How do I pump this tire ??
Old 06-14-21, 03:47 PM
Tee tee
Quoted: 8 Post(s)
How do I pump this type of bike tire ? The bead in non removable . My little bike pump won’t work on this.
700c for bontrager tire
Tee tee is offline
Old 06-14-21, 03:54 PM
Iride01
Iride01's Avatar
Quoted: 6196 Post(s)
Liked 4,810 Times in 3,318 Posts
You mean tube? Or is this one of those weird tires that are tube and tire in one... but it sure looks like just a tube.
It's a presta type stem. You need an air chuck for presta valves. You have to unscrew the tiny knurled nut with the small threaded shaft coming out of it first. 3 turns maybe. Don't force it if it stops sooner after loosening.
If your pump is a bicycle pump, they usually include both presta and schrader chucks. Many I've used you just unscrew the end of the chuck and turn the piece it holds in around. Some have an adapter. But I don't care for them.
Iride01 is offline
Old 06-14-21, 03:58 PM
Tee tee
Quoted: 8 Post(s)
This is just the tube . Can you post a link with the pump and valve I need ? Everything included would be best! Thankyou !
Tee tee is offline
Old 06-14-21, 04:14 PM
dsaul
Quoted: 714 Post(s)
Liked 800 Times in 475 Posts
Loosen the little nut on top, so air can flow into it and put one of these adapters on it. https://www.amazon.com/Bike-Bits-Bra...3708704&sr=8-5
You can find them at most bike shops for a couple of dollars or less. Or, get a pump that works on Presta valves.
dsaul is offline
Iride01
Iride01's Avatar
I just use a Zefal bicycle floor pump that I got from Walmart or Target 15 years ago for $10. It has a gauge on it. I had to replace their air chuck after about six years. I got a generic replacement hose and chuck that is also changeable to presta or schrader. It was about another 4 bucks. But was better quality IMO than the original Zefal air chuck. It's just now showing signs of needing replacement as it's hanging on to the stem even after the lock is released.
Here is a link to Walmarts list of pumps they have. Pick one. https://www.walmart.com/search/?cat_...icycle+floor+p
Get at least a floor pump. Those small pumps for you to carry with you on your bike take forever to inflate your tires. They were bad enough on 18 mm tires. With many using 28 and 30 mm tires, you'll wear yourself out and be too tired to ride. Get a CO2 inflator for road side flats.
Others might be along to suggest what they feel is the best pump. But I'm a cheapskate when it comes to floor pumps. Most any will do. I've got an older bell pump that still works. But it has that adapter thing you screw on to the end of the presta valve that I don't like.
Iride01 is offline
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
That's a 100% completely normal, comes on virtually all bikes over about $400.00 presta valve. Your pump will most likely work on it as posted above...how about you post a photo of your pump so we can confirm.
cxwrench is offline
Old 06-14-21, 05:17 PM
Tee tee
Quoted: 8 Post(s)
Will this one work ? https://www.amazon.com/Letton-Portab...a-476134146396
Tee tee is offline
Old 06-14-21, 05:22 PM
SoSmellyAir
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times in 1,020 Posts
Originally Posted by Tee tee
Yes, per Amazon product page you linked; fourth picture from top (on Amazon product page) shows Presta valve.
SoSmellyAir is offline
Old 06-14-21, 05:42 PM
sincos
Quoted: 98 Post(s)
Liked 127 Times in 74 Posts
Yes but before getting a new pump check the one you have. Many pumps have a reversible chuck or (more commonly) reversible insert in the chuck which in one direction is for Schraeder (like you find on cars) and in the other direction Presta.
sincos is offline
Old 06-14-21, 07:48 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
After loosening the nut on the valve stem, "burp" the valve by pressing down on the nut to release it if it has gotten stuck closed.
dsbrantjr is offline
Old 06-14-21, 07:49 PM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times in 1,439 Posts
There isn’t a $10 floor pump made that’s worth even half that. Spend a little and get a Topeak JB or a Specialized. Buy once, cry once.
YouTube is full of videos about using tubes. Here’s one now:
Rolla is offline
Likes For Rolla:
Old 06-15-21, 08:02 AM
pdlamb
Quoted: 2604 Post(s)
Liked 1,933 Times in 1,213 Posts
Very true. I think I'd go to the bike shop and spend $2-3 for a Presta adapter, and use my car (or service station) inflator before I spent $10 on a bike pump.
Like so many things, if you plot quality versus cost you'll get an S-shaped curve. At $10 the question will be, can you use this to pump up two mountain bike tires to 30 psi within a half hour? A low-priced $30 pump from the bike shop IS going to work -- and you can ask them to show you how to pump up your tires.
pdlamb is offline
Old 06-15-21, 08:25 AM
Iride01
Iride01's Avatar
What floor pump have you ever used that you couldn't pump up two mountain bike tires in way less than 30 minutes? A frame pump or mini pump, yes, I can see your point for those.
Iride01 is offline
Old 06-15-21, 08:31 AM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 527 Times in 349 Posts
That little "bead" just needs to be loosened. The valve is a "Presta" valve. Your pump is probably set for Schrader valves (much wider). Try reversing the pump head.
jadocs is offline
Old 06-15-21, 09:16 AM
pdlamb
Thank you for answering your question for me!
pdlamb is offline
Old 06-15-21, 09:18 AM
Iride01
Iride01's Avatar
I'm not going to assume anything about what you were talking about. That's why I ask. I still don't know.
Iride01 is offline
