Anyone own both a high-end steel bike AND a low-end steel bike?
Flyin' under the radar
I will soon be a position where I will have some extra funds, and I really want to add a steel bike to the stable. The top end of my budget would be about $2500 for frame + fork. But, I could get a cheaper steel bike and upgrade the group on my commuter bike (from 9-speed to 11-speed, and then I could interchange wheels), or upgrade the cockpit on my carbon bike, etc.
My question is this: for those of you that have both a high-end steel bike and a low-end steel bike, is the high-end steel bike really worth the premium?
For example: would there be an appreciable performance/weight/ride quality difference between an Independent Crown Jewel and a Soma Smoothie?
Quoted: 6556 Post(s)
Liked 58 Times
Even moderate steel frames now are excellent compared to the low end of the '60s and '70s. All you will sacrifice is low weight as far as the frame is concerned. The parts are the parts. 105 is still wonderful as is Rival. So a 520/525 steel frame with 105 or Rival is a pretty sweet, moderately priced bike.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,531 Times
What do you mean by this? Moderate (aka mid-priced) steel frames today are excellent compared to low-end steel bikes from 40 yrs ago? But today's steel frames weigh more than they used to?..
Liked 58 Times
No. I meant that the moderately priced frame will be heavier than a more expensive frame made from a stronger steel of which less is needed to build the frame. Lower end frames many years ago were mikely hi-ten steel and very heavy. The best marerials of the past are the lower end materials today.
Quoted: 1067 Post(s)
Liked 259 Times
I have had mid and high end frames in steel, carbon, and aluminium. I would say they are all similar in that the better frames are just a little bit better. It isn't a big step from one level to the next but it is noticeable. Mainly in feel rather than anything you could detect with a stopwatch.
Quoted: 276 Post(s)
Liked 6 Times
My current steel is Wraith Hustle, I also happened to have owned a Soma Smoothie. I love the Wraith and it's about 17 lbs without trying too hard. I also loved the Smoothie. The Smoothie was a really sweet riding bike. It was about 20 lbs with full carbon fork and 5800 groupset but of course you could probably get that down to 17 lbs if you wanted to. I think there is difference but not worth spending tons of money. I think a new Wraith frameset is about $1400. You can also get a Ritchey Logic for less which is still nice. You can get a Gunnar frame and even some custom like Curtlo for $1000-1500
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12762 Post(s)
Liked 7,675 Times
Yep. I've had SL and Aelle. 520 and 853.
I get my steel used so the prices vary less and sometimes overlap.
IF probably has greater resale value if you like to keep bikes for just a few years.
Quoted: 401 Post(s)
I'm also curious how good a high end steel bike is with respect to stiffness as compared to say a CAAD12 or a decent CF frame.
Quoted: 276 Post(s)
Liked 6 Times
Nice question. I'd like to hear about people's perception about stiffness and power transfer. Are the higher end steel bikes stiffer but still absorb road buzz?
Liked 58 Times
If I go low-end, the Smoothie is the front runner. Based on your response, it sounds as though the difference in feel is likely due to different geometry vs. different steel grades -- thoughts?
I currently have a 90's steel Trek 420, which I like. I'm looking for something more modern with a 1-1/8 to 1-1/2 tapered head tube and full carbon fork.
I think if I were to go high-end, there isn't a better bang-for-the-buck than Curtlo. Though there's something about a Colnago Master that just speaks to me.
Any other low-end recommendations?
Bikes: 1981 Bianchi Limited 650B conversion (sold), 1985(?) Guerciotti retro-roadie, 2018 Specialized Allez Sprint, 2012 Specialized Crux, mid 80's Focus MB-400
Quoted: 67 Post(s)
Recently finished putting together my first "high-end" steel bike, a 1980's Guerciotti with 105 5800 components. The ride is just awesome. Obviously that is a totally subjective opinion. However, the Guerciotti does not strictly dominate my trusty "medium-end" steel Bianchi. The Guerciotti is racier, while the Bianchi is cushier. Recently did a 90 mile ride with lots of climbing on gravel roads, the Bianchi was perfect for that.
If you really like the fit of your current steel road bike, try to get the fit of your new bike as close as possible. Reach from saddle to bars, saddle to bar drop, etc.
Quoted: 1136 Post(s)
Liked 650 Times
If you wanted to spend the full $2500 you should go for high-end custom. You have to be willing to wait a few months, usually.
Or you could get something semi-custom, like a Gunnar frame. Super light steel, awesome paint and fork options, made by Waterford. And you can still do custom sizing. Frame + fork will run about $1500.
Pricing
I went the semi-custom route and have a Mercian coming. It will be beautiful, light, and stiff. I opted for lugs so the British semi-custom options (Mercian, Bob Jackson) were better.
The last and cheapest option is to buy a high end vintage steel bike in good condition. Will take a little time searching through eBay/craigslist because you will need to find the right size, look, and frame specs for what you want. It will definitely be cheaper than buying new and if you find something good from the late 80s onward the frame will probably be the same quality/weight as a new frame. You have to be willing to search and also probably overhaul/replace parts.
In general the Smoothie and similar bikes are really nice and can be built light, but if I had your budget I would be looking at custom or semi-custom, or go real-deal vintage and drop the cash on really nice parts.
Pricing
Liked 58 Times
Pricing
Pricing
Quoted: 276 Post(s)
Liked 6 Times
For me it's hard to beat bang for the buck on the wraith but they have limited production and sizes. I feel like soma is best bang for buck at that price but I would also look used. You can find nice Lemonds and other similar 853 frames for $300-500 on ebay
Bikes: Colnago CLX,GT Karakoram,Giant Revel, Kona Honk_ Tonk
Quoted: 149 Post(s)
I am in the process of building out a new steel bike now. I was going to buy the Soma Smoothie but went with the Kona Honk_y Tonk instead. It's 520. I'm putting full 6800 on it. I still need a headset, stem, cables and a saddle. I actually have a saddle but I want to put a Brooks B17 N on it.
The Soma frames are really nice but I love the lime green on my Kona. Plus, I picked it up for only $450.
Jenson has the complete bike with Sora for 799.00. It's a great price but I like to build mine out with specific parts.
Liked 650 Times
True. Newer alloys like 853, OX Platinum, and then all the stainless variations are somewhat lighter than the older tubesets. You have to be willing to drop a lot of money on those frames, though.
Liked 650 Times
Going with a smaller builder gets you a lot more bike for the money and something that will be more unique on the road than another Colnago.
Bikes: 2015 Jamis Quest Comp
Quoted: 270 Post(s)
Yeah, that's what thought when I saw that Colnago picture: "everybody's got one of those." ;-)
But I agree about price and performance/quality. you are paying for the name and paint job...which some people want.
If I were financial able I would be buying frames from Hilary Stone. I was just browsing his website and the frames he sells are true artisan built classics. Amazing stuff that would cost 2,3,4 times the price if built today. And you get the workmanship of some of the greats of cycling history.
To provide a counterpoint...going big and Italian is a great way to spend way more money for the same quality and performance as just about any other option. You're essentially spending 2-3 times as much for a name and a garish paint job.
I do agree you can find better value elsewhere. But if you have your heart set on one, nothing else will do.
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1251 Post(s)
Liked 1,276 Times
I'm trying to think how emphatically I can express this without violating Bike Forums' Terms Of Service. "HELLS YEAH!" doesn't quite do it justice.
But yes, it's definitely worth the premium. No question. The way my high-end bikes handle, track straight, resist twisting, convert your every thought/impulse into action, they way they inspire a confidence that is simply unfathomable on the low-end bike...no comparison. Zero. Apples and oranges.
And worth every penny.
