BB problems on Road Bike
I think I need some BB work done. But thinking I can do this myself.
road bike is an Argon 18
Argon 18
Radon
I have a SRAM Apex crank
When I am riding . I all of a sudden get moments where you hear all this metal on metal screaming noise.
So I was able to take it all apart myself and look inside
I noticed I only had 4 ball bearings left . the bearings seem to sit and held in place by grease.
I am wondering how many bearings would i need to place here? as it is odd i could only find 4 bearings here. Should the whole circular of the BB have more bearings?
or would i need a new BB. here are some pics of the crank. I don’t have a pic from inside.
suggestions of what i should do, as per do it at home situation for now. as my LBS is backed up for a few weeks now.
Help and suggestions please. thanks
Argon 18
Radon
Non omnino gravis
Knowing what year and model of the bike would help a whole lot. But if there are as you say only 4 ball bearings left, that is a serious problem, and that whole BB needs to be replaced, as (so far as I know) any GXP BB would use cartridge bearings-- so there should be no way for individual balls to "fall out."
Non omnino gravis
Quoted: 4209 Post(s)
Liked 3,875 Times
Were you able to actually count the balls? if so then the cartridge bearings (one unit a side) were far more worn/broken down then should ever have been continued to be used. If this really is the case then the crank would have been slopping about with in the massively loose and unable to be supported by the lack of, maybe, 75% of the balls. Typical cartridge bearings will have 10+ balls evenly about the race and often held apart by a ring.
So what's the real story? How about some photos of the bearings? Andy
AndrewRStewart
AndrewRStewart
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Those are pictures of the crank. The bottom bracket is behind it mounted in the frame.
Bikes: Canyon Endurace
Quoted: 1041 Post(s)
Liked 926 Times
Your pictures aren't helping. How did you tear this down, see the problem and not provide pics of the problem?
SE Wis
Liked 3,401 Times
You don't replace the bearings you replace the complete bottom bracket.
https://www.sram.com/en/sram/models/bb-gxp-a1
Non omnino gravis
yea. it was turning when riding. but i would get a loud metal on metal sound
https://www.amazon.com/SRAM-Bottom-B...7890128&sr=8-5 + https://www.amazon.com/Acekit-Bracke...890201&sr=8-23 and pray that being in a completely destroyed BB didn't mess up the spindle of the crank too badly.
Likes For cpach:
tool bb
what tools would i use to take out old bb and install new one?
now to determine the proper size of BB, just go by the numbers on it? and size of tool? or most quite universal?
Quoted: 6196 Post(s)
Liked 4,810 Times
By the time you obtain all the stuff you need you might be better off with a bike shop doing it. The tools sometimes cost more than the bb and if your next crank and bb are a different type, then those tools will sit unused forevermore.
As well, they'll probably put the crank back in for you correctly and even tune up the DR for little to no additional cost.
no problem i found the tool, i had one all along and i was able to get the BB off now with no problems, just have to order the new one, thanks everything
if i went with a lower priced brand of BB would it still work with my crankset? would that be a bad idea? in regards to wear if using a cheaper BB over the type/brand i am already using?
SE Wis
Liked 3,401 Times
https://www.retro-gression.com/produ...bottom-bracket
i think i order the right one
says SRAM Bottom Bracket GXP Team Cups English 73/68mm
i assume thats the normal dimension/ otherwise how do i measure it properly?
when i measure from across it is 9cm or 90mm? across?
or what size do i select?
or how do i measure?
Liked 4,810 Times
Gosh.... bb's are expensive in Canada. The same BB here is only $19.00 USD. Hope you shopped around.
