Disc brakes vs rim brakes on Giant escape
Quoted: 10 Post(s)
Found a Giant escape 3 with rim brakes for $250. Looking for a bike to get started with, but I was under the impression that disc brakes were the way to go. Any input?
If you go the used route, you have less choice for modern features.
For new I definitely would go disc, but for used older options are OK. That is part of the lower price. Same with drivetrain options etc.
Just make sure it is not that rotton bad bottom level Escape with freewheel, that will severely limit drivetrain options.
Quoted: 576 Post(s)
Liked 1,002 Times
However, realize that V brakes were a bigger game changer than disk brakes were. When Vs appeared, cantilevers instantly disappeared from all MTBs, it took disks about 15 years to take over MTBs.
Quoted: 1188 Post(s)
Liked 1,154 Times
For 250 bucks it doesn't matter. Though unless its very new 250 for a 350 bike seems steep. Just get some good aftermarket brake pads like Koolstop or Jagwire with replaceable pads in metal holders, adjust them well and ride the wheels off it. V brakes work very very well when set up properly.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
- Cost; it costs less to build a bike with linear pull brakes (compared with cantilevers) because they're easier to setup and require fewer parts (no straddle cable, etc). Shimano's staddle cable simplified setup of cantilevers, but also worsened the performance of the brakes in many cases. Linear pull brakes cured all of that, and they were cheaper, too!
- Compatibility and standardization; no frame changes were required -- they were designed to work with standard cantilever mounts, so design changes to the frame could be avoided. They didn't even need different hubs; all they needed were long-pull brake levers (which are interchangeable, from a cost perspective, with short-pull brake levers). They were literally bolt-on parts using the then-standard design (cantilevers), which had been standardized across the industry for three or four decades or more at the time.
I think it's fair to say that disc brakes have completely disrupted the cycling industry, from design considerations (all of the various standards) to regulatory considerations (what will be allowed in racing). Linear pull brakes, such as Shimano's V-brake, were an evolutionary design from the already-standard cantilever, making its adoption cheap and fast.
Liked 762 Times
I think it's mostly up to personal preference. The good thing is you have a lot of options to try. You can go to any bike dealer and try bikes with linear pull brakes, mechanical disc brakes, and hydraulic disc brakes. Ride all three options with an open mind and see what feels the best to you. I suspect you'll walk away from that experience knowing exactly what you want. If not, if one type doesn't speak any stronger to you than another, then that's good to know also -- you have more choice in the used market!
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 208 Times
Liked 208 Times
Besides, old fashioned V brakes are inexpensive, replacement pads are cheap, and they are easy to set up and work great.
IMO, you don't really need disc brakes on a hybrid or a road bike, unless you live in the mountains and/or ride a lot in the rain.
I understand that it is s concern not having the latest technology, but to a certain extent, almost every cyclist who has been riding for more than a couple of years is probably riding on yesterday's technology. My preferred bike has cantilever brakes, which are really old school. Yet somehow, I have managed to survive and keep my bike in good repair. (and I have no plans to replace it)
I would keep your eyes peeled on CL now that summer is almost here. Folks are cleaning out their basements and garages these days. I wish you lived next door, we would have fun getting you into the best of pastimes.
stil your choice..
Oldest is drum brakes , no issue in 3 decades.. , newer is disc brake ,
these Bikes see use in the foul weather..
summer and good weather recreational rider , probably don't need disc brakes ..
Particularly if you are so cost conscious..
I just realized it is the 3, with freewheel. It only cost $400 new. $250 is a ripoff. The components are almost Walmart level. The only thing it has over a Wally bike is a sealed cartridge BB, which cost $15. At least get a 2 with freehub. Or negotiate price to $100.
The low level LBS bikes basically trick you with the brandname. You basically never upgrade anything on those economically due to the bad base. For example upgrading to a cassette for 8+ speed would require a new hub/wheel.
The only thing I disliked about my rim brakes when I owned my road bike vs my disc brakes on my dual sport 2 is the fact that my disc brakes stop slowly or instantly depending how hard i pull the brake lever, the rim brakes either didn't stop fast enough or they were too abrupt in how quick they stopped if I pulled the handle hard. Honestly though, they both work great and for $250 I wouldn't be picky. I just like my disc brakes because they require less maintenance and look better on the bike.
Quoted: 576 Post(s)
Liked 1,002 Times
I think the primary reasons linear pull brakes took over almost immediately are:
For the industry, it freed frame design from the constraints of having a centered hanger. This was huge and opened the way for modern suspension design. Marketing took over and pushed strong brakes on consumers, but this was a win win. Slight changes were required -stops and beefier stays but were minor.
Most bike parts are bolt-on; but to keep it relevant, suspension at this point in time had just been accepted as the way forward and was heavily marketed as an aftermarket item. However, many (including I) held out and rigid steel is still a thing - unlike cantis. Even thumbies are a thing, but not riding cantis on MTBs. Another example is X+1 speeds - its just a few parts away...
After disks were mainstream in MTBs, many high end XC rigs were still Vs for a long time. High end V performance and lower weight kept Vs viable. Many rigs were disk front and V rear.
Road bikes and the UCI have understandebly have been slow to adopt to disks, but seeing how far back disks on bikes go, its hard for me to see them as disruptive. News of Camapgnolo working on disks was out for years. Read about disks in 92, got disks in 99, road bikes get disks deep into the 2ks..... Hard to see it as disruptive IMO.
V brakes are bolt on, but nobody would have bolted them on if they weren't an improvement.
Back to OP, 250 for a G Escape is too much IMO.
Liked 762 Times
Back to cantis, there are some very good ones made today, and many feel that their performance is every bit the equal of linear pull brakes with similar pad compounds and correct setup. That's where linear pull brakes really took an edge -- they're dead easy to setup. Traditional cantilevers can be very enjoyable to tune and use, if you're inclined to that. With some understanding of the maths involved, one can tune the mechanical advantage in a variety of ways, and really get superb performance out of them. It takes time and effort, though, which are two things linear pull brakes don't require to set working well. You bolt them on and go. I'm not saying that's a bad thing -- quite the opposite in fact. It make good braking accessible to those who didn't know how to, or what to, fiddle with their cantilever brakes all day.
I have a set of modern cantis on my 1997 Trek 750. Great bike, and great brakes. I had linear pulls on it for a while, but switched back to cantilevers for the more traditional look. And I still have my first "big boy" bike, a 1993 gas pipe MTB. It came with low profile Shimano cantis back in the day, and I put Avid linear pull brakes on it some years ago. I still use that bike some, though admittedly fairly infrequently.
Quoted: 5224 Post(s)
Liked 3,581 Times
my rim brake road bike slows &/or stops just fine. my MTB has disc brakes & I like them cuz sometimes I have steep descents & they do a much better job than the marginally effective rims brakes in those situations. if you don't think you be going down steep hillsides, I suspect rim brakes will be fine
Quoted: 10 Post(s)
Thanks to all for the info, very helpful. It's hard to get solid information online since most of what I read is someone trying to sell me the bike. I'm sure things will make more sense after I get some actual miles in and see what works -- just don't want to start completely blind. I'm not opposed to spending a bit more if I know it's going to be decent.
What I've learned -- embarrassing but I assumed the Escape 3 was an upgrade from the Escape 2.. obviously not so I'm going to hold off. Would make sense to buy new at that price.
I also need to consider my terrain, I'm in the mountains and will have some hills. Also don't mind short rides to work in rainy weather so would like my bike to handle that too.
Still on the hunt.
Likes For Wishiwasabiker:
Quoted: 576 Post(s)
Liked 1,002 Times
This is a good point, about suspension fork design. Traditional cantilevers can work with suspension forks, but it's a more difficult design, with a cable stop required on a tall arch. It's not a very elegant solution (though some forks designed for this look pretty cool), and linear pull brakes made this a lot easier.
This is what I meant about "disruptive". Most bike parts are bolt-on, but disc systems are not. They required fundamental design changes to bicycles, including considerations for fork design (including blade structure, etc), frame design, etc. It started with simply welding on an IS tab on the rear seat stay, but this has evolved slowly into disc-only frame designs. Disc brakes took over the MTB world fairly rapidly, but have seen much slower adoption in the road cycling world. I think a lot of this has do to do with the nature of the two segments. MTBs themselves grew out of a very non-traditionalist mindset, where cyclists cobbled together whatever they needed to build something to go off road. There was no tradition, no "right way" to do something. You made what you had work and any new component that improved your performance was welcomed. Linear pull brakes and front suspension in the 1990s. Disc brakes and full squish in the 2000s. Etc. In comparison, road cycling tends to be driven by tradition and provenance as much as anything else...and of course the heavy hand of the UCI.
If you think that disks were (are?) more disruptive, that's great but that was not my point: The performance increase from cantis to Vs was much larger than the one from Vs to disks.
In 93 I was in college, working in bike shops, and occasionally racing XC mountain bikes. Bike-wise, I just bent the forks on my beloved Haro Extreme and was building up this 21 lb steel hardtail
I still have cantis also, but that's not the point. V brakes were the first brakes that worked for off-road biking. Just about any brake is adequate for city riding. V brakes gave suspension design more freedom, and the increased traction benefited from the increased braking power. Cantis were not up to the task due to routing issues, vulnerability from monkey motion, placement issues, and lack of performance in off-road steeps.
For those who follow GCN on youtube, they just released a video on the benefits and drawbacks of both brake systems on their Tech Show Ep. 76. The video is 34m long but don't worry, the rim vs. disc section is only the first 12m. I thought they did a very balanced and thorough job of talking about pros and cons for both, which reinforced my purchasing decision (hydraulic disc) but also made me fully understand why someone else with different riding needs and priorities would choose rim brakes.
Honestly properly set up cantilevers perform great. I use them instead of V-brakes. Cantis don’t have to be spaced as close to the rim as a V and give far more clearance in sloppy conditions. But to each his own.
Yes, properly set up rim brakes can be effective enough, but for me the main advantage of hydraulic discs is the ability to use most of their potential with one finger, which means that I can hold a finger on the lever at all times, thus being ready to stop instantaneously, without compromising steering control.
For me it's all about stopping power. GCN did a test on superbikes that showed disc brakes, in normal weather, stopping a bike much faster (i.e. over less distance) than rim brakes. I believe they were using their typical superbikes, so it should have been top-tier vs. top-tier gear. And the rider (Simon, I believe) still prefers rim brakes for many reasons, but the improved stopping power from disc brakes was not in question from that video's results.
I live in a very traffic-heavy city, so most of my riding is among cars. And to be honest, Los Angeles drivers are overall...not great with regards to cyclists. So I will value my disc brakes ability to stop faster, and potentially avoid me getting hit, over any weight/aerodynamic penalty, increased maintenance, higher cost, etc.
If I were a professional rider/racer, I might feel differently. But for me, the one thing it's (almost) universally agreed that good hydraulic disc brakes do better than rim (stopping power), is the one thing I prize above all else for my daily riding situation.
crankarmbreaker
24
10-29-18 11:59 AM
Jarrett2
27
08-22-13 03:36 PM
