Dahon Mu Uno... damaged? Help please!
Quoted: 7 Post(s)
Hey everyone,
I recently picked up a Mu Uno from facebook Marketplace. I didn't notice notice week or so after that it's bent . The handle post looks to be bent off to the right. I tried to post a pic but I'm not allowed yet
Seller has disappeared, I'm now hoping to repair. Just wondering if anyone can shed any light on the most likely culprit... forks or stem? And where to buy replacement.
Many thanks
Many thanks
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
Is the handlepost actually bent, or, is it just installed askew?
Likes For Nyah:
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 275 Post(s)
Liked 245 Times
As you are UK based, you could email CH white in Malmesbury or give them a call .
Quoted: 7 Post(s)
Thanks for the replies... I'm not allowed to post pics yet as I haven't done my 10 posts.i have tried rotating the handlepost, but it is then off axis with the wheel direction.
if possible i could dm a pic to someone to be posted on my behalf?
Thanks
Thanks
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 460 Post(s)
Liked 410 Times
If you are referring to the hinge being set off at 45 degrees from center, that is the way it must be for the handlebar to fold down parallel to the bike frame.
Paul Pinigis
Owner of Origami Bicycle Company
Paul Pinigis
Quoted: 7 Post(s)
Hi, thanks for the reply. I'm not referring to the 45 degree angle... it looks as though the handlepost is tilted slightly to the right! If I rotate on the steerer tube of the fork so that the angle looks correct the handlebars are out of line Pretty sure it's damaged
Quoted: 7 Post(s)
QR-disc must die!!!
Quoted: 397 Post(s)
Liked 199 Times
If the handlepost needs replacement, that's not very difficult to do, assuming you have a threadless headset. Post a photo so that we can confirm your problem. Up your post-count by posting in this thread. No one will consider it spamming.
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Quoted: 172 Post(s)
Liked 95 Times
Dahon had a post recall, Had to replace mine on a Curve. Easy peasey.
Check for the recall. Had cracks in the securing wedge of hinge IIRCC
Quoted: 275 Post(s)
Liked 245 Times
They had a problem with the clamping undercut that clamp the steerer on the fork. the undercut receiving the hinge locking slider was too sharp causing stress raiser eventually cracked. The later revised model has a rounded shallower undercut.
Likes For Fentuz:
Quoted: 7 Post(s)
ok, this is interesting. Wonder if it applies to mine?
QR-disc must die!!!
Quoted: 397 Post(s)
Liked 199 Times
This view is probably the best one to discern what's going on.
However, the view isn't really close enough. If you get really close to
the headtube, can you see light between where the handlepost, headset
and/or the headtube come together on the non-drive side?
Remove the handlepost and start looking for any signs of damage.
Is the top of the fork steerer tube bent where the handlepost clamps onto?
Does the top of the headset look mashed?
If you stand the handlepost up, with the bottom flat against a tabletop,
does it still look bent - If so, the handlepost is either damaged or
malformed to begin with. If this is the case, it's not difficult or expensive
to get a new handlepost.
Likes For Nyah:
Quoted: 275 Post(s)
Liked 245 Times
As per other comment, it looks like the plastic top headset part is crushed as if it has a big side impact.
You will need to open the stem, undo the clamping bolt and fork threaded cap to establish if the headset is dead or the fork steerer is bent.
Have you got close-up pictures?
Have you spoken to CH White in Malmesbury?
Likes For Fentuz:
I think the fork steerer the stem is clamped to is bent.
Likes For Joe Remi:
Quoted: 275 Post(s)
Liked 245 Times
QR-disc must die!!!
Quoted: 397 Post(s)
Liked 199 Times
Quoted: 595 Post(s)
Liked 679 Times
Fork Stem is likely bent.
You check for damage on the handlebar stem too.
If you can, you'll need to unscrew the center retainer (10mm) and the 2 side compression screws (5mm?) and take a look at the fork stem.
