ISO Stronglight 48T #12 (star pattern, outer) chainring
Quoted: 3814 Post(s)
Liked 3,345 Times
search tip: they made these both for hex head c/w bolts and for allen key c/w bolts. the set in your link is hex head. iirc the changeover from hex head to allen was ~1973. if you have an existing inner you plan to use make sure its bolt holes will be compatible with the outer you purchase.
Quoted: 765 Post(s)
Liked 660 Times
Either way, if one had the old-style ring it should be possible to have a machine shop modify it to accept the larger allen-head bolts, yes? Though obviously not the other way around.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Liked 3,345 Times
yes and yes.
