grease packer for bicycle bearings
Hi,
I am wondering if there is small grease packer available for the typical bicycle 680x 690x bearing size ?
Any advise.
Thanks.
Any advise.
Thanks.
Clark W. Griswold
Quoted: 4350 Post(s)
Liked 3,989 Times
Beyond that I am unsure what you would need? If you are worried about getting your fingers greasy, you can wear gloves or use some Phil Wood Hand Cleaner when you are finished.
Non omnino gravis
Likes For DrIsotope:
I've never seen one and I've worked in some relatively high production shops, though they might exist. In a commercial setting, most cartridge bearings aren't cleaned because the cost quickly becomes eclipsed by the shop's labor rate and it makes more sense to just replace them when worn. I do clean them out occasionally (particularly if there are time constraints in sourcing parts, or sometimes with things like Chris King bearings) and mostly just remove as many seals as possible, hit them with some Finish Line Speed Degreaser (hexane, in a pressurized can) and spray them with a compressor, all while spinning the bearing. This does a pretty good job of cleaning them out--it's not particularly hard to get adequate grease fill using a grease gun, or a finger for that matter.
Quoted: 1324 Post(s)
Liked 927 Times
I use a big syringe made for basting meat. I cut the metal end off square.
Cheers
Cheers
I have used a medical syringe in place of a grease gun. Get one with a not too wide plunger to make it easy to depress it. Work well for injecting grease between the balls with minimal excess mess. Im sure a veterinarian style syringe would work fine too (its the type that is in bleed kits for hydro brakes). All sorts out there, just google it.
Or simply get a small grease gun.
There are a lot of automobile bearing grease packer. Example like this below;
https://www.amazon.com/Lisle-34550-H.../dp/B0002NYDYO
However, they seems too big for the type of bearing that we uses for bicycles. I am currently using medical syringe. Hence, looking for possible other options.
I am quite happy with the syringe method.
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 184 Post(s)
Liked 204 Times
Last new bike 1991
Last new bike 1991
Quoted: 4201 Post(s)
Liked 3,857 Times
Shades of Stein grease injectors. While not for the cartridge bearings noted Stein has freewheel/freehub grease injector devices as well as has made a BB sealed and injectable system using Zerk fittings. Andy
AndrewRStewart
AndrewRStewart
Quoted: 2026 Post(s)
Liked 1,096 Times
Quoted: 241 Post(s)
Liked 232 Times
Quoted: 1438 Post(s)
Liked 1,092 Times
Many of those bearing packers will waste several times as much grease as is installed into the bearings. Just use an injector-type gun or your fingers. No matter how fully you pack the bearings, as soon as they start turning they will push much of the grease to the side anyway.
The Grease Guard system depended on having a needle tip grease gun , the finish line type, above, can do ..
Likes For FiftySix:
On Tuesday I bought a used Campagnolo Scirocco rear wheel for $45. The rim was fine, but the bearings were slightly crunchy. So what the hell, I decided to dedicate 15 minutes to making things better. The application of a hammer and large screwdriver led to the satisfying ricochet sound of the old 6001 bearings shooting across the workshop floor.
The new $5 fleabay-derived cart bearings were pressed in place using a threaded rod, and some nuts and washers. The freehub was cleaned out an regreased. Fortunately, the two 6803 carts in the freehub were still smooth. But in the past, I've replaced these as well.
Just to be sure, I pulled one of the rubber seals off of each 60012RS carts. The grease was somewhat skimpy so I used my advanced grease installation tool (fingers) and packed them tight with auto bearing grease that cost $5 for a one-pound tub.
So everything went back together smoothly, and 120 miles of test riding later, I am very satisfied with my new wheel.
Quoted: 6963 Post(s)
Liked 10,961 Times
Quoted: 303 Post(s)
Liked 136 Times
Open bearings filled with the palm method pictured rapidly get rid of any excess grease. Sealed bearings, with seals removed and
repacked by any method tend to get over filled and with the seal replaced remain so. This increases bearing friction from the viscosity. Bearing
manufacturers have charts suggesting how much fill is best for function, IIRC above 60% is not a good idea, though most of us would never
become aware of the increased resistance from overfill which might suck a few watts.
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
Although, it does remind me of installing some of the first sealed and shielded bearings coming over from China 20 years ago that didn't have any grease in them. With those, I did pop the seals to add grease until I could find better bearings made in the USA or Europe. Considering some of the old machines I was working on from Czechoslovakia back then had bearings marked with CCCP on the shields meant the Chinese bearings were likely near the same grade, though.
BTW, one good thing with the palm method is one is in control of their own hands and can adjust the grease fill capacity as one sees fit.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
For the assembly line at Trek, we had bulk bearing greasers for bottom bracket and headset bearing retainers. The retainers were slipped over a steel rod, a pipe fitted over the retainers and rod, threaded fittings plugged both ends of the pipe, and grease was pumped into the pipe via a Zerk fitting. Once greased, the rod with all the retainers was positioned by the appropriate assembly station, and the assembler just picked nicely greased retainers off the rod.
