SRAM Patent for Compact Motor-Battery
Quoted: 890 Post(s)
Liked 848 Times
SRAM has initiated a patent for a compact motor & battery / unit that appears lightweight with the weight centered and low. See electrobike.com for details. This would be great if it was applicable to DIY, but probably is headed in the OEM direction.
Likes For 2old:
Quoted: 343 Post(s)
Liked 281 Times
Here you go. SRAM patent,
I count 28 cell holes, enough for a 52V7AH battery using 18650 or a 48V7AH if they leve two holes empty,
A 26 cell 18650 actually takes up a lot of room. The motor module could be pretty bulky,
Likes For Doc_Wui:
Quoted: 890 Post(s)
Liked 848 Times
I count 30, which (to me) makes sense for a 3 parallel X 10 series (35V) system. I would think the system could be about 10 pounds.
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 144 Post(s)
Liked 317 Times
Nifty. Be interested to see some frames designed around it.
My TQ motor and battery combine for 8.1 pounds/3,680g and I'd imagine this integrated take might be in the same ballpark.
Likes For Rick_D:
