Tips on mid 90's Athena rear hub service?
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 159 Post(s)
Liked 133 Times
The rear hub in my 95 Marinoni is gritty. Here's a video of somebody servicing it:
Any further tips from anyone?
Quoted: 159 Post(s)
Liked 133 Times
More specifically:
How the heck do you hold the pawls in place when you reassemble?
Bikes: Numerous
Quoted: 1676 Post(s)
Liked 3,085 Times
Yes that's the biggest challenge. I have the spring tool that comes with the hub but I found it doesn't work as well (or really at all IME) as looping string or dental floss around the pawls and then pulling out after everything is in place. Don't tie a knot, just wrap around once or twice.I found a thicker string works better than dental floss. Grease on the pawls with a drop of oil added after string in place will help keep the pawls in place.
Quoted: 159 Post(s)
Liked 133 Times
Thanks for that! I'll give it a try.
Quoted: 159 Post(s)
Liked 133 Times
Got It.
I put a small cable tie around the hub body, and that allowed me to push the pawl and springs into place and leave them there.
Then, when I was ready to reassemble, I slid the cable tie up the body, wrapped a string below it, and slipped the cable tie off. I pulled the string out once the pawls were contained in the shell. Phew!
I wouldn't have had a clue it Spaghetti hadn't chimed in. Thanks again.
Bikes: Numerous
Liked 3,085 Times
Got It.
Quoted: 159 Post(s)
Liked 133 Times
Well, I spent the entire morning procrastinating, because I imagined myself crawling and swearing across the basement floor like an aging Gollum, sifting through the sawdust with my fingers looking for one of those pawls.
Don't ask me why I could picture it so vividly!
vintage Bianchiist
Bikes: Bianchis, 84 Superleggera, 86 Giro, 87 SportSx, 87 Campd'Italia, 87 Limited, 88 Proto, 95 TSXChorus, 94 TSX105/DAax, 94 Super Grizzley RC, 94 Genius Record, 06 Pinella Boron, 18 Volpe Avanti, 00 Megapro ST Veloce00 EM Strada OS
Quoted: 35 Post(s)
Liked 13 Times
I just overhauled one of these for the first time, before starting it sounded like a cement mixer. It was missing a pawl spring, I replaced it it using a spring from push button ball point pen, it worked perfectly!
Quoted: 1636 Post(s)
Liked 824 Times
Leave it to Campy to make things overly complicated with those paws and springs.
I'm sure there could have been a way to cast the body (like a hole in the body and a short pivot shat on one side of the pawls) and pawl so the pawl and spring can be retained in place while inserting the assembly into the hub......
Bikes: Numerous
Liked 3,085 Times
