Best way to carry a computer tower
Socrates Johnson
I have a bike with a tubus front low rider rack, and old man mountain rear rack.
I'm not sure the best way to carry a computer are. The two options I can think of are:
1). Put it on my rear rack vertically, and strap it down really tight.
2). Create some wide platform to sit on top of the rear rack, strap that down good, then strap the tower on top of that.
When i tried just strapping the tower down with it on it's side, it slid around way too much. That was using velcro, rope and bungy cords.
I like option 2 the best (if it's possible/easy enough to do), but I'm not sure the best way to go about doing it.
Any other options or ideas?
Plays in traffic
Bikes: 1996 Litespeed Classic, 2006 Trek Portland, 2013 Ribble Winter/Audax, 2016 Giant Talon 4
Quoted: 76 Post(s)
Liked 14 Times
LAN party, eh?
I know a guy who straps his mid-tower to a backpack frame. He built the display into the side of his case, FWIW.
If I were ever so inclined, I think I'd just pad my rack and strap it down with those ratcheting nylon straps. It's not the sort of thing I'd trust to bungees.
Then again, I prefer to move data, not devices. To each their own.
Socrates Johnson
LAN party, eh?
I need to bring a "spare parts pc" to go and fix my parent's computer (and possibly give them one of my old ones if their's toast)
Velocommuter Commando
Quoted: 659 Post(s)
Liked 7 Times
I'd be inclined to use the method of carrying it on its side, but first put some high-friction material on the rack so the computer won't slide around. Wrap the rack top with some old innertubes or put down a rubber mat, then put the computer on top, and finally strap it down good and tight. Bungee cords would probably work if you're careful that they're really tight and can't slip, but the ratcheting nylon straps would be more secure.
Trailer Nut
Bikes: Viking Urban Trail. Schwinn Spoiler
Wrap it in a BIG bath towel then strap it securly to your rack, that should stop it sliding around.
Regards
Tom
Regards
Tom
Quoted: 19 Post(s)
Liked 7 Times
When I carry over-sized loads on my Blackburn rack, I wire on some wooden slats or plank to make the platform larger, esp wider. I have carried heavy bags of plaster with no problems.
Bikes: Bianchi hybrid. Dunelt 3-sp. Raleigh basket case. Wanting a Roadster.
Computers do not like vibration and banging around. That said if it is packed so UPS could not damage it you can probably transport it on a bicycle safely. Put it in a shipping box, carry the shipping box as listed by others above. Anything else and you are depending on Luck. As you know, the lady is a fickle friend.
+1 Not to mention set the PC with the motherboard side as the bottom.
Quoted: 7348 Post(s)
Liked 2,471 Times
I recommend removing the hard disk and putting that in a small backpack and wearing the backpack. Hard disks are almost always easy to remove. And it's easy to destroy them with shock.
I can attest that a little vibration won't kill them even when powered. I used to do GPS in my car using an old laptop mounted in my car. I'd go blasting down gravel county roads at 50 MPH hitting cattlegards and all manner of bumps and ruts with no ill effects on the drive..
Liked 2,471 Times
That might be overkill. The killer of drives is vibration and shock while they're running. In a powered down state the heads are parked and the platters are not spinning.
It's not overkill in my view, because in nearly all cases, the value of the data far exceeds the value of the hardware. You could call it overkill if the effort is substantial, but if you have moderate mechanical ability, you can remove a hard disk in five minutes and usually less. Not spending this time seems foolhardy if you're knowingly taking a risk. Hard disk crashes are already very common. I trust that you're right that they're not likely when they're powered down. But my perspective is as an independent computer consultant, and I spend a lot of my time helping people after their hard disks crash. I'd like to do everything to (1) prevent crashes and (2) be prepared for them before they happen.
Bikes: Custom 531ST touring, Bilenky Viewpoint, Bianchi Milano, vintage Condor racer
The last time I needed to carry a full-sized PC on a bike, I simply tied a harness out of rope and wore it as a backpack -- a bit heavier than ideal, but it took five minutes and cost nothing. Make sure the ropes aren't hung up on any projecting buttons or other fragile parts.
Liked 2,471 Times
Sirrus Rider, I appreciate the depth of your experience, but I'd guess that the shocks of a bike on a potholed street are greater than those on a cart pushed at walking speed.
I would second the suggestion to carry it on your back, either in a large backpack or via the homespun method above. It would take a lot less of a beating by using your built in natural suspension.
