Chafing
Quoted: 130 Post(s)
Liked 24 Times
Chafing
I've been having probs with chafing right where my leg meets my crotch (more on the left than the right). I lube it up real good before heading out but around 30-35 miles it can get pretty sore. trying to think if i should try a narrower seat or better bibs? My bibs are all kind of mid range about $125-150 or so several different brands, current saddle SMP hell saddle.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
At 30-35 miles is awfully early. Are you using chamois butter of any kind? Body Glide?
Quoted: 1814 Post(s)
Liked 923 Times
Sometimes skin bacteria composition gets out of whack.
You might try mineral stick deodorant, and/or witch hazel or other skin cleaner to reset.
Also consider what you eat- can be a factor in skin issues, & make sure that bibs & saddle get really clean.
Kudos for correct spelling of 'chafing'.
Bikes: Shmikes
Quoted: 10153 Post(s)
Liked 5,849 Times
I try not to think about other peoples’ crotches, but if it were mine, I would look for a piece of chamois bunching up, not having my chamois pulled up all the way and and seated properly on one side, or sitting on my saddle crooked. All of the above have caused me chafing issues at one time or another. Have you inspected your chamois for asymmetric wear or bunching?
Quoted: 130 Post(s)
Liked 24 Times
I try not to think about other peoples crotches, but if it were mine, I would look for a piece of chamois bunching up, not having my chamois pulled up all the way and and seated properly on one side, or sitting on my saddle crooked. All of the above have caused me chafing issues at one time or another. Have you inspected your chamois for asymmetric wear or bunching?
I'll have to do some inspection
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I chafe right where the OP chafes. Body Glide prevents it.
Just about every triathlete on the planet uses body glide.
Quoted: 1975 Post(s)
Liked 232 Times
I've had this happen with a poor seat fit, usually you are sitting on too narrow of a saddle or too narrow portion of the saddle so applying excess pressure at that intersection. No amount of lube is going to fix this long term
Bikes: Cervelo S3
Quoted: 38 Post(s)
Had problems regardless of seat until I switched to high end bibs(assos) and started using chamois cream on any ride but commutes. It could be 4 things, saddle, bike fit, not using chamois cream, or the bibs...I would relook at your fit and see if your seat is to high, then try chamois cream of your not already, then high end bibs, then last saddle change.
Bikes: '15 Cervelo S3 Trek Alpha 1.5
Quoted: 15 Post(s)
Some pictures may be beneficial in identifying the culprit. 🤣
All joking aside, I recently had the same issue. The problem stemmed from me pulling my bibs at the hem while standing and stretching, prepping for the ride. I would never pull them back up and make sure the padding was seated in the right place before mounting the bike . The inseam where the chamois joins my bibs would work it's way to the crotch/inner thigh crease and cause miserable discomfort.
That's where I'd start looking for answers . Keep the area clean and dry when not riding and well lubed when on the bike till it heals.
