Touring wheelset Qs
Touring wheelset Qs
Old 02-10-12, 02:32 PM
you
Bikes: Schwinn Voyageur '89
Quoted: 10 Post(s)
Touring wheelset Qs
Hi there, I'm looking to build a new wheelset for my everyday bike/tourer (currently running 27" single wall Wolbers laced to old shimano hubs). I've got a spare CR-18 kicking around that I was going to lace to a dyno-hub and then set up a rear wheel with an asymmetrical rim (velocity synnergy) and a 130mm rear hub (bike is currently spaced to 126). The velocity rims, however, are wider (only by .5mm) than the CR 18. Could this pose any problems at all? Also, is the general wisdom in the touring community to use butted or straight gauge spokes?
you is offline
Old 02-10-12, 03:13 PM
sstorkel
Bikes: Cervelo RS, Specialized Stumpjumper FSR Pro, Schwinn Typhoon, Nashbar touring, custom steel MTB
Quoted: 8 Post(s)
Differences in width shouldn't be an issue, assuming the tires you want to use will fit the rim. I frequently replace my Velocity Synergy rear wheel with the 19mm wide PowerTap wheel from my road bike... I'm a bit fan of butted spokes, but plenty of people seem to use straight-gauge spokes without problems.
sstorkel is offline
Old 02-10-12, 05:38 PM
pdlamb
Quoted: 2604 Post(s)
Liked 1,933 Times in 1,213 Posts
0.5 mm? Pfft. Your pads will wear that much on a short stretch in the mountains.
There's a slight advantage to butted spokes on the non-drive side of a rear wheel; unless your tour is a Tour d' Something, straight spokes will do fine.
pdlamb is offline
Old 02-10-12, 06:55 PM
bradtx
Bikes: Cannondale, Trek, Raleigh, Santana
Quoted: 308 Post(s)
Liked 4 Times in 4 Posts
you, I prefer DB spokes. That said, the first wheelset I've bought in many years with straight gauge spokes were for my tourer and I've been happy with them.
Brad
bradtx is offline
Old 02-11-12, 11:31 PM
nubcake
nubcake's Avatar
Bikes: Gunnar Crosshairs, Giant Trance, Felt Breed, Marin SS MTB, Felt Pyre BMX bike, oldschool GT trials bike
Another vote here for DB spokes, your build sounds like it should work well assuming it is properly tensioned but that can be said for most wheel builds.
nubcake is offline
Old 02-11-12, 11:59 PM
fuzz2050
Real Men Ride Ordinaries
fuzz2050's Avatar
Quoted: 17 Post(s)
Liked 3 Times in 3 Posts
Double butted spokes are better, and worth the few extra cents per spoke, so if you're building from scratch, there is very little reason not to. However, the advantages (durability more than weight) are not nearly worth the hassle of rebuilding a wheel.
fuzz2050 is offline
Danny01
Touring
39
12-09-17 03:06 PM
Wheels Of Steel
Touring
25
11-05-12 11:45 AM
slims_s
Road Cycling
12
08-29-12 04:06 PM
lucky1976
Touring
16
10-09-11 05:29 PM
Deathmobile
Touring
17
04-12-10 06:24 PM
