Is Campy 9-speed rear derailer compatible with 8-speed system?
Quoted: 128 Post(s)
Liked 12 Times
I'm wondering if 9-speed Campy rear derailers can be used with 8-speed Campy indexed systems, or does 9-speed have a different cable pull? I Googled for a bit and was surprised that I couldn't find this. (For comparison and to illustrate what I mean, Shimano 9-speed rear derailers can be used on a Shimano 8-speed drivetrain, excluding Dura-Ace which had a different cable-pull ratio for 7 and 8 speed, then went to normal Shimano starting with 9-speed).
A friend recently broke his Campy 8-speed rear derailer and needs to replace it. The tab which holds the b-screw (or whatever it's called in Campy world) snapped off, which is a weird failure. His chain was frozen and he was backpedaling trying to free it up. It's hard for me to imagine how that would snap the b-screw holder. My friend is strong but is decently mechanical.
But I'm mainly interested in whether a 9-speed Campy RD would work as replacement, or does he have to find an 8-speed. If my friend can use a 9-speed Campy RD, that opens his buying choices a bit.
Quoted: 128 Post(s)
Liked 12 Times
I'm surprised no one knows the answer to this, despite over 50 views of this post. I realize not that many people have come in contact with this issue, but it's a simple informational question:
"Will a 9-speed Campy rear derailer index properly with 8-speed Campy shifters and cassette?" Campy 8-speed, esp Ergopower, may not have been around for that long, either. But I figured someone here would know.
Quoted: 1819 Post(s)
Liked 1,695 Times
There were 2 generations of Campagnolo 9 speed derailleurs. The first generation had a B screw like the 8 speed versions and would probably work just fine. The second generation relied on a different method to adjust derailleur tension similar to 10 speed derailleurs. If you can find a 9 speed derailleur with a Shimano style B screw adjuster, it will probably work just fine
Quoted: 128 Post(s)
Liked 12 Times
Bikes: Peugeot Mont Blanc . Bianchi 28c 1980. Coppi Giro di Lombardia. Vitoria Vintage 1990. Orbea Luarca 1977. Trek 950.
Quoted: 51 Post(s)
Liked 12 Times
Maybe this would help.
Art's Cyclery Blog » Science Behind the Magic | Drivetrain Compatibility
Liked 1,695 Times
Thanks for responding. Do you know if the later type, without a Shimano-style b-screw, required a different style derailer hanger, or had a different cable-pull ratio? (I doubt Campy shifted the Cable pull halfway through 9-speed, but the different adjustment mechanism replacing the b-screw could be an issue for pairing with 8-speed drivetrains).
Quoted: 128 Post(s)
Liked 12 Times
Art's Cyclery Blog » Science Behind the Magic Drivetrain Compatibility
Probably
"speeds" is not in the RD itself, it just moves inward with cable pulling it..
across the gear-cog cluster.
compare parallelogram pivot to pivot distance...
& inward motion, for a given cable pull amount..
Quoted: 128 Post(s)
Liked 12 Times
Exactly. This is why I am asking about cable-pull geometry. The link shared by MarcoBiancho covers these differences and gives precise measurements.
I'd just try it. I'm a mechanic, not a computer code writer .. posting from work.
IDK why this forum always wants others to do things for them...
Quoted: 1608 Post(s)
Liked 2,216 Times
@TallRider - I can understand the issue. I have been converting my 740x drive train to Campy. One of the challenges is that the 8V DA cassette has a different spacing than the Campagnolo equivalent. I found a Wheels Mfg spacer kit (discontinued) for the DA cassette to space the DA cassette block to match the Campagnolo spacing.
P1010339, on Flickr
Next was a 9V Campy RD using 8V ergo's. Works like a charm. My first experience with Ergos or "Brifters." I love riding that bike so much more with the ease of shifting now.
P1010333, on Flickr
P1010552, on Flickr
P1010339, on Flickr
P1010333, on Flickr
P1010552, on Flickr
Quoted: 128 Post(s)
Liked 12 Times
I started this thread because I'm advising my friend on whether to buy a used 8-speed campy derailleur on eBay vs a new 9-speed, to replace a broken derailleur on his 8-speed drivetrain. Turns out the available new nine speeds are the new, slightly different cable pull ratio, which'll index fairly well but get worse toward the edges of the cassette. So, I got my answer while ago in this thread. Only needed one bump to start getting answers.
Lewis_Moon
Road Cycling
7
09-10-12 07:55 AM
boatsinbottles
Classic & Vintage
18
02-06-12 05:09 AM
