What would be needed to convert this to a 1x11?
Bikes: 1970s Gitane Tour de France with double-butted Reynolds 531 throughout and Sport-Touring geometry; 1985 Cannondale racing; 1990s Fuji racing frameset with Reynolds 853 & Ultegra groupo; 1990s old "beater" Univega CroMo Mtn. Bike.
Quoted: 9 Post(s)
Liked 5 Times
Hi: I'm looking at this used bike, but it's set up with a Gates belt-drive single-speed system:
Those are American Classic hubs from 2012 or 2013. Would I need a new rear hub? The frame is a 2013 REEB All-Mountain. Is a derailleur hanger available for that? What cassette, derailleur, and shifter would you recommend? I'd like to not spend much. This will be used for Bikepacking and mult-surface touring.
It's been a really long time since I worked as a bike mechanic, and everything has changed so much. Any help/advice would be appreciated.
Make it all different ?
A new back wheel, big range cassetter , Rear Mech, chainring. all the tools to take what's on there and more put something else on
+ the right dropout with the hanger for the rear mech, .. and the shifters,,
How about a Shimano Alfine 11 speed gear hub and leave the belt drive on it? Or Rohloff 14 speeds ?
To Know How Much (?) Ask the shop that will be doing the Work.
Quoted: 9 Post(s)
Liked 5 Times
Thank you for the responses. I was hoping to keep the existing hub and crank, add a cassette to the existing hub, a chainring to the existing crank, a bolt-on derailleur hanger (I think REEB has one), and keep the costs down. I'll do the work myself, but It's been a long time since I've dived into what solutions are on the market. Does anyone know if the hub pictured can accept a cassette?
Thanks!
Thanks!
Thanks!
Thanks!
In fact, I'm pretty sure that's the case here. That looks like a regular cassette lockring.
Was the hub a wide cassette driver and a bunch of spacers to put that 1 belt cog on?
what Specific hub ?, I can't guess.. too much bother..
Quoted: 713 Post(s)
Liked 796 Times
That looks like it may be a single speed specific hub, so a full cassette may not fit on it. The dropouts are Paragon Machine Works sliders and you can get the drive side insert with a derailleur hanger from them. So, you'll need:
11 speed right hand shifter
11 speed cassette
11 speed derailleur
Narrow/wide chainring
11 speed chain
Drive side sliding dropout insert with derailleur hanger
I don't see cable stops or guides on the chainstay, so some zip ties or stick on guides
Possibly a new rear wheel
11 speed cassette
11 speed derailleur
11 speed chain
Quoted: 2337 Post(s)
Liked 2,810 Times
keep it single speed....it will build character in the hills
Liked 2,810 Times
there could be an issue with shifter disc brake compatibility also, that would need to be checked out
Quoted: 9 Post(s)
Liked 5 Times
Thanks again for all the replies. I got some better photos from the seller. The hub is American Classic, and the freehub is SRAM PG 1070.
So ... which cassettes will fit on the SRAM PG 1070 freehub? I've heard that all Shimano 10 and 11 gear cassettes will fit, but can anyone verify that?
Next step is to find out which chainrings are compatible with FSA cranks.
Thanks!
SRAM PG 1070 Freehub
Better view of the spacers
Thanks!
Quoted: 9 Post(s)
Liked 5 Times
Thanks for your help.
Liked 2,810 Times
Hi ... I'm sorry but I'm not sure where the incompatibility would be. Are you talking about the derailleur hanger? Location of the shifter on the handlebar? Sorry for being such a newb with this new stuff. I used to wrench in a bike shop, but the bikes I worked on are all considered classic road bikes now.
Thanks for your help.[/QUOTE]
no expert but if you are switching to a combined shifter/brake lever you would want to make sure the lever works with the existing brakes. If shifter is separate then no worries
Quoted: 9 Post(s)
Liked 5 Times
-Robert
Quoted: 630 Post(s)
Liked 369 Times
I would leave it as is but purchase a Rohloff 14 speed internal hub. Then you can mess with rear cog and crank sizes to get the gear ratio that you need. I think that you have a very very sweet setup here and going back to a traditional chain set would be going in the wrong direction.
Quoted: 6177 Post(s)
Liked 4,794 Times
What type riding do you intend to do? If for road biking, I just don't see this as a good thing unless you are getting the bike for free. QR's on disc brake wheels aren't considered a great combination. Though for those that don't have to dissipate a lot of energy to stop their momentum, they'll probably be fine.
But for the price you are going to have to pay to put 11 speed on it, you should be able to find a bike already with it. Again, even if this bike is free.
And if the frame isn't light, then you'll probably dislike it when you max out your climbing ability if you ride a lot. I sort of got that way with the Paramount frame I put new 11 speed on.
Thanks!
Thanks!
Things I don't know: whether this hub has interchangeable freehub bodies. If so, you could just pop off the 10 speed one and pop in an 11-speed one. DT Swiss hubs are modular this way, as are several others, but not all of them let you do this.
Second, the black part closest to the hub, I can't really tell what that is -- Is it a spacer that covers the freehub body and just has a flared shape? Or is it part of an unusual freehub body designed for single speed setups so you don't have to use a bunch of spacers?
Quoted: 9 Post(s)
Liked 5 Times
I can get a decent XT cassette, derailleur, shifter, chain, and chainring (11-50) for about $300.00 or less. The only thing I was trying to do in this thread is to figure out which of those replacement pieces will fit on the existing bike. I've gotten it all figured out now, so here is the info, in case someone else is looking for this in the future:
- A SRAM PG 1070 is compatible with Shimano MTB 10-speed and 11-speed cassettes, and is also compatible with SRAM 10-speed cassettes.
- Shimano drivetrain sets, including cassette, derailleur, shifter, and chain are available on ebay and amazon for decent prices.
- A replacement dropout with derailleur hanger is available from Paragon for $25: https://www.paragonmachineworks.com/...mm-skewer.html
- The front chainring is 104mm BCD (bolt center diameter). I'll probably go with 30 or 32t. That BCD is for the FSA V drive crank on my bike ... other cranks may vary.
I plan to ride this bike on the Great Divide Mountain Bike Route, which has more than 150,000 feet of vertical climbing over 2700 miles, sometimes over mountain passes as high as 11,000 feet. I definitely don't plan to ride a single-speed MTB, fully loaded with camping gear over that kind of terrain. Converting to a 1x11 setup seems to be the most practical, common-sense solution. Call me crazy, but I think it's perfectly OK to have a chain on a bike.
Quoted: 9 Post(s)
Liked 5 Times
The 1070 Sram thing is just a lockring that came with a 10-speed cassette. To tell what kind of freehub body you have under the spacers and cog, you'll have to take that off and slide out the spacers. If it's a 10-speed freehub body, you won't easily fit a 11-speed cassette on the existing driver. It can be done, but it involves various cobbles, such as machining off a little bit of the cassette's backside.
Thanks for your attention ... thanks to everybody ... I appreciate the help.
Quoted: 9 Post(s)
Liked 5 Times
Wow ... Thanks again to everybody ... this has been a real learning experience for me. I hope that I'll be able to return the help someday when I learn more.
Sram has long wanted to get a big slice of Shimano's dominant market share, so they are among the many companies
making parts that are using their standards^....
I had no idea that 11-speed mtb cassettes fit on a 10-speed freehub body. I thought it was the same as road. That's good to know.
