Weekend functional art project, copper basket/rack
I couldn't find a good front rack that didn't get in the way of my dynamo-powered headlight (connecting to the upper fork and handlebars instead of to the fender bracket), so I made one from leftover copper pipe and fittings. It's strong, fairly lightweight and would probably have cost $40-$50 if I didn't already have most of the copper.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,445 Times
Neat. I borrowed a hedge trimmer from a pal several years ago and he apologized for the broken loop handle that was supposed to go over the top of the unit so I whipped one up from 1/2" copper. Made it much easier to use and impressed the hell out of him when I returned it.
Likes For thumpism:
Bikes: Indeed!
Quoted: 1504 Post(s)
Liked 3,444 Times
Very nice!
Next you'll have to take up wicker work so you can make a basket to fit in that frame.
Brent
Brent
Likes For obrentharris:
Likes For PDXCarless:
Quoted: 7287 Post(s)
Liked 2,365 Times
Very nice! What made you decide to use copper? And do you know what it weighs?
Basically, I keep everything in my garage and try not to throw anything away. When I need so buy something, I first walk around in there and think of ways to build it. We, our society, buy and waste too much s**t.
I figure it weighs roughly the same as the typical front racks and baskets I see on amazon that are made out of solid aluminum. Copper isn't that heavy and these are hollow pipes, after all. I'd guess 4-5 lbs, altogether.
I still have a little work to do. The fork screws need to be changed out for stainless ones so there's no galvanic corrosion between the copper and the steel. Also, I need to put tape between the copper and the aluminum fork for the same reasons. The bailing wire that I mentioned will also have to be stainless.
Liked 2,445 Times
WALSTIB
Hot and cold running water would be nice on a bike ride. Interesting very interesting
Likes For hillyman:
Advocatus Diaboli
Quoted: 4717 Post(s)
Liked 1,526 Times
You should hunt this guy down to work on getting your bike to match:
https://www.bikeforums.net/road-cycl...rbea-orca.html
Quoted: 1088 Post(s)
Liked 1,204 Times
Nice work -- it would have matched my old copper-plated Bergmeister!
That's really nifty. Necessity is the mother of invention. But the title of the thread says "basket" and there is no bottom to it and items would fall through. Are you going to put a mesh bottom on it or something similar?
Likes For Flip Flop Rider:
Quoted: 5220 Post(s)
Liked 3,564 Times
Likes For rumrunn6:
rebmeM roineS
Quoted: 653 Post(s)
Liked 345 Times
All that nicely-sweated copper pipe and no valves?
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
Now someone's going to steal your bike for the copper scrap.
Likes For rollagain:
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 834 Post(s)
Liked 332 Times
When I progressed down that route years ago I ran into a poor balance between weight and rigidity. The plumbing pipes are optimized for different purpose. Thinking harder, stainless steel can be soldered nearly as easily as copper, but sleeves for joints may be harder to get. Thinking further, while the soldered sleeve joints provide flexibility for a home brewer they will be adding weight over welds as a matter of principle.
