Shimano Center Lock Rotor Tool?
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
I have a 2017 Roubaix with disc brakes, and would like to know what tool I need to remove the rotors. They are center lock, not the six-bolt kind. Can someone point me to the right tool?
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
You need either a standard Shimano cassette tool, or a 16-notch BB tool.... the axle size determines which lockring you use.
Liked 406 Times
Are you needing a replacement?
The lockring is either internally splined along the inside circumference, in which case you use a Shimano cassette lockring tool....or the lockring is externally notched on the external circumference, in which case you use a 16-noth BB tool,
You should only need to use the external-notch lockrings on hubs with a 15mm axle diameter or bigger.
https://www.parktool.com/blog/repair-...d-installation
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Quoted: 646 Post(s)
Liked 289 Times
Disc Rotor Installation and Truing | Park Tool
Thanks!
Hi! Does anyone own the TL-LR10 tool? I'm asking because I'm looking for a single tool to do my rotor lock rings as well as the cassettes. I believe it will work for my front rotor and rear cassette, but the big question is: Will it slip over my 142x12mm rear thru axle for tightening the rear rotor center lock. Currently, my bike has a 16 spline lock ring on the front, and an external spline lock ring on the rear. The goal is to get them all the same so i can carry just one tool for touring. Thanks!
stockae92
Mountain Biking
2
07-14-15 07:23 AM
TheNeed4Speed
Bicycle Mechanics
4
07-13-14 04:51 PM
