Touring with One-By Drivetrain?
Quoted: 463 Post(s)
Liked 567 Times
This idea that when shifting one must land in the perfect gear is a fixation from competitive road cycling where the rider stands to lose in ranking, position and earnings. We are talking about non-competitive touring. I don't see it as a big deal, much less as a deal-breaker. Not to mention, of course, that the real leg shock and dramatic change in gearing comes not from rear shifting but rather front shifting when you go from one chainring to another. But that gets conveniently overlooked in the tally of pluses and minuses. 😉
Likes For staehpj1:
A Deore 11-speed 11-51t cogset gives you 464% range. For light- and medium-load touring, where top end speed is relatively unimportant, I'd say it's hard to ignore.
An advantage of the 11-speed Deore M5100 part over the M6100 12-speed 10-51t part is the the former, unlike the latter, can be mounted on a standard freehub spline, and is quite a bit less expensive.
A triple crankset today? With the widening range of cogsets in the last decade, no. Today, a double at most, for sure.
With doubles you easily run into cross chaining if you want to use the whole cassette with a single chainring. If you emphasize the big ring as the main ring, going lower on the cassette means that at some point the chain angle gets pretty rough. Not necessarily and issue but I don't like to do that. Dropping down on the small ring can be an issue or not depending which sort of system you have. Since I feel I need a 22t or 24t as the small ring, the jump to the big ring is inevitably pretty large, because a 32 or 34 is spin out town on the flats. So if I do need to use the bailout small ring I need at least two, maybe three upshifts on the cassette side so as not to come to a complete halt. Loaded touring bikes slow down fast. With a triple I'll need maybe one or no upshifts at all.
It doesn't help that middle ground cranksets are expensive and difficult to find. A 24-40 crankset with a 11-40 12-speed cassette could work fine, but as far as I know such a combination doesn't exist anywhere. A 11-speed 11-40 does exists, but that crankset is still a dilemma. I like way more that I can buy a crankset for under 100 € than paying over 500 €.
The leg shock is easily mitigated with upshifts on the cassette. But you can't do that with a wide cassette.
I do realize that these two replies I've made are pretty contradictory. However what works great for my (all)road bike actually doesn't work at all well for a loaded touring bike. Kinda like how the 1x 12s 10-50 works great for the MTB, but just sucks on the road.
For example the whole upshift thing to mitigate leg shock. Works great with a road bike and if you drop a chain you usually have time to use the front mech to re-engage before coming to a stop. And if you do come to a stop, you can easily remount the chain by upshifting the front, raising the rear wheel and spinning the cranks. AND you can set off even if you're in too high a gear. Grind it out. With a loaded bike you're way more likely to stop before you can re-engage. Lifting the bike or trying to engage the chain whilst on a steep incline may not be a viable option, especially if you have a trailer full of kid. What comes up, will want to roll back down if you don't have both hands firmly pressing the brake levers.
As the triple may not even need an upshift, you're much safer in terms of potential chain drops. But I wouldn't use it on a pure road bike.
Quoted: 3461 Post(s)
Liked 1,467 Times
This idea that when shifting one must land in the perfect gear is a fixation from competitive road cycling where the rider stands to lose in ranking, position and earnings. We are talking about non-competitive touring. I don't see it as a big deal, much less as a deal-breaker. ...
I have three touring bikes, one has a Rohloff hub with 13 percent difference with each gear shift. My derailleur bikes have eight speed cassettes and a half step plus granny triple crank have much closer gear ratios in the mid and upper range where I spend the vast majority of my time.
My Rohloff hub gearing plots up on a graph like this (this was also shown in a previous post in this thread):
And this is from one of me derailleur touring bikes, of the 24 possible gears I try to only use the 18 least cross chained gears, thus only 18 are shown:
I really like the closer gears in the mid and upper range so I can fine tune my gearing for optimum cadence. The lowest gears, they are much further apart but I spend so little time down there, I can live with wider gear spacing where I rarely use it. The two lowest gears are only used on the steepest hills.
On hilly terrain, I often end up in less than optimum gears because the slope is often rapidly changing, thus the half step does not really help much there. But on flatter terrain, that is where the close spacing really shines.
I doubt if I have changed your mind, but that is ok, we do not all have to share the same opinion.
Only a very small minority use half step plus granny gearing, it is an acquired taste and my first experience with a bike with half step gearing was back in the 1970s, so I got used to it long ago.
the most miserable touring experience is riding long-distance with a load, on varied terrain or especially against the wind, being unable to find the correct gear. either too high or too low, so can't maintain a comfortable cadence.
Quoted: 463 Post(s)
Liked 567 Times
Wow. So rigid and unadaptable. Come on, let's get real, folks. You slow down or speed up a bit. It's not brain surgery or Swiss watch-making.
c'mon, man! we're living in the 21st century!
you no longer have to limit your number of gears, or accept a poor gear ratio selection.
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 175 Times
Likes For L134:
Quoted: 463 Post(s)
Liked 567 Times
Yes, I am highly adaptable. And I don't make a mountain out of mole hills or split hairs. In other words, I am sensible and pragmatic. 😉 Slowing down or speeding up a bit if you are not in perfect gear is the reasonable, pragmatic approach rather than adding complexity and weight to the bike. KISS. Yeah, i know old habits are hard to break, but let's try to keep it just a wee bit real.
Cadence is surprisingly important. In cycling, in running, in swimming and in walking. Doing any of those for long outside your preferred area gets annoying.
Also, what happens if you're riding with somebody?
In my experience you have to be even more flexible with speed then, but you do get one more tool to cope with it, drafting. I have found that when riding with folks that I trust to ride close with drafting is a great equalizer and can keep a group of varied strength riders together. It works well even for equal riders when someone is having a bad day. It doesn't work so well for long climbs. That usually requires the stronger climbers wait for the others at some point. We usually met up at the top in the groups or pairs I toured with.
Personally I find it pleasant and helpful to vary cadence throughout the day. Some days I may spend some time noodling along at 50-60 rpm, some I may maintain a steady 90 all day. Sometimes I may climb at 100 or even 110-120, but sometimes I choose to mash a big gear. In any case most often I mix it up throughout the day.
For at least 50 years I have been told that mashing a big gear would ruin my knees, but I have done it at least on some climbs and here I am at age 72 with pretty health knees.
I notice that in the pro peleton in grand tour type racing the majority of the rider who are out of the wind when the pace is not yet heated up are most often rolling along at a pretty low cadence sometimes as low as 50-60 rpm. Some also climb in fairly low gears others spin like mad. Some vary pretty widely depending on conditions and goals at the moment. You see them on much wider ratio clusters these days and no one looks like they are using the little ring until they are on steep climbs and even then some are still on the big ring. A few top riders have sported 1X MTB/Gravel drivetrains for specific stages even including on a time trial bike in one case.
hi stae, this years Giro d'Italia which just finished last weekend was a great race with a dramatic final (penultimate) stage--a TT with a super steep climb at the end. The riders did a bike switch at the bottom of the climb, and the winner went with a 1x climbing bike, but partway up he dropped the chain. Got it back on and a push from some people and was the stronger rider in the tt and so won the race by 14 seconds--but yup, even at the grand tour level, a 1x can drop the damn chain!
Likes For djb:
I'd have to say that from my experience I can see both views here.
I got into looking at gearing details a long time ago, and so now look at the percentage jump between shifts. For touring on a loaded bike, or driving a heavy 18 wheeler, its always going to be better with closer ratio shifts. This is why transport trucks use 15 speed gear boxes or whatever.
Back in the day of 5, 6, 7 speed cassettes, the jumps were bigger and more annoying. This is where we get into the grey area of what works fine enough, so yes I can agree with Ron on it not being a big big deal. For example, I have toured a lot on cassettes up to 9 speed and the 9 spd 11-34 has , for me, perfectly fine jumps. Ya, there are a few that are a bit big, but not horrible. My wifes 10 spd touring 11-36 even has slightly closer ratios--so as 11 and 12 speeds become more and more common, you can have as good or better ratio jumps between shifts compared to 9 or 8 speed, so all in all something that works fairly well.
I also ride a bike with a much closer ratio cassette, still only 9 speed, but I would love in the future to have a 11 speed cassette with these same nice close ratios, but with a few added on cogs for good measure--best of both worlds--and why a suitable double and cassette for your bike + load weight + how steep the terrain would be fantastic.
Quoted: 2333 Post(s)
Liked 2,097 Times
My first touring bike went lots of places on 46/32 with 5 speed 14-32 FW.
An 11 or 12 speed 1X would/could have a lower low, higher high, and smaller gaps. Of course, it could not compete with 46/42/24 with half step and a 6 speed.
I find I want 1 tooth steps from 45 inches to 65 inches and 2 or 3 gears above and 2 or 3 gears below when touring with a load.
My cadence varies according to a variety of factors. Those who piddle along the flats at 10 mph at 90 rpm and 50 watts know nothing
Liked 2,097 Times
But in my touring it's mostly with my wife where we ride side by side and chat.
Or perhaps it's all hogwash.
I've understood that the 1X bikes used in the grand tours were swapped to the riders before a big climb etc. So they wouldn't use said gearing on flat stages or even flat parts of mountain stages.
Liked 1,467 Times
Everybody has their own cadence. I know people with a high cadance and one guy I know has a hummingbird cadence, he really spins the crank. And others that are much slower. When I am working hard, I am around 72 to 78.
Making comparisons between average people on a bike tour with pro peloton racers is not applicable in any way.
Don't assume that a high cadence is only for racers, the guy I know with a hummingbird cadence goes on tours in the desert where he needs to pull a trailer behind his loaded touring bike to carry his load of water. He does not have much torque, but the rpm makes up for it.
We are currently cycling around the world. I'm typing this on my phone inside my tent. One of us has 1x, the other has 2x.
1x is perfectly fine for touring. 34t chainring. 11-50 cassette. If I was setting this up again I would change the chainring to 32t. Never used the 34-11 combo once so far. Hills are tough withe extra weight so one rests at every opportunity. We are coasting well before this fantasy gear comes anywhere near being in play. The highest speed I bother pedalling at is 20 mph. At 20.1 mph I'm coasting. I have zero desire to waste my leg power during a downhill. I prefer to save my legs so I can crush the uphills.
I don't think I'll build another 2x touring bike in my life. In my opinion 2x is obsolete for touring. As for 3x, I stopped using that stuff over 10 years ago.
Regarding finding the perfect cadence, I'm comfortable anywhere between 75 and 90. Some people's neural-muscular system can't cope with this kind of variation. Individual brain muscle control differences, probably genetic. Nothing you can do if you are in the other camp, 1x is not for you.
Likes For Yan:
I too have been ridiing a 1x recently. Mine is on a new mountain bike and it has not been used for anything other than daily local trail rides. That said the 30t and 11-51 seems like it would be good for all of the ratios I'd need for any of the touring I've done or plan to do. So far I am really enjoying the setup. If I were to set up a bike specifically for touring I wouldn't hesitate to choose a similar drive train.
I just like a closely spaced cassette to get finer/closer steps between shifts, I'd run 4 chainrings in the front to keep the 1 tooth steps in the rear.
If only it was possible to get a triple with a 12 speed cassette and brifters. A 12 speed 11-36 cassette would have super tight gearing and with the triple you'd get more range than with a 10-52 cassette. Not a ride goes by with the Disc Trucker that I don't dream of putting on a GRX. Sadly no option for low gearing with the GRX without lots of bodging stuff.
A 10-52 has similar gear jumps as a 9-speed 11-36, but with a triple those big jumps are pretty well mitigated so it's easier to find the proper gear. I remember being severely bothered by the difficulty of trying to find a proper gear with an 11-speed 11-42 and 32t chainring. The lack of front shifting options does remove the mid gears so you're relying completely on the cassette jumps.
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
I haven't yet had a chance to test it on a real-world tour, but I've fully loaded the bike and ridden local hills that are worse than anything I have encountered on a tour, and it works well.
Likes For Polaris OBark:
I have a GRX 11-speed setup on my Soma Saga, and have an 11-40T SLX 11-speed cassette and a 2X 46/30T GRX crankset. The only "bodging" involved turning the B-screw.
If it were possible to directly use the GRX shifter with the front shimano mtb derailers, that'd be great. That way I could use a 24-38 crankset which would give me pretty decent range. It is possible with a JTEC pulley (which I already use with Sora) but that's a bit of a bodge and a total pain to route a cable through
Liked 1,467 Times
I have been using gearing with that for a lowest gear on derailleur touring bikes for over a decade.
Likes For Tourist in MSN:
