Subcompact Doubles v Triples
Hey Chris, forgot to ask, but what crankset do you own that is 44/34/24 ?
that is not a usual standard stock set of chainrings.
I'd be curious to see a photo of it.
square taper?
outboard bearings?
square taper?
outboard bearings?
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I also have a 3 ring 104/64 spider for a Carmina (square taper), a riv silver double that could be triple (external), and an older XT triple (external), I have crankset flexibility it's just a matter of choosing the right one. If it was just over Brenner pass or something like that I'd just run a mountain double in like 34/22 but it's the lead up to the mountains that makes me think about these things. On that bike I'm happiest with a 36 ring but I have a feeling that running through Frankonia I'm going to want something larger if I do I could pull the VBC off one of my other bikes and pick up a 24 inner ring and say run a 40/24 or do much the same thing with a Carmina.
This whole thread is just me thinking out loud
Likes For Germany_chris:
It's a Sugino AT that I have a couple sets of rings for, right now it's 46/36/26.
My triple on my Troll is an older XT, external--light, and even though I bought the bike used and completely dismantled it to the frame and then reinstalled the XT hollowtech 2 , first time I had ever worked with external bearings--I have never had to touch the bb since then, and the bike must have 10,000kms on it, a reasonable percentage of this loaded up.
So in other words, I have a great opinion of the crankset 44/32/22 and the hollowtech 2 bb.
I would also add that I use friction shifting for the front derailleur, and so find shifting between front rings to be smooth, fast, quiet, and really nice all in all. I use those Gevenalle shifters, on the hoods.
Ive spent weeks and months on that bike and have never gotten sick of the shifting , nor when loaded found the 44/32 thing to be an issue or annoying with too much shifting back and forth.
To be frank, if your bike is already 39lbs and then you have to add. your gear, it seems to me that this is exactly where a triple is so nice--and to repeat myself, especially in mountains.
have fun deciding, and no matter your choice, it will be a fun trip, so enjoy.
Likes For djb:
If so, thats quite light
add on a few lbs for a crankset, water, food etc, but still light.
Quoted: 3462 Post(s)
Liked 1,469 Times
I assume that weight is the bike, racks and empty bags.
sorry chris, you did say at the beginning that you would be carrying about 50lbs of gear, so that's all clear.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I have not..I'm going to measure the chain line tonight and see what the difference is between the three triples I have. I know this isn't rocket surgery but I'd like to get this buttoned up in the next few weeks so I can get some miles on the bike again.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
Which will put the bike at ~90 pounds which is about what the KM weighed last summer. Since that ride was flat I just ran a 32 w/11-36 and everything was fine I'm probably putting more though into this than I need to.
When I've carried more in mountains, I had the forementioned triple and a low of just under 17 g.i., but you hopefully will know what low you would be happier having.
I'm very much in the camp of preferring a low low, and if I hardly ever use it, that's fine, I just shift up.
Speaking for myself though, I use my low gear often enough that it is worth having, even when touring with less stuff.
And one can always slap on a tighter cassette if you want for tighter shifts, which is nice too.
Again, have fun building and planning
Liked 1,469 Times
My titanium touring bike with racks front and rear but no panniers is roughly 35 pounds, would be about 43 pounds with empty Ortliebs front and rear. Your 39 pounds is quite respectable. My touring weight tires and wheels push up the weight some, as does the Brooks Conquest. I have some lighter panniers but my next trip will probably be with the Ortliebs.
My lowest gear on this bike is a 24T front and 32T rear, for 20.7 gear inches, or about 1.65 meters of development.
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
I got thisYBB weight : 29.2 lb
Harness with sleeping bag and tent: 9.75
Pocket: 1.9
Seat bag: 5.25
Gas tank: 0.75
Frame bar: 4.4
Camelbak w/o water: 7.5
Total: 56.9
W/100 oz water: 6.25
Total: 63.2
That’s the total weight of bike, bags, food, cooking gear, etc.
Configuration and weight can change a bit depending on the trip length but not by too much. I carry a bit more food is all and, for the most part, that food is freeze-dry for my off-road touring.
For my road touring bike, I don’t have exact weights of the whole kit but the bike is 28.3 with racks. I do carry food with more weight…I’ll exist on freeze-dry for up to 5 days but not much longer than that…and I carry more elaborate cooking gear. Maybe 45 lb instead of 35 lb.
Stuart Black
Stuart Black
Likes For cyccommute:
I would put some effort into reducing your gear weight along with thinking about gearing as both are important when climbing hills.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
This ride could easily be a credit card tour but the "man card" seems to be on the line for some reason so we'll camp and ride heavy bikes.
No matter how this plays out Lake Garda in August is great and bike rides are great so I'll "let it go" and prepare for the unexpected
Quoted: 970 Post(s)
Liked 1,632 Times
WOW... DOUBLE WOW... That's a real accomplishment.
I am not a Touring Bike guy, but I have done quite a bit of multi day summer West Texas hiking. I don't think I have ever gotten my gear less than 35 pounds and that's not including water.
Back in the day (US Army SETAF) our little excursions would easily have me with 70+ pounds on my back before my fighting load... Ha
Liked 1,469 Times
The frame is lighter than the weight of my rear wheel with tire, so just because the frame is a few pounds lighter does not mean the whole bike will be that much lighter. I will be the first to admit that a titanium touring bike is pure bling, as spending a lot on a frame to trim a few pounds is not cost effective. I got a great price on the frame, so could not pass it up. At that time Lynskey wanted an extra $300 for the front fork, but the rake and axle to crown length almost perfectly matched a LHT front fork I already owned, I used the LHT steel fork. Thus, rim brake front and disc rear.
Photo is lighter weight, as the racks were not on it at the time. But I have the heavier touring 37mm wide tires fitted. Dyad rims.
Yes, the lake was frozen at the time of photo, that was a year ago in mid March.
Likes For Tourist in MSN:
Liked 4,222 Times
The cited weight was with a Racktime Addit rear rack, Tubus Tara front rack.
My Cannondale T1’s weight is with a Tubus Tara and a Tubus Cargo with a steel fork. And I haven’t gone particularly lightweight on components nor wheels.
Not saying you are wrong, just that I find the extra 10 hard to square when compared to a mountain bike.
Stuart Black
Stuart Black
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
So I was weak when I couldn't find some bits to make my road barcons to finish the install, I bought enough Tagra 4703 bits to make everything work.
A bit late to the party but no matter.
I've gone from Vienna to lake Garda so not sure how much overlap of routes there's going to be. But with lots of weight I feel you really can't go too low with gearing. I think I had a 11-34 cassette with a 22-24-44 crankset and would not have frowned at a 11-36 on some of the steeper climbs.
As for not needing the high end of the triple, I feel that coasting forever if boring. Also spinning out on tailwinds sucks. With a 44 big ring that doesn't really happen.
I've tried a wide double for touring and frankly I did not like it. The large jump between big and small chainring is jarring and I felt like I was constantly cross chaining trying to find a proper gear. My road bike has a wide double but with no luggage it doesn't really matter all that much.
My experience is similar, and while shifting up a few gears when going down to the smaller ring is fairly easy and doesnt bug me, if you have to do it often, it can be annoying a bit.
The point about this being more of an issue with a loaded bike is important, so do keep this in mind chris in germany. Maybe for you its not an issue, and also doubles probably dont have that "cross-chainng" feel to them like a triple does, so I guess see how it feels in real life.
personally, I find when riding loaded, a 40t ring is a bit big, but then thats me and also more modern drivetrains handle everything better , crosschaining etc, so I guess you can just set the bike up with the tiagra shifters and see how it is when riding with all the stuff you plan to take.
I still like my Sugino triple with an 11-34 nine speed cassette. I haven’t ridden in the Alps, but I have ridden across all the major mountain ranges in the United States and I don’t think fifty pounds of baggage is too much. Barcons are alright, but I am an old guy and I still prefer friction down tube shifters with drop bars.
Liked 1,469 Times
On the big jumps between chainrings, I think a lot of front derailleurs are designed for a 16T change for doubles. The compact double of 50/34 is quite common, I have that on my road bike. And we are seeing more bikes with a 46/30 crankset, which also is 16T.
When I built up my LHT in 2004, I used a road triple (52/42/30), but swapped out the 30T for a 24 before I even installed it so the 30T chainring is still pristene in storage somewhere. So, my shift to the granny gear was a change of 18T, which was big, but I did not use the granny gear that much and therefore do not notice it that much. And this was on an eight speed cassette, so only a couple shifts in back countered that big change in front.
A decade later, decided to swap out the 52 big ring for a 46 on my LHT, thus had a half step with granny triple (46/42/24), thus still have the big step of 18T from middle ring to granny in front. I am not suggesting everyone else should use a half step plus granny gearset, it is an acquired taste. I think I got my first half step bike in the late 70s or early 80s, that bike had a five sprocket freewheel, I got used to the benefits of half step at that time. I liked that enough that when I built up another derailleur touring bike, I used the same gearing. And later when I finally got rid of the LHT frame, I put that same drive train on the frame that replaced it, a Lynskey Backroad.
When I ride my road bike with a ten speed cassette and the compact double with a 16T jump, I certainly notice when I shift the front, as I am having to make about three shifts in back to counter that big change But when you have so many sprockets in back, I think you need to expect something like that, it is less noticeable with cassettes with fewer sprockets.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
So I bought a Tiagra Triple
I’ve had the group for a couple of months but I couldn’t find a rear brake that would work. I tried Paul Mini Moto’s then Paul Touring Canti’s none would work. In a bit of frustration I bought some Rene Herse canti’s they work sorta.
I’m not sure I want a bike that has in essence a drag brake in the rear and a powerful brake in the front to ride a lightish touring bike even if I like it. In the end it stops and goes but….
Quoted: 1034 Post(s)
Liked 1,292 Times
So it looks like the Franken >Lake Garda tour is going to happen this summer barring any unforeseen circumstances.
I'm not inclined to take my Cross Check since it's going to require more weight than that bike can handle without becoming too flexy so I've drug out my Rock 'n Road frame. My parts bin is fairly deep so I can build how I like which leads to my question...
If you were going to build a bike to cross the Alps with say 50ish pound of gear would you build on a mountain triple 44/34/24/6 or go with a 44/28 double, if I go triple I'm going to use barcons and 11-36 10 speed if I go compact double I'll probably go 11-42 11 speed double tap. In day to day use I don't use that big of a cassette because it's not needed and has some holes in the cassette stack that make me uncomfortable, but on a ride like this I can deal I think.
I don't love barcons though I have no issue using them but If I had my druthers I choose integrated shifters, the flip side is my brake levers are long pull so I'll be able to use full length linear pulls v mini's since this bike is going to be built around 32mm tires I'm not sure that will make a difference but it exists.
When push comes to shove I'll be able to ride the route with either setup and since I own all the parts cost isn't a consideration. I'm leaning triple since i'll have a closer spaced ratio but I don't know if that's a benefit over a change of hand position to make it work.
So would you choose traditional or modernish for my ~600k est. 10 day trip?
I also would not like the 44T personally. I spend most of my time in the middle ring on my triple, which I believe is a 38T. For a compact double, if I could get the low ring of 24T, I would probably want a 40T.
Liked 4,222 Times
Well, that’s confusing since you show a Sugino crank in your pictures.
A couple of things I see wrong with your current cable routing. First you really should use the cable anchor point on the frame if you have one. See the red arrow below. It’s much more stable. Your current anchor (red x) is short which makes for a longer cable run outside the housing which can be more flexible.
The Surly hanger on my bike below is much longer which allows for a longer run of the cable housing as well as a straighter run. My bike doesn’t have the cable anchor on the frame but I don’t have any issues with the rear brake being highly effective everywhere I ride.
You might also want to consider replacing the hanger as well. The Paul’s Moon Unit is nice and wide which makes for better leverage of the cable on the straddle cable. Additionally, shorten up your straddle cable significantly. A long straddle cable makes for mushy brakes in my experience. Combine that with the hanger and your brakes are going to be rather ineffective.
Stuart Black
Stuart Black
