Need help in building my first build - Cervello R3
Bikes: Giant TCR C1 - 16.5 lbs
Quoted: 13 Post(s)
Background:
I've been riding a 2006 Giant TCR C1 in smail size, I'm 5'5" and it is a perfect fit for me and now decided to build a new bike for myself.
Plan:
Just placed an order for 2018 Cervello R3 and going with Ultegra Di-2 R8050 (rim brake). I'm trying to keep my cost low and want to keep the weight to about 16 lbs.
Plan:
- Groupset: Ultegra R8050 - Di-2 - rim brakes
- Wheelset: Mavic Ksyrium Elite UST
- Drop bar: TBD - Looking for carbon aero bars with internal routing
- Stem: TBD
Quoted: 696 Post(s)
Liked 910 Times
Property torque all bolts to spec
use carbon paste
use carbon paste
Likes For Ghazmh:
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Background:
Plan:
Plan:
- Stem: TBD
COMP CYCLIST - CUSTOM R3 RIM
Quoted: 13 Post(s)
Are you doing this for fun or to save money? Just curious, when there's eg. options like below to get this built for you:
Bikes: Trek Domane SL 5
Quoted: 218 Post(s)
Liked 102 Times
Background:
Plan:
Plan:
- Stem: TBD
Quoted: 18883 Post(s)
Liked 10,646 Times
I had an R3 years ago. It's a fantastic bike. You'll love it.
Quoted: 3238 Post(s)
Liked 2,085 Times
Where’s the battery going ?. If in the seat tube, don’t install the bottom bracket till the cables and B Junction box are installed unless the frame has the nifty access port to route cables. If press fit bottom bracket maybe have a shop install as they have the tools.
If putting the b-bracket in the fork, get a stem that provides for the Di2 cable.
Also there some special type of compression plug for the fork that allows an E-Tube cable.
If using the 111 BlueTooth transceiver, maybe consider the XT Di2 display instead. It can replace the A Junction as well as 111 unit, saves about $85. It mounts on the h-bar. Gives you gear indication, 3 E-Tube ports, the BT connection and the charging port. Uses a bit of space on the bar.
Likes For Steve B.:
Vandalized since 2002
Good luck with the build. I absolutely love my 2012 R5. I just got a new set of Ksyriums for it too. This weekend I’ll hopefully be putting the bottom bracket back together. My drive side cup had walked itself a little askew. If it doesn’t take, I might switch it over to a one-piece design. I’ve read about mixed results with these Campy cups, but apparently with the right retaining compound and good prep it should be fine.
Pointy Helmet Tribe
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times
For stem - I'd like to find a lightweight stem that allows me to tuck the cables against it on the handlebar end and where they emerge out from near the steerer end. That would clean up the bike a lot. The Specialized aero stem does that, but it is very heavy. For now, i am using a Kalloy SuperUno stem - lighter than most carbon stems and $20. I've used this for years on my bikes and think this is one of the best performance/$ items out there.
