what size tires?
what size tires?
Old 02-01-15, 09:50 AM
captronk
Bikes: 2012 Fuji Traverse,
Quoted: 5 Post(s)
what size tires?
I currently have 700x38 sized tires right now. I wan to go smaller, what will fit on the rims? The rims are 622x19.
captronk is offline
Old 02-01-15, 10:07 AM
JerrySTL
JerrySTL's Avatar
Bikes: Giant Defy Advanced, Breezer Doppler Team, Schwinn Twinn Tandem, Windsor Tourist, 1954 JC Higgens
Quoted: 36 Post(s)
Liked 10 Times in 8 Posts
If the 19 is the actual interior width, you could go down to 700x28s. However you'd probably be better off at 700x32s.
JerrySTL is offline
Old 02-02-15, 07:58 AM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
What do you hope to gain with these smaller tires?
dsbrantjr is offline
Old 02-02-15, 09:14 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,271 Times in 877 Posts
Typically, exterior width is about 5mm wider than interior.
You can pretty much go as small as your exterior width, but I feel that's an absolute minimum and should stay at least 1mm wider.
You should be fine with 28's.
My hybrid came with 35mm's, which were total "slugs". I initially switched to 28mm's and it made the bike accelerate so much better and was easier rolling, it made the bike fun to ride.
I've since built a narrower set of wheels and use 25mm's.
Bill Kapaun is offline
Old 02-02-15, 03:44 PM
Dfrost
Dfrost's Avatar
Quoted: 502 Post(s)
Liked 466 Times in 256 Posts
Defining a tire's performance strictly by its marked width is missing the point regarding the variations possible in tire construction and weight.
There are heavy, sluggish 28's, and light, responsive 38's (or 42's if you include 650b variants). 25's will almost always be lighter, but not necessarily better rolling, and unlikely to be as smooth riding. Here's my favorite source for light, smooth, and "fast" (but not cheaper) fatter road tires:
Compass Bicycles: Tires
Frequently suggested as a tire that is a good compromise between light, smooth, wide, decent flat protection and less expensive are Panaracer Pasela, especially in the folding, PT, Kevlar bead version, or the similar T-Serv and Gravelking models.
https://www.amazon.com/Panaracer-Pase...913836&sr=1-12
Dfrost is offline
Old 02-02-15, 03:57 PM
nfmisso
Nigel
nfmisso's Avatar
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times in 6 Posts
Type of tire will make a bigger difference than width.
nfmisso is offline
Old 02-02-15, 04:26 PM
Bill Kapaun
A heavy, sluggish 28 will still be "faster" than a heavy, sluggish 38 for relatively smooth pavement.
Factory hybrid tires in the 35-38mm range tend to be heavy & stiff, giving excellent flat protection at the expense of quicker acceleration & rolling resistance.
Within a budget, you pick your poison. Faster, lighter, but more prone to flats OR flat resistance, but not as light and nimble.
Higher priced/quality tires can give a bit better"choice" of fast, light and/or flat protection for your use, within the various constraints.
Many of us don't want to spend $50/tire though.
daoswald
General Cycling Discussion
23
11-06-18 12:13 AM
Lrdchaos
Road Cycling
3
04-29-17 08:28 PM
curbowman
Bicycle Mechanics
8
04-09-17 05:48 PM
Shaqo_Wyn
Classic & Vintage
9
04-03-17 04:03 AM
max power
Road Cycling
6
01-24-11 10:19 PM
