Any tips for my first true road bike?
Old 06-04-19, 07:11 AM
Jrasero
Quoted: 23 Post(s)
Liked 8 Times in 4 Posts
My last three bikes have been flat bar bikes: 2014 Giant Escape RX Composite, 2016 Kestrel RT-1000 Flat Bar, and a 2016 Scott Scale 730 Hardtail.
I decided it was time to get rid of my hardtail because I spent the entire time on the road and wanted to try out a proper drop bar road bike. I got a good deal on a leftover 2017 Scott Addict 20 Disc and I have just done 50 miles on it and need to bring it in to have the derailleur tuned but other than that mechanically it has been great
Any advice for a first time roadie?
https://imgur.com/gallery/8vpYqnU
What I somewhat overlooked was the fact that the 2017 model was marketed as race geometry so the bike especially in the drops has me insanely low at least for me, so my back is actually a tad sore
Jrasero is offline
Old 06-04-19, 07:19 AM
delbiker1
delbiker1's Avatar
Bikes: 1991 Ochsner steel frame, 2002 Airborne Zeppelin titanium, Schwinn DBX SS aluminum, Orbea MD 40 carbon fiber
Quoted: 182 Post(s)
Liked 31 Times in 24 Posts
How tall are you? By my judgement in the picture, the bike looks to be about 54cm. You can get a riser type or adjustable stem to bring the bars up. Also check your saddle position, height, forward/backward and angle.It takes some time and miles to get it all how you are most comfortable.
delbiker1 is offline
Old 06-04-19, 08:40 AM
Maelochs
Bikes: 2015 Workswell 066, 2014 Dawes Sheila, 1983 Cannondale 500, 1984 Raleigh Olympian, 2007 Cannondale Rize 4, 2017 Fuji Sportif 1 LE
Quoted: 5449 Post(s)
Liked 115 Times in 76 Posts
Fit is much more important on a drop-bar bike than a flat-bar bike (IMO) and even more so for an aggressive frame.
As @delbiker1 notes, you can adjust bar height (seat-bar drop) with spacers and stem. You can also try different bars---drop bars come with varying drop and reach. As he notes, it takes time and miles ... and also, as your body develops the specific muscles, your "correct" fit will change ... and change again during the off-season ...
Ge the seat right first--height and fore-and-aft position relative to the pedals. Then start experimenting with the bars. My high-tech solution is to park my bike next to the washer-dryer, with one foot on the pedal and the other on a small footstool, so I can balance and still approximate sitting and riding. Then I lean forward however much is comfortable, swing my arms down so my elbows are still a little bent, and that is about where I want the hood (I normally ride on or just behind the hoods.) I get whatever stem/spacer/bar combo is going to put the bar where I need it.
Maelochs is offline
Likes For Maelochs:
Old 06-04-19, 09:02 AM
Jrasero
Quoted: 23 Post(s)
I am 5'5", Bike is a 49cm, the day I took that picture the seat was too high and that might explain the back pain
Thanks for the advise I probably will look into a riser stem to give a slightly more up right position
Jrasero is offline
Old 06-04-19, 09:19 AM
Jrasero
Quoted: 23 Post(s)
Also any advice on a comfortable saddle the Syncros one is killing me lol. I can get a Selle Italia C2 Gel Flow Saddle for half off would that be any good?
Jrasero is offline
rumrunn6
rumrunn6's Avatar
Quoted: 3021 Post(s)
Liked 97 Times in 84 Posts
strobes front & rear
rumrunn6 is offline
Likes For rumrunn6:
Old 06-04-19, 09:49 AM
delbiker1
delbiker1's Avatar
Quoted: 182 Post(s)
Saddles are one of the most difficult things to fine comfort in. What works for me will not work for others. It is very size, body shape, bike fit, material, type of riding, position, etc., specific. See if one of your local shops has test saddles for you to try for a couple of rides. For me, I need narrow in the transition area, relatively flat on top and not too much padding. Most will agree that any saddle takes some time and miles to actual find if it is comfortable for you. I have saddles that I did not like and stopped riding them, only to give them another try later, and find that are comfortable if I give them a fair try. Others have been comfortable from the first use, to finding they are really bad for longer rides. The saddle is one of the most important aspects of riding a bike, and one of the hardest to get right. I have a couple of saddles that I paid a good bit for that are now just taking up space. I have one saddle that I bought new for $14 and is very comfortable. I use that one on my commuter, errands and beater bike.
Old 06-04-19, 09:58 AM
Jrasero
Quoted: 23 Post(s)
lol I am getting the common trial and error advice. I can see why cycling even if not serious can be very expensive. I might get the Selle Italia since it's on Back Country and they have free 30 day returns...
You are probably right since a lot of biking is subjective even if there are some optimal performance suggestions
Jrasero is offline
Phil_gretz
Journeyman Bike Commuter
Phil_gretz's Avatar
Bikes: '71 Jeunet 630, '79 Peugeot PXN10LE, '88 Fuji Saratoga, '13 Motobecane Fantom29 HT, '16 Motobecane Turino Pro Disc, '16 Motobecane Gran Premio Elite, '18 Velobuild VB-R-022
Quoted: 566 Post(s)
Liked 71 Times in 47 Posts
Get the fit right first...
Not good. My suggestion would be to get the fit correct on the bike first. Saddle height, saddle fore/aft positioning relative to the bottom bracket, and saddle pitch all contribute to getting your weight balanced correctly on the bike. Then move the handlebars to suit your reach, flexibility, core strength, and power level.
Only then can you begin to evaluate whether or not the saddle is any good for you. The one that you have might be fine, with all of the other variables sorted out.
Get the bike to fit properly first. Spend your time, brainpower, and money there.
Phil_gretz is offline
Old 06-04-19, 10:03 AM
Phil_gretz
Phil_gretz's Avatar
Quoted: 566 Post(s)
Just to add that these ^ adjustments rarely are done in one day. Small adjustments will make substantial changes in your comfort and performance on the bike. If you have access to a bike trainer (that you can borrow for a few weeks) that'd be a good way to make an adjustment and compare your riding result.
Make measurements and keep detailed notes. Read and re-read what your observations are as you make adjustments. Subjective is one aspect, yes. Random is what you want to avoid.
Old 06-04-19, 10:18 AM
delbiker1
delbiker1's Avatar
Quoted: 182 Post(s)
I am not going to give you untruths as advice. I can only relay to you my own experience. If you get only humor out of it, that is your perception and has nothing to do with me.
Old 06-04-19, 10:36 PM
Teamprovicycle
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 314 Post(s)
if you already did 50 miles on it why do you need advice , and what advice do you need , a trek fanboy would tell you to throw that POS in the trash can and get a emonda , thats a real roadies , bike , this post is way to open for silliness !!!!!
the bike is what you choose ride it and enjoy , what advice could a person give you , up wear your helmet ( crash and land on your hips and elbows every time ) , put a reflective strip on your back and shoes , ect ect ect !!!!!!!
Teamprovicycle is offline
Old 06-05-19, 11:34 AM
downhillmaster
Quoted: 391 Post(s)
Liked 59 Times in 38 Posts
Lots of good advice here.
All I would add is don’t feel like you have to spend an excessive(or any)amount of time in the drops until you rack up some miles and are somewhat dialed in on fit.
downhillmaster is offline
Old 06-05-19, 02:28 PM
Jrasero
Quoted: 23 Post(s)
lol nah all the advice on here has been good. There defiantly is a difference between a race oriented drop bar bike and flat bar road bike, hardtail, and hybrid which I used to own. I get what your saying, just go out and ride and a lot of things will just come over time.
Jrasero is offline
Old 06-05-19, 02:30 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6833 Post(s)
Liked 211 Times in 176 Posts
Spend time at your favorite bike shop to get the right size and fit..
fietsbob is offline
Old 06-05-19, 03:00 PM
NomarsGirl
NomarsGirl's Avatar
Bikes: Specialized Ruby Sport
Quoted: 148 Post(s)
Liked 28 Times in 20 Posts
I was very nervous about switching from a hybrid to a drop-bar road bike. I'm actually loving my new bike and it has seemed pretty comfortable from day 1. My butt has adjusted nicely to the saddle which looked extremely uncomfortable to me at first. I haven't ridden more than 40 miles at a time on her yet, but I felt no pain after that ride. Next up - 50 miles.
The bike store gave me a credit toward a bike fit with the purchase of my bike and and I have a credit from the old bike that they sold for me. I'm just not sure I need to adjust anything.
NomarsGirl is online now
Old 06-06-19, 02:22 PM
Wilfred Laurier
Señor Member
Wilfred Laurier's Avatar
Quoted: 322 Post(s)
Liked 61 Times in 42 Posts
I have the saddle you mentioned and I find it comfortable. However, I do not give you permission to use my arse for your bike rides, and your own arse might be shaped differently, so this comment is pointless and should be ignored.
Wilfred Laurier is offline
CanadianBiker32
Training & Nutrition
17
03-20-14 09:35 AM
Calminian
Triathlon
24
04-03-09 02:37 PM
army14
3
03-26-09 11:10 PM
monkistan
Fifty Plus (50+)
20
10-29-08 03:25 PM
will dehne
0
10-14-07 10:42 AM
