difficulty threading cable trigger shifter
cyclotourist
Quoted: 443 Post(s)
Liked 205 Times
Replacing the cable on a low end Shimano ML 360 trigger shifter.
took the top plate off the shifter and managed to coax the old cable out, but I cant get the new cable in.
It seems like it has to go around a corner and thread into a little hole that you cannot see. I've been trying all afternoon with no luck.
Am I missing something?
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
make certain the shifter is in the relaxed position by clicking the shifter until the indicator moves to the 7 or 8 position, whichever is the highest number...
Now the cable SHOULD slip through the hole in the Reel towards the Adjuster... now.. REMOVE THE ADJUSTER..(There is a SPRING INSIDE! Be ready!) they are a serious pain to thread a cable through... push the cable through where the adjuster was... now pull the cable through the reel until the lead barrel seats into the reel... DO NOT Kink the cable... Any kinks WILL cause problems with shifting!
now, slip the adjuster, spring, and grip deely backup the cable to the shifter and re-thread it into the Shifter body.
Likes For maddog34:
cyclotourist
Quoted: 443 Post(s)
Liked 205 Times
When I shift it into 7 or 8 position I can no longer access the little socket that holds the head of the cable.
However. I advanced it as far as I could, threaded the cable end through, wiggled it a bit and it went through. It was a bit tricky getting the end through opening where the adjuster
threads, but it worked.
You sir, are a genius. Much thanks.
I have three of these types of shifter, and this was definitely the trickiest.
Likes For skookum:
Liked 739 Times
