View Poll Results: 1, 2 or 3?
1
8
40.00%
2
6
30.00%
3
6
30.00%
Voters: 20. You may not vote on this poll
Which one?
Raising the Abyss
1 if you use silver components, 3 if you use black components (and replace the stem with one that's either black or white).
Quoted: 1096 Post(s)
What are we supposed to be comparing?
Aside from the fact that the one at the top has pale tires and is turned the "wrong" way, the only readily apparent difference is in the lighting, which is so noticeable that it makes it hard to tell what's going on.
Mostly Harmless
Bikes: Have two wheels
Quoted: 13718 Post(s)
Liked 4,532 Times
Quoted: 18424 Post(s)
Liked 15,581 Times
Hello. What's this thread about?
Bikes: 2007 Ridley Excalibur, 2003 Orbea Orca, 199? Cannondale Headshock MTB hardtail
Quoted: 520 Post(s)
Liked 10 Times
I am also left guessing what we are comparing. OP, you need closer shots or just say what the choices are. I guess all three have different wheels? FWIW, I selected #1 for tire color aesthetics. Although I like the white on the hub flanges in #3.
Should Be More Popular
Quoted: 22601 Post(s)
Liked 8,928 Times
Raising the Abyss
Raising the Abyss
They do get bigger when you click'em.
Though seeing the overflow from the hot or not thread was worth the laugh.
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
Always go for no. 3, it's a good bet on Let's Make A Deal.
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
All else being equal (model, make, dimensions) white tyres have slightly worse grip than the black ones.
So I'd choose between 2 and 3. 3 because of the slightly deeper rims.
Option 2. Option 1 does look a little better, but white tyres won't stay white very long, they do perform a little worse than black all other things being equal, and you have a wider choice of good tyres in black than in white. Both 1 and 2 will need a silver groupset and white saddle and bar tape, of course.
Serious Cyclist
Bikes: Emonda SL6
Quoted: 5721 Post(s)
Liked 261 Times
Obviously we're comparing white balance settings on your cell phone camera, so I'd say #2 is the most natural. 1 and 3 are too cool and your lens appears to be smudged.
Quoted: 189 Post(s)
