Numb fingers / change grip?
Old 06-04-19, 07:05 AM
rsmeed
Hi,
I am not an avid bike rider but I want to do it every so often. I did an 18 mile for the first time in a LONG time on a friends bike that was a little too tall for me. By the end of it both hands were completely numb. The next day it was just my pinky, ring finger and palm on both hands. 2.5 weeks later and they are STILL numb. I assume I need to go to the DR for that so my question to you all is... Can I change my grip if my bike is a GripShift? The ones I see on Amazon seem to be longer, so maybe I just need to cut them? I am in the process of getting a new bike and the ones I am coming across in my price range of mostly Gripshifts BUT if I can't change the grip then I need to look into ones with different shifts.
Also, does it matter if it dual suspension? I was told that since I am not doing crazy trails and stuff that I should stick with single b/c it will be easier to ride.
Thanks.
rsmeed is offline
Old 06-04-19, 07:17 AM
Wilfred Laurier
Señor Member
Wilfred Laurier's Avatar
Quoted: 327 Post(s)
Liked 64 Times in 45 Posts
Often when experiencing excessive pressure in your hands, the root of the problem is not the bars or grips, but elsewhere in the way the bike fits. We know the bike you were riding is not a good fit in general, but there may be simple adjustments that can make it better.
The first thing I look for when someone complains of hand pressure is the saddle position - if the saddle is nose-down, your weight slides forward and your hands are then responsible for pushing you back, almost subconsciously.
Wilfred Laurier is offline
Likes For Wilfred Laurier:
Old 06-04-19, 07:20 AM
rsmeed
Ok. So isn't going to make much of a difference with what type of bike I get and I want to make sure the seat is flat and not tilted down? Do you know if gripshift grips can be changed though?
rsmeed is offline
Old 06-04-19, 07:23 AM
Skipjacks
Skipjacks's Avatar
Quoted: 942 Post(s)
Liked 155 Times in 99 Posts
Probably. Usually the drip shifter is a separate piece from the rubber hand grip. The hand grip is just shorter than a normal grip so it fits with the shifter.
You can find short grips that are meant to be used with grip shifters.
You can also use a locking full size grip (as long as it's got a hard rigid core) that just hangs off the end of the bar. It will make the bar 2 inches longer but it'll work.
Skipjacks is offline
Old 06-04-19, 07:48 AM
Wilfred Laurier
Señor Member
Quoted: 327 Post(s)
While this may seem possible, I believe it is a bad idea. If the grip is not fully on the bar you are essentially using the inner plastic tube of the grip as a structural part. I assure you it was not meant to be used this way. A friend of mine's city bike has an arrangement like this, and luckily he only uses that bike for ~10 rides per year of less than 2 km. Handlebars are made of steel, aluminum or carbon fibre and are designed to hold the weight of the rider. The plastic tubes inside grips are not made for this.
Old 06-04-19, 07:55 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6838 Post(s)
Liked 217 Times in 180 Posts
Grip, ..your hands, .. relaxed or tight? take 1 hand off the bars and let them relax , occasionally?
gloved hand with a padding gap in the palm si nerves not compressed..
Im a JRA type now , not s mountain bike guy , bit I fit the Ergon grip bar end for grip shifters , on my folding bike..
Is it a 1 to 2 thousand dollar plus dual suspension bike bought at a specialist bike shop ?
or was it a sub $400 one bought at a mass merchant / sporting goods Big Box store ?
fietsbob is offline
Old 06-04-19, 08:05 AM
rsmeed
I know my hands were tight b/c I was leaning forward since it wasn't the correct fit for me.
I was trying to get away from wearing gloves b/c of the heat but if I need to to prevent this from happening again then I will. I know once I get a bike that fits me better it shouldn't happen BUT I am leary since I am still numb 2.5 weeks later.
I will look into the Ergon grips!
I am looking for a used and/or one from mass merchant.
rsmeed is offline
Old 06-04-19, 08:17 AM
VegasTriker
Quoted: 305 Post(s)
Liked 11 Times in 8 Posts
It is called "bicyclist palsy" a form of carpal tunnel syndrome. Look it up. Don't ignore the symptoms. I go to the orthopedic doctor today to have the stitches taken out after carpal tunnel release surgery. It only gets worse. If you are still experiencing the symptoms after 2.5 weeks you need to see a doctor. I long ago switched to recumbents that don't put any pressure on your hands but it still got worse over the years until I could no longer ignore it.
VegasTriker is offline
Old 06-04-19, 08:20 AM
Skipjacks
Skipjacks's Avatar
Quoted: 942 Post(s)
If you're using grip shifters though your hand should be far to the inner portion of the grip, thus nullifying the entended portion.
You certainly wouldn't want an ergonomic grip for this reason as your hand would be out of position if it's far to the interior. You'd want a uniformly round one.
For sure though....this is not an ideal solution. At best this is a stop gap until you can come up with something better.
Or just get trigger shifters and go to normal hand grips that have thousands upon thousands of options for every size and shape hand.
Old 06-04-19, 08:21 AM
Skipjacks
Skipjacks's Avatar
Quoted: 942 Post(s)
Also, work out our core muscles. Abs and lower back.
Make those stronger (those muscles grow pretty quick) and you'll be amazing how much less you are leaning on the bars as your core and get you more up right.
Old 06-04-19, 08:22 AM
McMitchell
Bikes: Focus Mares CX, Rocky Moutain Sherpa
Quoted: 58 Post(s)
https://www.bikeforums.net/hybrid-bi...-shifters.html
I just switched to a microSHIFT thumb shifter. I was having issues dealing with the two parts & extra room a grip shifter requires too. I have a SRAM Eagle, 12 speed, 1X group-set, which typically comes with either a grip or trigger shifter. The microSHIFT showed up on Amazon when I searched “12 speed shifters”.
The thread I ran explores the many benefits of this shifting system. They last longer, shift easier, can be used in indexed or friction modes....They take up the least space on handlebars too.
McMitchell is offline
Old 06-04-19, 08:55 AM
Sojodave
Sojodave's Avatar
Bikes: Fezzari Fore CR3 Di2
Quoted: 127 Post(s)
Liked 7 Times in 4 Posts
This post from BF has helped me tremendously with numb hands.
https://www.bikeforums.net/12953035-post7.html
Sojodave is offline
Old 06-04-19, 11:00 PM
Teamprovicycle
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 314 Post(s)
yeah , id say you just have to tough up , or you have a serious medical issue , you can pad and adjust but if you road once and had numbies for weeks thats not normal !!!
Teamprovicycle is offline
Old 06-05-19, 07:06 AM
livedarklions
Je suis Snap Motomag
Bikes: Trek FX 3; 1994 Specialized Allez Pro; "Motobecane" Fantom CX
Quoted: 1927 Post(s)
Liked 444 Times in 264 Posts
I've ridden several centuries with a grip shifter, and I'm of the opinion that they generally suck for distance riding because a) you really have to keep your hands at the ready in a numbing position to use them on the fly and b) the actual repetitive twisting motion of shifting very quickly gets uncomfortable on the wrists. For me, at least, it just really isn't a technology suitable for endurance.
Ignore @Teamprovicycle . This is a case where the bad fit of the bike probably caused the problem, and it's not necessarily a matter of "tough up" or "serious medical issue". Numbness is telling you not to do what you did again, but it's not unusual for it to take weeks to go away. There wouldn't be any harm in talking to a doctor, but I'll bet the doctor won't tell you anything you don't already know, and if it's like most doctors these days, you'll wait so long for the appointment that the problem will probably be gone once you get there.
livedarklions is online now
Old 06-05-19, 07:17 AM
iCollector
you can try Ergon grips, they may help.... I have them -and they make them for Gripshift compatibility. They may or may not help you, they are good for me... YMMV.
iCollector is offline
Old 06-05-19, 08:10 AM
MRT2
MRT2's Avatar
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast, 1997 Bianchi Advantage, 1994 Trek 930.
Quoted: 829 Post(s)
Liked 3 Times in 2 Posts
Fix the bike fit problem first. Your hands should be resting lightly on the bars, not locked in a death grip.
MRT2 is offline
Old 06-05-19, 08:13 AM
Cl904
Quoted: 101 Post(s)
Liked 20 Times in 15 Posts
I’d recommend an aero base bar with added drop ends.
Cl904 is offline
Old 06-05-19, 08:22 AM
livedarklions
Hah!!!!!
OP--just in case you didn't see the other thread, he's joking.
shredderfoxwood
Classic & Vintage
16
10-03-16 03:18 PM
mainstreetexile
Classic & Vintage
9
11-23-12 04:03 PM
damianxp
Road Cycling
5
06-26-07 10:38 PM
Dewbert
Touring
5
02-28-07 05:10 PM
