Used Bike Friday Tikit (worth the buy)?
Quoted: 151 Post(s)
Liked 10 Times
My Speed Pro TT has the SRAM version. It's heavy,you need to carry a 15mm to pull the wheel,and you have to watch the click box sticking out on the right side,but it def gives you a seriously wide range. Also note,it works with a triple brifter,but can be a bit fiddly at times do to the trimming clicks.
its a shame really. sturmey archer used to be so damn good. the first bikes i bought when i moved to new york after uni were a raleigh sports and a BSA branded girls bike. my girlfriend and i bought them at the 13th street flea market. they were 45 years old and more trouble than they were worth. the only thing good about them were the 3 speed hubs. 45 years old and they worked like they were made yesterday... i'm almost 40 and i wish i could say the same about myself...
Quoted: 113 Post(s)
Liked 8 Times
Bought this new in 1962 .. Sturmey 3 spd worked flawlessly through the years .. would be nice if that level of quality existed today from Sturmey ..
Part-time epistemologist
Now on my tikit, I have a 28 tooth cog with a short cage derailer and I have plenty of clearance. A 42-tooth cog would have a 50% larger radius. Since a pair of teeth will be 1 inch ... the cog will be a little more than two inches bigger.
Hmmmm ... it certainly warrants consideration. I'm not sure. The derailer will be pointed forward on the biggest cog. So the derailer won't be 2 inches lower; but it will be hard to tell without trying it since the (lateral) derailer path will be very steep to make it to a 10-tooth cog and every gear change should raise/lower the jockey pulley about 1/2 inch.
A narrative on bicycle driving.
Tikit recall fix pictures
I've ridden my tikit upwards of forty miles at a throw and feel like I could pretty much ride it as far as any other straight bar bike.
A new 2015 hyperfold tikit with rack and fenders will top $2000. If it's the bike you want - and it's in fine condition - that price seems like a bargain.
BikeFriday recalled these bikes on several occasions, issuing 'dangerous to ride until repaired' warnings. If this is an older tikit, make sure it has the jackleg installed to prevent the seat tube base from breaking, the steerer tube recall completed and the hyperfold cable upgrade.
thanks,
Andrew
I got a 'season Tikit', 2nd hand ,, gear hub Sram 9 speed , internal, grip shifter ..
Hyper fold is so eager to fold , I have to tie a strap around it, so it wont do it when I don't want that..
I discussed all the upgrade and recall parts issues with the seller,
and even got a new threadless headset preload collar from the company ..
replaced the crankset, , seat post , and added my own pedals saddle ..
and stem, different to dial in reach..
You can also check in with Bike Friday on what it would cost for them to update the bike with the various bits for you.
Good luck
Palmer
Quoted: 1662 Post(s)
Liked 1,815 Times
Early handles:
Improved full loop handle:
BikeFriday 'fix' for the early bikes:
Yes, installing this brace blocks the rider from getting a good grip on the handle. Despite that, the brace has to be installed - before the fix, some frames brokes and riders were injured.
Likes For tcs:
Palmer
Liked 1,815 Times
The steerer tube issue affected all tikits. Some original steerer tubes broke, riders were injured, etc, you know the drill. BikeFriday sent out replacements. I think the red dot is what indicates a replacement tube. The replacement tubes also did not have the BikeFriday headbadge.
BikeFriday's superlative customer service took ten months and two weeks to get me a replacement headtube so I could return my tikit to use. After the recall, a rider with a replacement headtube reported a failure and injury crash on BikeFriday's Yak forum. BikeFriday subsequently discontinued tikit manufacture and shortly afterwards shutdown the Yak.
Likes For tcs:
As I recall, pictured at the time, the fork difference was; 1st building technique, 2 tubes one over the other, ..
the 2nd version a single thicker tube, thicker on one end thinner than the other with same inside diameter..
So, solid, not sleeved over , doubled, for same function..
stepped rather than butted, which tapers from thicker to thinner.. usually maintains the same outside diameter ..
The main thing I look for in a used Tikit is the aardvark upgrade. That's the one that @tcs has labeled as the "Improved full loop handle". If this upgrade is present, the likelihood is high that the bike has received all the other upgrades or was produced toward the end of the Tikit's production lifespan when the upgrades were standard on the bike.
YW_Slayer
Folding Bikes
23
12-10-13 05:31 PM
vmaniqui
Folding Bikes
0
06-04-10 04:46 PM
