I probably already know the answer
Bikes: Dawes SST Al (2011) Trek 1000 (2003?)
But being that I'm in the market for a new bike I'm torn.
I know the generic answer is usually kilo tt (or pro if its even worth the upgrade) but how does it stack compared to the langster? I like the langster but at the same time since a kilo is so much cheaper than the langster (even on sale) is the carbon fork reallyt worth the extra money? Or should I just go ahead and buy the kilo and then upgrade as needed with the extra money?
Edit: Does the kilo tt (or pro) have 2 water bottle mounts or jsut the one?
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 765 Times
What type of riding do you plan on doing with this bike ? The Kilo TT has track geo and would be a good choice if you plan on riding / racing at the Superdrome with it's steep banking. The aluminum Langster is a great road bike with slack geo and a low bottom bracket, but would be a poor choice for the track. The Langster is a better quality bike than the Kilo TT, which is why it costs more; that's usually the way things work.
This purchase is going to be mostly for fitness/commuting in combo with my trek 1000
Veteran Racer
Liked 765 Times
Well, the Langster is a good choice as a street machine. It's set up as a single speed (freewheel), not fixed gear, although I believe it can be converted to fixed. Stock gearing is 42 x 16, which is an easy 69 gear inches with 700 x 23c tires. It comes with 2 water bottle mounts, whereas the Kilo only has one or none. I agree that you should first use one of the GT rental bikes before buying a dedicated track bike, and I'd look for a used one for sale on the TXBRA forum classified when you decide to buy one.
Bikes: Specialized Tarmac Expert, Cannondale R700, Specialized Langster, Iron Horse Hollowpoint Team, Schwinn Homegrown
Brown Bear, Sqrl Hunter
My friend's Kilo TT Pro has holes for 1 bottle holder, mine had none.
Problem is the lightning is a bit more than I want to spend at the moment. The classic would be the most I'd really want to go and even then that is pushing it since I can't get a test ride on it first
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
Oh I see your point; what's your price range by the way? It is crucial that you disclose that so we can recommend you things... it stems to the kilo tt answer trend here.
I don't mind purchasing online Id just like to have something that uses a similar frame/material that I could go get a feel for.
THE STUFFED
Quoted: 361 Post(s)
Liked 20 Times
Nobody bought them, they melted them all down in the end to make the FTP's sold at nashbar.
One last question, if I do go with the Masi what would be a good affordable wheelset to get thats thinner? stock it comes with 32s and that seems like a lot of rolling resistance (least if I read the specs right) I was thinking maybe some 28s or 25s even?
Veteran Racer
Liked 765 Times
More important is tire quality and design. Large low pressure hybrid tires often exhibit high rolling resistance, whereas higher quality / pressure slicks offer about the same rolling resistance as much narrower tires. The only real difference is weight, which you only notice on a overall lightweight bike with light wheels.
Made Of Modern
Track Cycling: Velodrome Racing and Training Area
27
08-09-12 05:04 PM
