Choosing new Bottom bracket size
Hey Y'all!
I'm currently replacing the guts of my trusty Windsor "The Hour" frame. I know that the BB size is 68x103mm, but the crankset I want requires a 107mm length on the BB spindle. How flexible are these sizes? What am I to do? I'd like to mount a Sugino Zen on whatever crankset I choose- any recommendations on affordable but not trash cranksets are welcome.
Thank u guys!!!
Thank u guys!!!
Your cog is slipping.
If you want a good chainline and the right amount of crank arm & chainring clearance, you need to use the correct spindle length and type for your crankset. It's not that hard.
Likes For Scrodzilla:
Quoted: 586 Post(s)
Liked 612 Times
Hey Y'all!
Thank u guys!!!
Thank u guys!!!
https://www.retro-gression.com/colle...bottom-bracket
BTW, you didn't mention which crankset you are looking at. It helps us to know. As far as affordable sets that aren't trash, I would offer these two options. I own a set of the Sugino's and they are 10 years on now and look/act like brand new.
https://www.retro-gression.com/colle...rankset-silver
https://www.retro-gression.com/colle...track-crankset
Likes For TugaDude:
Here you go...
Dave
Here you go...
Thanks for these recommendations. I have a related question, but I'm not looking to highjack the discussion or distract from the OP's question --
I too am looking to upgrade from my stock crankset, because I also have continuing noise and instability that my mechanic advises might be due to the wear of my current bottom bracket (stock).
I'm seriously considering the Phil Wood track crankset with the appropriate bottom bracket (also by Phil Wood) . . .
but this combination will cost approx $800 while the Sugino you recommend is priced much less.
Is the Phil Wood setup worth the extra money?
I'm seeking reliability, the "bling factor" is secondary to me.
My rationale on the Phil Wood gear is that the investment might just last me the lifetime of the bike.
I've recently bought a wheel set with Phil Woods hubs, and it's been a definite upgrade from my previous wheel set which came stock on my bike.
MY USE -- I ride my single-speed as my main road bike . . . my typical rides range from 20-40 miles, and my routes are completely flat. I don't ride track, and I'm never going to race.
if the Sugino gear you recommend has proven reliable for 10 years of your use, it seems to make sense for me to consider it . . . any thoughts on whether the price difference of the Phil Wood setup is worth it for my purposes? Any insight is welcome, thanks in advance.
Dave
Likes For bonsai171:
Quoted: 586 Post(s)
Liked 612 Times
Thanks guys for the insight, I appreciate it
Clark W. Griswold
Quoted: 4356 Post(s)
Liked 3,994 Times
I will say this on the Phil Wood B.B. it looks nice and probably will last forever and in a Phil Wood frame they are a must. However I think my favorite JIS Square Taper B.B. is IRD Defiant QB-95 bar-none. Phil Wood just isn't that exceptional in this instance as from looks.
Now if I am going Sugino 75 or similar and not doing Direct Drive (which why not DD is awesome) I will go with a Sugino 75 B.B. They make a cartridge style if I am using on a road bike or you can do the Super Lap (or Ceramic) if you are a trackie or want the smoothest and are cool with regressing and cleaning with some regularity.
The only reason I would do Square Taper Sugino track would be for a Grand Mighty. Other than that I can now do Super 75 Direct Drive so I really don't need square taper anymore and the dang thing comes with a Ceramic B.B. or I could upgrade to Ceramicspeed if I was really feeling like going homemade Goldschlager with triple the gold leaf suspended in some Balvenie 50 (a rather expensive Single Malt Scotch Whisky)
