Shimano 105 RD with a 28T cassette?
Hello,
I need advice. I have a Shimano 105 Model RD-5501 GS Long Cage Rear Derailleur but being used with a double crank. The Shimano tech specs says it can handle a 27T maximum largest rear gear.
I intend to install a 12-28T rear cassette, will it work? It's one tooth over max specs.
Any experiences/advice/theories would be appreciated. I dont wish to buy it and find out it wont work.
Thanks
Thanks
Bikes: Surly CC, Raleigh Team Pro, Specialized Rockhopper with an xtracycle
It should work. I had an ultegra short cage (27t max) paired with 11-30 and it worked fine. I've done it with a 53/39 and a 50/34.
Likes to Ride Far
Whether it will work depends at least as much on the geometry of the derailleur hanger on your frame as on the derailleur model. Shimano spec's tend to be pretty conservative, so it's likely that you'll get the 5501 to work without any trouble - I've certainly made a 5600-series RD (which is also only officially rated up to 27 tooth cogs) to work with a 28-tooth cog, I don't think I've tried with a 5500-series. But again, a lot depends on your frame. Your chain length can also affect whether or not it will work, because that determines where the upper pulley ends up.
I'd recommend going ahead and buying the 12-28 cassette, there's a very high chance that you'll be able to make it work without any problems.
totally louche
Bikes: the ever shifting stable loaded with comfortable road bikes and city and winter bikes
Liked 10 Times
I've run 11-32 with 105 derailleurs on a couple of bicycles and seen this setup on several other bikes.
Should be fine check chain length and make sure upper wheel on RD isn't touching the 28t if so you will need to adjust B screw a little.
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
I just tried installing a 12-30 matched with a 105 5600 long cage and had issues getting into the largest cogs.
When I tightened the B-tension screw I could shift into the 28t cog, but that seemed to be as low a gear as it would go. I am also running a 53/39 up front.
Any recommendations? It seems from what I've read here than it might be possible.
Has anyone made this set-up (53/39, 12-30t, 5600 long cage DR) work?
Quoted: 2026 Post(s)
Liked 1,096 Times
The real cure in your case is to limit your cassette to a 28T maximum, replace your rear derailleur with a MTB model (9-speed or before, not 10-speed Dyna Sys), or a newer road rear derailleur rated for 32T like the Ultegra RD-6800.
Thanks. It's what I suspected, but I think I just needed to hear it. Also, for the suggestion, the Ultegra 6800 RD looks pretty sharp. It is something I am going to consider. Now my immediate question is do I return the cassette, or keep for future use.
daoswald
General Cycling Discussion
4
01-27-19 03:59 PM
biketampa
50
11-10-18 05:49 PM
Ozan Guner
16
04-07-13 02:18 PM
