am not sure that entry level disc brakes are noticeably better than v-brakes in that regard. If I had the choice of getting better forks/shifters instead of getting entry level disc brakes, I'd pick the former every time.
If the wheel is 'disc ready', it's not hard to install the brakes yourself (I installed hydraulic disc brakes on my bike when I was complete novice going through a phase of upgradeitis).
Does your LBS carry Giant bikes. Usually Giant gives you pretty good value for your money. You should be able to get a Ravel 1 if you stretch your budget just slightly.
Lastly, the difference between these bikes in the same price range are almost negligible. So stick with one that feel the best, and if they all feel 'good', just pick the one with your favorite paint scheme (I am completely serious). It's more important to get a bike that makes you go 'DAMN that's a sweet looking bike' everyday than to get three extra gears that you most likely will not miss.
Liked 4,250 Times
Stuart Black
Stuart Black
I decided not to get either of those bikes. If I was to increase my budget to $500, would I be able to find a much better bike. I am looking at the following bikes.
Specialized Hardrock Disk
Giant Revel 1
Fuji Nevada 2.0
Jamis Trail X2
I assume that all of these are not freewheel. Is there one clearly better than the other?
Giant Revel 1
Fuji Nevada 2.0
Jamis Trail X2
Liked 4,250 Times
Giant Revel 1
Fuji Nevada 2.0
Jamis Trail X2
Giant Revel 1
Fuji Nevada 2.0
Jamis Trail X2
Stuart Black
Stuart Black
