Washed bike now have squeak when pedaling or coasting
Old 07-05-20, 11:08 AM
rollingsound514
Hi everyone, I just did a wash in what I felt was the proper way (I've watched the tutorials lol) of my Cannondale CAAD12 roadie. I lubed it up like I normally do with some dry teflon lube on the chain and some spray teflon lube in the important bits... go out riding today and it's squeaky as hell, fairly high pitched. Happens when pedalling and when I coast (for a bit after letting off the gas). Where should I start to look? Did I mess my BB?
Thanks guys in advance you usually help me out quite a bit!
rollingsound514 is offline
Old 07-05-20, 11:15 AM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
If it squeaks while coasting, probably not the BB.
tyrion is offline
Old 07-05-20, 11:25 AM
rollingsound514
I'll get it up on the stand some time soon, just got in from ride, I'll try and post a video if the sound can help clue people in.
Old 07-05-20, 12:25 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1791 Post(s)
Liked 1,267 Times in 874 Posts
Hold it up by the front & spin the front wheel.
Repeat for the rear.
It's called isolating the problem.
Bill Kapaun is offline
Old 07-05-20, 02:20 PM
rollingsound514
​​​​​​OK there's the vid, unfortunately on the stand the noise is much harder to hear but it's still there, so it depends on how much torque is involved and if we're bouncing around a bit on the road. It's definitely coming from rear but not sure if pulleys or something else.
Old 07-05-20, 02:42 PM
Kovkov
Kovkov's Avatar
Bikes: 1957 Alpa Special, 1963 Condor Delta, 1967 Tigra Sprint, 1977 Oltenia, 1987 Mondia, 1965 Staco de luxe, 1969 Amberg
Quoted: 117 Post(s)
Liked 76 Times in 43 Posts
I hear a short squeek after like every 4th turn of the crank. That‘s usually the amount of turns the chain needs to do a full revolution. From that i would suggest that a chain link didn‘t get enough lube.
Kovkov is offline
Likes For Kovkov:
Old 07-05-20, 05:12 PM
rollingsound514
You might have been right sir! Despite lubing the chain I always do maybe it was just a miss, I relubed everything and dropped some dry teflon lube on the pulleys just because I'm neurotic. It sounds quieter on the stand at least, real test will be back on the road. Your insight about the frequency of the noise is spot on I think
Thanks!
