tire question
Bikes: custom
tire question
guys i have 700x23c 622X23 tire is it 26" or 29 er? i am buying https://www.bikebagshop.com/extrawhee...rk-p-1383.html and can not specify which size to choose ( they have 3 sizes 26", 29er and some extrawide)
and also what are 622X23 number? i serched for it and some say its size of rim and some say its same 700X23 but French version ...plz help i know these questions have been asked million times...jst want to be sure...sometimes to search Internet is confusing
Fresh Garbage
700c is a nominal wheel size that has a bead seat diameter of 622mm. 29er wheels are the mountain bike adaptation of 700c, so you have a large tire that effectively increases the wheel diameter.
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times
https://sheldonbrown.com/tire-sizing.html
In general: The size called '700C' (700X 23c, 700 X 28c, etc) has a bead seat diameter (BSD) of 622mm. 700c is the standard size for most road, touring, and hybrid bike wheels. The same size rim - 622mm BSD - is used on modern mountain bikes but is called '29 inch' or '29er.' I believe the name was changed so people wouldn't confuse rugged mountain bike parts with skinny feeble road bike parts.
In general, any 29er tire will fit on any 700c rim, and any 700c tire will fit on any 29er rim. The only thing to watch out for is vastly different widths... you don't want your rim to be any wider than your tire (as can happen if you try to put a narrow 700X23c tire on a 25mm wide 29er rim), and it is not desireable to have your tire many times wider than your rim (like putting a 3" wide tire on a 14mm wide road racing rim).
Also, if you have a bike designed around narrow tires you will likely not be able to fit very wide tires into the frame and fork.
Bikes: custom
Bikes: custom
one last question....i know i sound noob...for sure i am..but dont know width of my rear wheel...i am buying https://www.biketrailershop.com/extra...se-p-1378.html and have probles choosing width...i am planing to put this cassette https://www.amazon.com/gp/product/B00...A16QDZ1XG7GVFM
Lover of Old Chrome Moly
Quoted: 143 Post(s)
Liked 23 Times
26" and 700c are completely different. 29er is a marketing term for wide 700c rims and as stated above, 700c rims have a bead seat diameter of 622mm. The rim width is often listed on the rim lable along with the bead seat diameter. Sheldon Brown's chart is what I go by.
Bikes: custom
