Racer Tech Thread
Old 05-04-15, 01:10 PM
  #1376
carpediemracing
Bikes: Tsunami road bikes, Dolan DF4 track
Quoted: 385 Post(s)
Liked 180 Times in 102 Posts
13, I think, maybe 14. Plus 7 on the other number. Not enough for a win though.
"...during the Lance years, being fit became the No. 1 thing. Totally the only thing. It’s a big part of what we do, but fitness is not the only thing. There’s skills, there’s tactics … there’s all kinds of stuff..." Tim Johnson
carpediemracing is offline
Old 05-04-15, 01:34 PM
  #1377
spectastic
commu*ist spy
spectastic's Avatar
Quoted: 653 Post(s)
Liked 5 Times in 5 Posts
Originally Posted by topflightpro
A buddy of mine won a set last year. He used them once, and he didn't seem impressed. The second time he went to use them, he wasn't paying attention when putting them on and let them slam together. Apparently that is a No-No, and they broke.
They are your brakes. Do you really want to go cheap and risk them not working when you need them most?
At this point, if I were to buy a new bike, I'd probably go with one with discs. I am convinced that in a few years, it will be nearly impossible to find a frameset for rim brakes - just look how hard it has gotten in cross in just two years. It's not necessarily the direction I want to go, but it really seems to me that is the way the industry is going.
for my caliper brakes, the tektros and shimanos all work the same to me. I've never used disc brakes. that's why I'm asking is the generic type comparable to the branded type.
spectastic is offline
Old 05-04-15, 01:39 PM
  #1378
spectastic
commu*ist spy
spectastic's Avatar
Quoted: 653 Post(s)
there's probably a point where the greater number of pins will result in more drag,
Old 05-04-15, 04:07 PM
  #1379
wens
wens's Avatar
Anybody know of somebody who beta tested the new stages firmware? Anybody hear anything about it having problems or being unstable?
wens is offline
Old 05-04-15, 04:09 PM
  #1380
globecanvas
Ninny
Quoted: 686 Post(s)
I just installed it. The install went fine, I haven't ridden with it yet.
globecanvas is offline
Old 05-04-15, 04:16 PM
  #1381
furiousferret
furiousferret's Avatar
Quoted: 842 Post(s)
Liked 469 Times in 250 Posts
I just bought Race Dots, haven't tried them out yet. I have a fear of going down and a pin going into my skin, cutting into my intestines, and having to wear a pee bag like that dude on The Wire.
furiousferret is offline
Old 05-04-15, 04:31 PM
  #1382
Doge
Doge's Avatar
Bikes: 1979 Raleigh Team 753
Quoted: 3374 Post(s)
Liked 371 Times in 253 Posts
3M 77 combined with GooGone GEL (not their Heavy Duty stuff). It helps to just really wrinkle the number, then spread it out and it is barely noticeable.
Get someone to rub it on.
Sat number (good/typical ink)
Sunday Number. I stopped wrinkling as the number ink was coming off - inc. on the jersey. Starter ref was concerned about reading it and chief ref had no issue.
3M 77 spray - let dry till tacky (5 min)
Spray Gel on underside and wash
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Doge is offline
Old 05-04-15, 04:39 PM
  #1383
globecanvas
Ninny
Quoted: 686 Post(s)
Oy.
Old 05-04-15, 04:42 PM
  #1384
shovelhd
shovelhd's Avatar
Bikes: Yes
Quoted: 9 Post(s)
No issues with my upgrade. I also have not ridden it yet.
shovelhd is offline
Old 05-04-15, 08:44 PM
  #1385
Doge
Doge's Avatar
New / old topic. My son has pulled wheel out 4X this year. 2X it was a big deal - VOS RR and yesterday. It always happened in big power. 1st time - thought it was a loose skewer. 2nd time VOS RR - thought it was a loose skewer. 3rd time was VOS crit and I clamped that thing on tight and it came loose in the sprint. We were using the KCNC Ti skewers. Last year he had no issues. He had not really sprinted since VOS other than in training when these wheels are not on.
So Venge has steel plates on dropouts. His prior bike was just carbon dropouts.
Really smooth hub face - hard anodized alloy.
And - lots of chain lube and not so tight skewer.
A beefy Campy serrated skewer may also help.
Old Campy track hub face
Lock washers?
Lock Washers
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Doge is offline
Old 05-04-15, 08:53 PM
  #1386
globecanvas
Ninny
Quoted: 686 Post(s)
If he has pulled a wheel 4 times I would immediately blame the undersized weight weenie skewers before putting lock washers or whatnot in there. Spend the 50g to put some real skewers on the bike.
versus
Old 05-04-15, 08:59 PM
  #1387
Doge
Doge's Avatar
I guess I did not properly report we gave up those skewers for steel shaft. But that was after the 3rd time. The first two I blamed him for putting them on too loosely - which he does do. We went with steel yesterday but caps were not heavily serrated. Yesterday he did mount his own wheels and they were not that tight, but never had any issues before this year. The new variable is the frame - which he loves, but I'm looking at dropout angle, steel plates etc. Sure, a standard wheel, with standard hubs would likely be a fix - but how fun is that?
Doge is offline
Old 05-04-15, 09:06 PM
  #1388
globecanvas
Ninny
Quoted: 686 Post(s)
Steel, but still the lightweight skewers with undersized clamping surface? Or normal skewers. I can send you a set of DA skewers if you want, those are the clampiest of the clampy, but they might cost you all of 100g.
Old 05-04-15, 09:21 PM
  #1389
hack
hack's Avatar
Quoted: 417 Post(s)
Liked 3 Times in 3 Posts
I had my rear wheel pop out recently in a group ride sprint (on a Venge). Scared me quite a bit and I lost the sprint. Since then I have been cranking down the rear skewer (pretty basic steel skewer) a bit more and it has been fine when sprinting.
hack is offline
Old 05-04-15, 09:30 PM
  #1390
Doge
Doge's Avatar
Time to over-Campagsate.
File Type: jpg
Doge is offline
Old 05-04-15, 09:33 PM
  #1391
spdntrxi
Bikes: not enough
Quoted: 189 Post(s)
Liked 86 Times in 52 Posts
I've used Enve skewers with no issues..
spdntrxi is offline
Old 05-04-15, 10:10 PM
  #1392
tetonrider
Quoted: 693 Post(s)
honestly....how big is your kid and how much power is he putting out? skewers work for tons of people out there--even the WW one.
INTERNAL cam designs (shimano and campy) are the most secure, but having a wheel fall off is (a) super rare and (b) terrible...esp for everyone else around. it is like rolling a tubular.
you've had to add weight to your kid's bike. just put on the proper skewers.
(i have never had a problem with zipp, shimano, or even the weeniest of weight-weenie skewers....even for MTB, but obviously this kid's mileage varies. i don't want to read a thread about him busting up his face.)
Edited to correct brain fart -- meant INTERNAL cams. (Thanks @globecanvas.)
tetonrider is offline
Old 05-04-15, 11:09 PM
  #1393
Ygduf
¯\_(ツ)_/¯
Ygduf's Avatar
Bikes: aggressive agreement is what I ride.
Quoted: 967 Post(s)
Liked 4 Times in 4 Posts
wait, what hub keeps coming out?
And you keep using it?
Ygduf is offline
Old 05-04-15, 11:12 PM
  #1394
Doge
Doge's Avatar
external cam designs (shimano and campy) are the most secure, but having a wheel fall off is (a) super rare and (b) terrible...esp for everyone else around. it is like rolling a tubular.
Yesterday he had the proper skewers I don't think it is a power thing for sure or leaning the bike. There is a bunch of bike twist going on but at 140# he's just not hitting the components with what they have not been designed for. There is an issue I don't get. This only happens on this frame. He road the KCNC all last year and won lots of Cat 3 and Cat 2 sprints. That's why I think it is the hub axil face combo with the steal drop-out plates on the Venge. I know Cav uses the Venge, but I figure he has serrated hub faces.
I am trying to figure it out. So for now - serrated washers.
As for adding weight - only UCI races. And that's a bit depressing as they don't check.
Doge is offline
Old 05-04-15, 11:31 PM
  #1395
Doge
Doge's Avatar
Correct. I understand I could have just gone big brand components. But there is a transition going from fun weight weenie stuff used with an 80# rider to real racing. These are fabulous wheels - except when married to this frame. I'd switch the frame and keep the wheels if we weren't on a team. It is the combo that seems to be the issue. I thought it was my son not tightening his own skewers, then I thought it was the skewers. Its also the frame and the hubs. Its all the above.
Doge is offline
Old 05-04-15, 11:47 PM
  #1396
Doge
Doge's Avatar
Originally Posted by hack
I had my rear wheel pop out recently in a group ride sprint (on a Venge). ...
This is good input. Based on your picture in the other thread I would also assume you were putting out some power.
What were your hubs and skewers? Also were the hub axil faces serrated and of what material?
These hard steel dropout faces that Specialized is putting on the Venge are part of the issue.
Doge is offline
Old 05-05-15, 12:16 AM
  #1397
hack
hack's Avatar
Quoted: 417 Post(s)
Hubs are White Industries. Skewers are whatever basic ones RaceRim uses. I'll check on the hubs in the morning to see if they're serrated.
hack is offline
Old 05-05-15, 03:11 AM
  #1398
Grumpy McTrumpy
gmt
Grumpy McTrumpy's Avatar
Quoted: 45 Post(s)
I have sprinted my rear wheel out four times on my Foil. All four times were with the same wheel/skewer. Zipp 303 and Zipp Skewer. It ended one race entirely, cost me a second one by dropping me from the field with 40 headwind miles to go, and the other two times were during warmups. There is a permanent scrape on the chainstay from the wheel. No amount of hand-tightening solved the issue.
This Mavic skewer fixed the problem. Completely.
Grumpy McTrumpy is offline
Old 05-05-15, 05:10 AM
  #1399
shovelhd
shovelhd's Avatar
Bikes: Yes
Quoted: 9 Post(s)
Ditto on the Dura Ace or Ultegra skewer. Give them a shot.
shovelhd is offline
Old 05-05-15, 05:14 AM
  #1400
globecanvas
Ninny
Quoted: 686 Post(s)
I think you mean internal cam?
