DW40 Dry Lube ?
DW40 Dry Lube ?
OK. Maybe this (chain lube question) has been asked a million times but when I try to use the search box I get totally irrelevant search results. Anyway, I use WD40 Dry Lube on my saws and I've been using it on my bike chain too -almost every ride- and I'm wondering if it's good enough. I know WD40 makes a lube (in a spray can) that's specific to bike chains and I'm wondering if these 2 are similar. Or is the one that comes in a small bottle better ?
https://www.canadiantire.ca/en/pdp/w...-0388090p.html
Thanks.
Thanks.
Quoted: 668 Post(s)
Liked 529 Times
Never thought to use that on a saw blade, will have to give it a try
Why not just use the bike specific stuff?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
WD40 also makes bicycle chain lube in drip bottles. Spraying chain lube on a bicycle, especially one with disc brakes, is a bad idea. You have much more control w/ the drip bottle and are much less likely to get oil on brake parts, which is obviously a bad idea.
I'm sure that what you are using now is good enough. Are you wiping the excess lube off the chain when you reapply or are you creating a massive dirt/oil mess?
Likes For Barry2:
Thanks for the replies. There's no reason why I'm not using bike-specific WD40 other than that I already have two cans of WD40 Specialist/Dry Lube (for machines, table saws....) and I'm not sure but they seem to offer the same benefits and have PTFE and this one is actually $2 less than the bike-specific one. So, if they're actually the same or close why buy another can just because it's made for bikes ?
I don't have disc brakes and when I spray the chain I basically spray gently -using the straw- near the rear derailleur pulley and I put a newspaper behind the derailleur so it covers/protects the rear wheel. I never tried drip bottle but I think aerosol is cleaner and you get more for the same price.
52psi
Quoted: 790 Post(s)
Liked 802 Times
More useful than any chain lube opinion I might offer:
The bikeforums search function has been hilariously broken forever. Best way to search something around here is via Google with bikeforums added...
"wd40 dry lube bikeforums."
Likes For Fahrenheit531:
Bikes: lots
Liked 2,932 Times
Me too. I'm purely saying this from personal experience. I've seen numerous bicycles w/ oil on the rear caliper/pads. Maybe bicycle riders are generally more clueless than moto riders?
Quoted: 668 Post(s)
Liked 529 Times
That bicyclist was absolutely clueless.
Wonder if a motor cycle with larger brakes and more heat are less sensitive to a bit of spray lube. I know I don't worry about getting finger prints on a car rotor like a I do a bicycle rotor.
On a road bike, the rotors/pads are exposed to puddles, road grit, rain and potentially sweat.
In fact, disc brakes are the preferred brakes for cyclocross and MTB.
The last 2 exposes the rotors/pads to mud - have you seen some of the "after" race pictures?
How on earth is a "clean" fingerprint worse that mud for brake pads?!?
However, I will say a "greasy" fingerprint will contaminate the pads if not cleaned off before use.
As long as you change gloves after regreasing bearings or lubing your chain, the rotors/pads will be fine.
If a little chain grease gets on the rotor, clean with any strong degreaser and the pads will be fine.
Quoted: 668 Post(s)
Liked 529 Times
I've had bike rotors squeal from "clean" fingerprints. Not a bad practice to wipe them down after any type of service. Seemed excessive to me as well but I've had it happen.
In all honesty, I don't worry too much about a little wheel bearing or caliper grease on car rotors. Car rotors burn that stuff off in no time.
joyful rider
I just started testing hexagonal boron nitride (white graphite) powder yesterday, so far very good.
Thanks.
Thanks.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3883 Post(s)
Liked 6,476 Times
