Fixed Gear "skipping" when accelerating / skidding / pedaling
Yooo, so recently, while i ride my fixie... I started to get these weird "skipping" motions while i either pedal/accelerate/skid. as if i were to be changing gears or something. so if i were to pedal/skid/accel, it would have some jerking motion :3 why is this? a friend told me it was because my lock ring was loose. so i tightened it and it still happened. any ideas?
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
Your cog & lockring are loose. Properly tighten them with the proper tools (chainwhip for cog; lockring spanner for lockring). Hopefully your rear hub isn't permanently damaged.
Bikes: Specialized Tarmac Expert, Cannondale R700, Specialized Langster, Iron Horse Hollowpoint Team, Schwinn Homegrown
Kilo TT
Just smang it.
Bikes: Felt F1X, Trek 2300 Composite, Dawes Deadeye
Quoted: 20 Post(s)
Btw, the graphic of the stripped threads is not a hub - just an example of what stripped threads in general look like
TEEEJ
Bikes: 78.5 Trek 710 FG Conversion, 90's Raleigh CitySport FG coversion, '98 Specialized Ground Control, '00 GT Outpost SS, Vilano Track Bike
I had the same thing happen to me after tightening my cog and chainring and I made sure it wasnt stripped either. I decided to regrease my bottom bracket that night and when I took out my bottom bracket there was a bearing that had gotten out, I put it back in and no more skipping, you should check that.
EpicSchwinn
Singlespeed & Fixed Gear
28
03-17-11 12:21 PM
Humenbean
32
06-27-10 10:50 AM
