DL-1 wannabes from the bike share world (Social Bicycles)
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
This is not entirely C&V, but I always thought the Social Bicycles (SoBi) 3.0 (and later 3.5) models were heavily inspired by the Raleigh DL-1 and other loop frames of the early 20th century.
Just got these two donated from Boise GreenBike (one is from the Topeka Metro system) to the Bike Share Museum. I'll be putting up an article about them on the BSM site, but thought I'd share a few pictures. Nexus 3 rear hubs, Shimano rollers front and back. The Boise example is on record as having traveled 3,219.55 miles over 1,235 rentals since it was deployed in 2015.
The frame angles are a lot closer to a Raleigh Sports than the super-relaxed geometry of the DL-1, but the general spirit is there. 3-speed with an enclosed drivetrain (of a kind), and hub brakes. More or less what the DL-1 set out to do when equipped with a chaincase and rod-operated drum brakes.
-Kurt
-Kurt
Likes For cudak888:
Quoted: 809 Post(s)
Liked 1,022 Times
cudak888 I agree with the DL1 influence. In this case, it is the loop frame or Ladies model. Where was the bike designed? I think anyone that takes on a share bike design project would have about the same design goals as when Raleigh was designing their DL1. So whether knowingly being inspired by the DL1 or just facing similar outputs, there are similarities.
One thing that I always wondered about bike share bike design is that I know they want to use parts that are not common and therefore vulnerable to theft and have low or no maintenance. On these bikes, they went with the shaft drive. It is a low maintenance design also precludes the possibility of the chain falling off. However, the cost of this design must be quite high. I like how they paired it with a 3 speed hub.
It looks like the frame is aluminum, and the handlebars/basket is steel. It's odd how things have changed. It used to be that the frame was steel and the handlebars were aluminum. I know they have their reasons. This could make a nice commuter bike if you don't have to ride too long. I guess that is the point.
It must have no flat tires. It was the one thing about the bike share bikes (in my case it was Lime) that made it difficult to ride for an hour or more. And the straight fork. ... And cheap seat. I know they have to put those solid rubber tires on them, but it makes me wonder how much better the bike would be if it were sold to me and I put good old fashioned pneumatic tires on it. It might make it enjoyable.
I'll have to check out your Bike Share Museum website to get more info.
Liked 4,395 Times
Limes are their own curious beasts. First off, what looks like a straight fork is immensely raked (and 3+ pounds!), so they're not happy at low speed - but they have a ridiculous 28t front chainring, spec'ed regardless of whether the bike is a singlespeed, Nexus 3, or Nexus 8, which means you're always going slow and fighting the front end. I'm not that fussed about the solid tires as much as I am the band brakes. The slightest bit of rub from one of those bands makes riding a chore, and it's really difficult to get them not to rub while still providing good braking force.
However, I've also rebuilt a Lime using a wheelset and fork from a third-gen Spin. Drum brake up front and a roller in back, less rake in the fork. Made a huge difference. Some good tires would have made it even better.
I've put pneumatic tires on a second-gen Spin (which, unlike most share bikes, uses the English EA3 26x1-3/8" wheel size). Rides beautifully. Just had to drill the rims.
At any rate, the SoBi docked hybrids (they're not purely dockless as SoBi intended) like these 3.0s are considerably nicer and more carefully designed than most of the build-them-quick dockless machines. Also the only shared bike that I've come across so far with a threadless, sealed-bearing headset, which I'd argue is a major reliability benefit.
-Kurt
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,195 Times
Kurt, those shaft driven transmissions have always fascinated me. I've never been able to look at one closely. After the pandemic and on my next visit to Miami, I look forward to seeing and hopefully riding one as you describe all the inner magic. The ones on these Bike-Share bikes look beefy enough to survive a nuclear blast with no ill effects.
Bob
Bob
Likes For pastorbobnlnh:
Liked 4,395 Times
Not sure I want to disassemble the shaft drive without a manual for it though. I'd rather not have to ring up CitiBike for parts
-Kurt
PeopleCode delaminator
Those look like the same model the bike share by me ( CDPHP Cycle! ) uses.
One of the group rides in the summer months in the area is a time trial, I had suggested everyone use these instead of multi-$$$ carbon fiber rocketships.
The consensus was everyone would need to REALLY get beered up first.
Liked 4,395 Times
It'd be both fantastic and hilarious to see a one-make time trial with these. Bicycle racing needs more humor like that.
-Kurt
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I ride the NYC Citibikes all the time. Sturmey Archer, Shimano, NuVinci, they're all good but a well adjusted NuVinci is a blast. I'd participate in a lunchtime race around Central Park if anyone's up for that.
www.rhmsaddles.com.
www.rhmsaddles.com.
Likes For rhm:
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
I'm still not sure who made this particular shaft drive. The first few generations of Arcade-produced (France) CitiBike Miami share bikes use the same shaft drive with the huge, integrated BB assembly. CitiBike Miami's new #4000 series deviates though, as they're the first with chain drive.
As for the shaft drive, Brik Bikes looks like they used the same one. I have also found a technical description in Dutch about the technology but no link to the manufacturer of said drive shafts.
Likes For JaccoW:
Liked 4,395 Times
FYI, the Bike Share Museum story abut these two bikes are up, for those curious: https://bikesharemuseum.com/getting-social-bicycles/
The main profile page for each bike has yet to be created; I'll link them up when they've been posted.
Going to look through this later tonight. Thanks, Jacco!
-Kurt
After the title description this had to be you.
-Kurt
Likes For cudak888:
