Stuck Cassette
Stuck Cassette
I have a 10 cog cassette on my Record Triple, and tried removing it using the Park FR-11. It was skipping, and would not budge the cassette lock ring. I noticed that the same tool made by Campy had longer teeth, or it seemed to me, so I ordered that. It skips also. I've never had this problem with a cassette or freewheel, although my experience is limited. I would rather not take apart the hub/axle. Is there hope?? Pictures to follow. Thank you.
Expired Member
Quoted: 3788 Post(s)
Liked 5,781 Times
The lock ring looks buggered. You can use a drift or flat blade screwdriver and beat it off.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
There have been cases where I am in too much of a hurry to put the QR in to help keep the tool in place, and the removal tool seems to slip, but it's really just losing engagement as it twists.
Give it another try with the QR skewer in, and see if that helps. The lockring splines DO look a little chewed up.
I forgot to add that I put the QR in on the Park one, but not the Campy one. I will give that a go, although I am thinking I may be doing what shelbyv suggests. Thanks.
Quoted: 6348 Post(s)
Liked 4,948 Times
But you'll need more hands or some fixture to lock it in place.
Last edited by Iride01; 07-14-21 at 02:24 PM. Reason: OP added more info while I was pondering my answer! <grin>
Expired Member
Liked 5,781 Times
Maybe lay the wheel on the floor, wrap the chain whip and hold the handle with a foot or knee while you whack on the lock ring.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Put the lockring tool in a vice that's firmly attached to a work bench. Set the wheel down on the tool, wrap your fingers around the handle of the chainwhip and a spoke or 2 and turn it counter clockwise as you're looking down on it. Skewer if needed to hold the tool in the lockring.
I did that cx. I ramped down the QR, clamped the tool in the vice, and the same skipping of the lockring. I think violence is the only answer. I only want to take it off because I wanted to throughly degrease it. I just did that with it on. I will wait until it needs to be changed, then get to it. That thing must really be on there. Thank you for the replies.
Really Old Senior Member
BBT-5 / FR-11: 12 splines, 22.8mm diameter. Fits all Campagnolo® cassette lockrings (including 11-speed) and splined, 12-tooth Campagnolo®
bottom bracket cups.
FR-5.2G: 12 splines, 23.5mm diameter. Fits Shimano®, SRAM® (including 1x), SunRace®, Sun Tour®, Chris King® and other cassette lockrings.
Also fits some disc brake lockrings with 12 internal splines. Guide pin stabilizes tool.
Maybe the FR-5 will fit?
I'm not familiar with Campy stuff, but the "CS" on the lock ring kind of raises a red flag to me since my Shimano cassettes have CS in the model.
Thanks, Bill. I have a FR5.2 that doesn’t fit, and for the FR5.2GT, I would have to take the axle out. And still not know if it will fit. I have in my brain that Campy has sealed bearings, and opening them up might not be a good thing. At least, I have never messed with Campy bearings. Appreciate it.
Sounds like it's going to be a destructive removal eventually, but maybe you can salvage?
Likes For Bill Kapaun:
