Weird Giant?
Quoted: 10 Post(s)
Weird Giant?
I have an odd Giant bike that I am fixing up for my daughter. It is a short frame which I believe is a 48. It has a 700c rim on the back and a 24 inch on the front.
It was made this way and I can't seem to find any information about it. I had Giant check their serial number database and it doesn't seem to match anything they have.
I can't seem to attach a picture. I am new to this forum and maybe I am doing something wrong. Has anyone ever run across a bike like this?
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Nine more posts and you'll be able to post pictures.
There's no model name on the bike? Does it just say "Giant"?
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
Sounds like a Georgina Terry knockoff.
Maybe someone "rebadged" one
https://georgenaterry.com/refurbishi...-road-bicycle/
SE Wis
Liked 3,395 Times
SE Wis
Liked 3,395 Times
Quoted: 18415 Post(s)
Liked 15,542 Times
I dated a girl who was 4' 10". She wanted a new road bike but was having trouble finding something in her size. Went to a LBS that always seemed to have that odd thing that I was looking for. Owner went into the basement and brought up a Shogun frame with a 24" front wheel. Built her a nifty little ride that fit her from the frame up.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Found this.
Quoted: 10 Post(s)
It appears to be exactly like the picture except it does not have the dropped handlebars. Pretty sure it's a Giant.
Seems to have factory paint and lettering but it has some age on it.
Wish I could post a picture.
SE Wis
Liked 3,395 Times
Likes For dedhed:
Liked 2,446 Times
^ Not my bike and not my photo. I'd have done better, I hope. And my garage door is brown...and mossy green.
That's OK, you can always borrow a white garage door when you post your pic. The Rules(tm) are codified somewhere, and they included the white door requirement.
Quoted: 10 Post(s)
This forum is frustrating for a new user. I guess you have to post a while in order to be able to attach a picture.
Also someone sent me a private message but the site won't let me read it as a new member.
Quoted: 10 Post(s)
If this bike has any value as a collectible we may be interested in selling it. Seems the bike is made for a short person. Someone around 5 foot tall.
Liked 15,542 Times
It's to protect against spammers, etc. 10 posts will allow you to post photos.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
The front wheel isn't a 24", it's an ISO 520mm rim. It's a kind of odd size and can be a bit difficult to find. Bike shops aren't going to carry them because there is so little demand. They will have to order them and QBP (the largest parts wholesaler) doesn't carry them. J&B Importers currently does.
Stuart Black
Stuart Black
Quoted: 1572 Post(s)
Liked 643 Times
The issue is "toe clip overlap".
You can't just shrink a big bicycle to make a small frame bicycle. You run into issues like wheel sizes and pedal to ground clearance. As you shorten the top tube to make a bike fit a shorter rider, eventually you will encounter toe to front wheel interference. Most of the time that's not an issue but, maneuvering through the parking lot after a long tiring ride is when you will most likely first discover the issue. Small frame bikes that have smaller front wheels can save you from an embarrassing fall.
When I had my shop I carried a few Terry bikes. I never had a short woman test ride one who didn't buy it.
Quoted: 10 Post(s)
It's probably not that collectable. Even Terrys don't have that much value and they are of better quality. The bikes are good at what they are designed to do which is to fit small people...particularly small women. The design idea is solid if a little strange looking.
This one is actually a 24" rim. It looks newer than the back rim so it was probably replaced at some point.
Liked 4,218 Times
There is no "actual 24" rim" because there are several different 24" rims and tires...and a lot of confusion about tire size. There's a 507mm rim which you find on child's mountain bikes, a 520mm rim which is the one that Terry uses, a 540mm rim which is also known as an E-5 for British children's bikes and wheel chairs, and a 547 which is also known as a S-5 and is an old Schwinn designation for juvenile lightweight bikes. Look at the tire for the size. While it may have been replaced, I doubt that it could have been replaced with anything other than a 520 since that is the only rim that will match up with the brakes and fit in the fork.
Stuart Black
Stuart Black
Quoted: 10 Post(s)
There is no "actually 24" rim" because there are several different 24" rims and tires...and a lot of confusion about tire size. There's a 507mm rim which you find on child's mountain bikes, a 520mm rim which is the one that Terry uses, a 540mm rim which is also known as an E-5 for British children's bikes and wheel chairs, and a 547 which is also known as a S-5 and is an old Schwinn designation for juvenile lightweight bikes. Look at the tire for the size. While it may have been replaced, I doubt that it could have been replaced with anything other than a 520 since that is the only rim that will match up with the brakes and fit in the fork.
Just going by what is stamped on the rim, 24 x 1 1/8 Not sure about the tire size. You might be right.
What cyccommute is trying to impress on you is that the rim itself isn't 24". With a 28mm tire mounted the wheel will measure something like 22.75" in diameter. A technicality, but it may be an important one in some cases. When buying tires, always go by the ISO number for the diameter. as there are 3 different 24" sizes, each incompatible with the other.
SE Wis
Liked 3,395 Times
Liked 4,218 Times
Minor quibble 1: I'm trying to impress on Billbob5757 that not all 24" wheels are the same. Look at the tire and see what it says.
Minor quibble 2: Four different 24" sizes.
Minor quibble 2: It's not a "technicality". Each tire that is called a "24 inch tire" will not fit on the same rim.
Stuart Black
Stuart Black
